Question about Brother MFC-9440CN Laser Printer
I just put in a new toner cartridge and it still prompted me to add a new one, it was still printing so i kept going. But now it's saying that the cartridge is empty and refuses to print any more. I've tried taking the cartridge out and putting it back in, but it still gives me the same prompt.
  • rjakubovsky Mar 16, 2011
    I'm not given a reset menu
  • 4,924 Answers
When you replace the Drum cartridge with a new one, you need to reset the drum cartridge counter by using the following steps:
  1. Turn the the machine's power switch back on.
  2. Press Menu > Machine Info. > Reset Menu.
  3. Press the Up or Down Arrow key to choose Drum.
  4. Press OK.
  5. Press 1 to reset the drum unit counter.
  6. Press Stop/Exit.
This will reset the counter and will see the toner cartridge as new..(if in the menu it is available toner reset instead of drum ..choose that one )
Posted on Mar 16, 2011
HP Color Laserjet Cp2025n Printer - driver says it's out of toner and won't print. No true. I put in new toner cartridge last week. How do I get it toreceognize the new toner?
Did you purchase a new OEM HP toner or a refilled or remanufactured toner. It is possible that the chip is bad on the cartridge in which case if it is a true HP cartridge have them replace it. If you purchased 3rd party go after the vendor to replace it.
Jun 28, 2011 | HP Laserjet Cp2025n Printer
I PUT A NEW TONER AND IT IS SAYING THERE IS EMPTY
Are you sure it was a full NEW toner cartridge?? Not an old one you had lying around.
If it was a new one the next question line goes as follows.... the machine will say in the display to "Rplace toner soon"...that dosn't mean its empty and to replace it..that means itsLOW and you should have a new toner cartridge "on-hand" because it will soon stop printing and say "REPLACE TONER". At that time the toner cartridge should be replaced, when it is installed a "fuse" on the cartridge blows and resets the toner light on the display. If you installed the toner cartridge when the display was saying "replace toner soon" you have blown the fuse in the new cartridge, now the machine has run about another 100 copies and says "replace toner"....but you now can't reset the light because the fuse is already blown because you may have replaced the cartridge too early!!! WHAT CAN YOU DO if that is the case...you can replace the fuse on the cartridge..its pretty easy to see, just replace it with another mini-fuse of the same rating written on the existing fuse..then put the cartridge in again..the fuse will blow, reset the light and away you will go. When all else fails read the operators manual.
Jan 23, 2011 | Muratec MFX-1430 Copier
Do the reset chips really work on the cartridges of HP 2500N laserjet printer
Yes, reset chips really work on laser printer cartridges, if you have a know good source for the chips and if you know what your doing, you can't put a new chip on an old cartridge, the chip is what registeres how may prints you will get out of the cartridge if you put a new chip on an old or 1/2 empty cartridge of course it will say it's full but then try and print.It will register as a full cartridge but it can only print with the amount of toner that is actually left in the cartridge, be careful there are alot of remanufactures out there that don't put new chips on or that do but don't fill the cartridge full, or replace all the wipers and drums, they just dump some toner in and say here you go, Only buy your remanufactured cartridges from a reputable company, do your research on them first or you'll be sorry
Aug 14, 2010 | HP LaserJet 2500N Printer
Put in new toner still says toner needs replacement ? Using original Brother toner?
Brother says a standard toner cartridge will print about 3500 pages ... Things You'll Need: Replacement toner cartridge; Piece of paper ... Turn off the printer and allow it to cool for at least 15 minutes, if you have been using it recently. ... Put the new toner cartridge in the printer same way the old toner ...
www.ehow.com/how_6394835_change-toner-brother-mfc_8220.html
Jul 20, 2010 | Brother MFC-7220 All-In-One Laser Printer
Using the same cartridges for the HL-4070CDW, I refilled the black yellow cyan and magenta cartridges. when I put them all back into the printer, the RED toner life end comes on saying that cyan, magenta,...
There's a window on each end of the cartridges and light shines thru to show when they're empty, your refill toner may not be the right density. If you put a small piece of electrical tape over the windows on the cartridge, the error will go away, but you have to watch print quality to change or add toner.
Aug 11, 2009 | Brother HL-4070CDW Printer
Canon MF-6550 ''toner not set''
check properly to toner if there is some stickers left on it and put it tightly to recognize it...
Jul 17, 2009 | Office Equipment & Supplies
DCP-130C COLOR INKJET
When inserting a new cartridge, you may receive a prompt
"The installed ink cartridge differs from the original ink cartridge for the printer. Your printouts may be different from those printed using original ink cartridges. Do you want to continue using the currently installed ink cartridge?"
If you click Yes, printing will continue. If you select No, you will be prompted to change the cartridge. Manufacturer prompts may vary.
Nov 21, 2008 | Brother MFC 420CN All-In-One InkJet...
Add Black Toner Msg.
Try taking out the cartridge and reinstalling it. Was this a original ricoh toner cartridge or a el cheapo cartridge off the internet?
Mar 19, 2008 | Ricoh Aficio CL2000 Laser Printer
Brother 5140 faint print
I had the same problem and I just fixed it.
It turns out that the toner cartridge I was using was not an authentic brother cartridge. It was an Office Max knockoff.
I replaced the knockoff with an original BROTHER toner cartridge and BAM! Right back in business.
What tricked us for so long was that the knockoff worked for two weeks before it conked out, so while we were looking for the problem, we kept saying to ourselves, "No, it COULDN'T be the toner cartridge. It's practically brand new."
Hope this helps.
Dec 27, 2007 | Brother Office Equipment & Supplies
Toner Cartridge Installation
Turn the machine off then on and let the machine go through the process of adding toner again repeat this about ten times. Then it should have added toner by then. If not then the toner motor is faulty and not turning. To check this by putting a mark on the toner bottle shut the door and let the machine add toner after this open the door and check the mark for movement.
Thanks J
Nov 29, 2007 | Ricoh Aficio 1515 All-In-One Laser Printer
Brother MFC-9440CN Laser Printer Logo
506 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
