Question about Skype IM
Can hear the echo sound test but when I record I cannot get playback I am using Skype5.1.0 on a lap top with Windows vista
H33looww..
Posted on Mar 18, 2011
Cannot get audio playback through headphones. Playback is fine when listening through computer speakers, but not through 2i2.
What type of laptop is this, Windows or MAC? If Windows, go to Control Panel/Device Manager and make sure that your USB 2i2 interface is being detected as an external sound card. Then check the Sound Manager in Control Panel to make sure that the external sound card is selected as the playback device. Go back through the setup portion of the users manual. Windows does not necessarily 'remember' settings for devices when they are unplugged and then plugged back in again.
Apr 03, 2015 | Focusrite Scarlett 2i2 USB 2.0 Audio...
I live in canada and have a wireless modem and now in the us of a, and when i skype my buddy , he can hear me but i dont hear him and my headphones work fine, please help
Set up Audio
Laptop x webcam/mic x Vista x Skype
If you have an older OS you may have to access your hardware from the control panel
TEST SPEAKERS
Right click on speaker icon in System Tray
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
Set required mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click OK
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
CONFIGURE TO SKYPE
Open Skype > Tools > Audio set up - run through defaults etc > Save
Make a test call from the inbox 'Echo/sound' test call
Oct 09, 2009 | Logitech Quickcam Chat Webcam
I need to get sound incoming with headset how do i do this?
Specifying if this was Windows XP or Windows Vista would make a difference in the fixing of this problem, I am going to explain for Windows Vista hoping that you are up-to-date on the most recent operating system.
Step 1: Locate your task pane in the bottom right corner of the screen.
Step 2: Playback options (I believe)
Step 3: Under "Playback" select your headphones from the list.
Step 4: Right click it and click "Set as default device"
Wallah, it should send the sound to your headphones now rather than the PC's output device, please note, once your not using the headphones anymore you must set the default device back to the normal speakers or you will have no spound.
Apr 27, 2009 | Insignia Bluetooth Wireless...
Audio problem
if it has a microphone you may be having you're microphone echoing whats coming out of you're speakers to disable it
windows vista:right click the speaker in you're tray click recording devices and click disable
windows xp:rigt click speaker icon in you're tray and click open volume comtrol and mute the current microphone
or if that's not the problem you may have to download new sound card drivers i can help you with that too!
Mar 11, 2009 | Acer Aspire 5735 Notebook
Echo problem in adobe audition 1.5 (not environmental)
My best guess to start with is a reverb setting of some sort.
Are you recording in multitrack or edit view?  If one, try the other, and see if you get the same results.
Another guess would be a sound-card setting.  If you have any special effects setup on your soundcard (onboard, pci, pci-express, usb, etc), that could cause it.  Things such as 3d-surround settings, environmental settings, etc..
Also, what version of Windows?  What sound card/ audio interface?
Jan 05, 2009 | Adobe Audition 1.5
Lg e500 notebook smart cam double speed and no sound on playback
Normal 0 Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Camera Microphone.
Click OK and it should work.
Hope this helps. Bud
Dec 13, 2008 | Computers & Internet
Skype
Audio Setup for Windows XP and Vista
1. Audio settings, in Windows and Skype
XP: Windows Control Panel / Sounds, Speech and Audio Devices / Sounds & Audio Devices
or Right-click speaker icon in system tray and select "Adjust Audio Properties"
Volume / Device Volume: Make sure “Mute” is NOT checked in this window.
Volume / Device Volume / Advanced: If there is no “Microphone” section in this window, go to Options / Properties and check “Microphone” in the “Playback” list. Then make sure “Mute” IS checked in this window
Audio / Sound Playback: Your on board sound/Sound Card
Audio / Sound Recording: Your on board sound/Sound Card
Audio / Sound Recording / Volume: Make sure "Microphone" is selected and the volume slider is at the center or higher
Audio / Sound Recording / Volume / Advanced: If “Microphone Boost” or “20db Boost” is present, select it
Vista: Windows Control Panel / Hardware and Sound / Sound / Manage Audio Devices
or Right-click speaker icon in system tray and select "Playback devices"
Playback: Your speakers or on board sound/Sound Card must appear in this list, and must show “Working”
Playback: Select your speakers or on board sound/Sound Card, then click “Set Default”
Playback / Properties / General: Device Usage: “Use this device (enable)”
Playback / Properties / Levels: “Mute” is not on, volume slider in the middle
Recording: Your Microphone or on board sound/Sound card must appear in this list, and must show “Working”
Recording: Select your Microphone or on board sound/Sound Card, then click “Set Default”
Recording / Properties / General: Device Usage: “Use this device (enable)”
Recording / Properties / Custom: If “Microphone Boost” is present, select it.
Recording / Properties / Levels: Microphone volume should be centre or higher
Recording / Properties / Levels: If there is a “Mute” button, it must not be on
Skype / Tools / Options / Audio Settings:
Microphone: Your headset/mic or USB device or Web cam mic, as you prefer
Speakers: Your headset, USB device or speakers, as you prefer
Ringing: VoIPVoice USB Phone or on board sound/Sound Card; also tick Ring PC speaker
Note: The audio devices you want to use MUST be present in these Skype device lists. If they are not, check the device connections and driver installations again.
2. Microphone and Speaker connections
Check if your mic (pink) and speaker (lime) jacks are in the proper sockets (it is easy to reverse them) and fully inserted (they sometimes stick only partially inserted)
If your microphone or headset has a “Mute” switch, make sure it is not on
If your speakers or headset has a volume control, make sure it is turned up
For test only you can use an earphone instead of microphone (really)! Just unplug the microphone, plug the earphone into the microphone jack, and talk into your earphones. (I know it sounds silly, but it might tell you if your microphone is defective)
A standard microphone plugged into Line In will NOT work.
3. Check audio in Windows.
XP: Start / All Programs / Accessories / Entertainment / Sound Recorder
Vista: Start [Orb] / All Programs / Accessories / Sound Recorder
Make a short recording with the microphone; you should see the level meters moving as you speak. On Windows XP, you can then play back what you recorded.
4. Once done, test with Skype Test Call (echo123).
Oct 19, 2008 | Computers & Internet
Echo indigo io recording problem
dont plug mic into output, it is input
May 24, 2008 | Echo Indigo IO Sound Card
Video sound problem
Durring video conferencing with MSN Messenger, I can't hear my friend and he can't hear me. Or I can hear them but they can't hear me. What's wrong? trnsp.gif Answer This article applies to the following products:
All Logitech Web Cameras with MSN Messenger Support
This article applies to the following software:
Windows XP
Test the Microphone in Sound Recorder
  1. Click "Start," > "Programs" ("All Programs" for Windows XP) > "Accessories" > "Entertainment" > "Sound Recorder."
  2. Click the Record button and speak into the microphone of the camera. You should see the green line move, indicating the application is picking up sound.
  3. Click the Stop button.
  4. Click the Play button. If there is no sound at playback, check to make sure the correct device is selected.
    1. Click "Edit," then "Audio Properties."
    2. Make sure Logitech is listed as the Preferred device for "Sound recording."
If the microphone does not work in Sound Recorder, click here for help in determining the problem with the mic.
While using MSN Messenger it is the messenger program, not the camera software, that negotiates the audio streams between two MSN Messenger Clients. Although we cannot directly support audio issues in MSN Messenger, the following steps have been known to resolve and improve audio issues in MSN Messenger. For further information, please consult the help documents associated with MSN Messenger.
Test Your Networking Router
You can also test to see if your router is causing audio issues by either physically bypassing your router and connecting directly to your cable/DSL modem or by setting up your computer as the DMZ (de-militarized zone). If you are a novice networking user, it is not recommended that you leave your computer in the DMZ state for extended period as that may leave your computer vulnerable to attack. However, you may briefly configure your computer as the DMZ to determine if your network settings are causing the audio issues. For DMZ setup instructions, please consult your router's documentation.
Enable Universal Plug and Play (UPnP) on both Windows XP and Your Router.
If either of the above steps resolves the no audio problem, try the following steps.
  1. Open Add or Remove Programs in Control Panel. To open Add or Remove Programs, click Start, point to Settings, click Control Panel, and then double-click Add or Remove Programs.
  2. Click Add/Remove Windows Components.
  3. In the Components list, select the Networking Services check box, and then click Details.
  4. Make sure the Universal Plug and Play box is checked.
Notes: If you used a CD to set up Windows, you will be prompted to insert it into your computer.
If your router does not support UPnP or you still get no audio after enabling UPnP on both Windows XP and your router, you must manually open all UDP ports between 5004 and 65535. This is because the audio streams are sent dynamically using that range of ports. Without a dynamic way to open those ports like UPnP, there is no way for MSN Messenger to successfully negotiate the audio stream. Consult your router's documentation for instructions to manually open these required ports.
If you are still experiencing audio issues within MSN Messenger, and you have verified that the microphone is working in Sound Recorder, contact MSN Messenger Support.
This article covers Accoustic Echo Canncellation (AEC) and how it works.
QuickCam 10.x and RightSound supported cameras
QuickCam 11.x and RightSound supported cameras
Call Central and RightSound support audio devices
This article applies to the following platforms:
Windows® 2000 Professional
Windows® XP Professional
Windows® XP Home
Windows® Media Center Home
Windows® Vista
Accoustic EchoCancellation (AEC)'s purpose is to prevent sounds from your computer's speakers to be picked up by your microphone. This can be a significant problem with audio or video calling applications where the voices or sounds from other parties of the call is being inadvertently picked up by the microphone and fed back into the call, creating echo and other sound distortions. Without AEC, this echo can detract from the quality of a call and in extreme situations, the echo can degrade the audio experience to the point where the audio is useless.
To prevent this from happening, the AEC component monitors sounds being played by your computer's speakers while monitoring the incoming sound picked up by your computer's microphone. The AEC module takes the outgoing and incoming sound signals and compares them to determine if echo is present. If echo is found, it is subtracted before the audio from the microphone is sent to the requesting application. This will result in the remote party only hearing you speak, without being distracted by hearing their own voice echo back to them.
When enabled, echo is eliminated for the recipient of the audio/video message. For echo free chatting, both parties need to have a RightSound technology enabled web camera that supports the AEC feature.
Apr 05, 2008 | Logitech Quickcam Chat Webcam
Windows vista home premium voice problems
TRY THIS http://www.bytescribe.com/downloads/tsp_codec_install.exe
Aug 28, 2007 | Logitech 250 Headset
Skype IM Logo
Top SKYPE Computers & Internet Experts
Mike
LP
Are you a SKYPE Computer and Internet Expert? Answer questions, earn points and help others
