I can only get the left and right FRONT speakers to play in DVD mode or FM or through the TV. I know they work because during set-up, they respond to db settings. The manual I have is in Spanish.
  • 635 Answers
That is because you have defeated the surround mode and the system is in pure stereo mode ( 2.1 mode )
Posted on Mar 17, 2011
I have bought a Sony Home theatre with total 6 speakers (including woofer, rear speakers (2), Front speakers with stand(2) and onr central speaker. But the centre speaker is not responding during TV,...
That would all be a function of your HTS, not necessarily the speakers.
Get a handle on how IT works, maybe find the manual and perform setup to verify the speakers work at proper levels.
I imagine it has several Digital Sound Processing modes that can create multi-speaker sound from any source.
http://www.retrevo.com/support/Sony-SS-CN550H-Speakers-manual/id/752ci570/t/2/
Feb 14, 2011 | Sony SS-CN550H Center Speaker
Bought a LG Blu ray DVD Home theater system last weekend and set up with LG lcd tv and has been working fine till today. We had the radio on and I turned the TV on and the two rear speakers do not work...
In a surround sound system, the correct way to listen to music is in stereo mode which will play out of your left and right channels and your subwoofer. When viewing a movie with surround sound, then you should use your rear speakers. The key element to remember is that rear speakers are only intended to play your sound effects, and will not play full range audio. Thats what your fronts and center are for. If you simply want to override this, than you will need to select the direct sound field on your receiver and than it will send full range audio to all speakers connected. Most likely, its not going to sound that good. If you dont know what each sound field does, here is a list and function of the most commonly used ones.
Stereo-Front Left and Right speakers including subwoofer
Dolby Digital or PLII Movie-these are the bost options for your surround sound
Direct-All speakers connected get full range signal
Good Luck
Jan 07, 2011 | LG Audio Players & Recorders
My home theatre was connected successfully playing the cd movie, but after turning off the dvd and go back to watching tv the sorroung system speakers do not give a sound to the television. is it that i...
hi,
select tv input on ur theater system. u can hear audio fro the frond left and right speakers. if u want to hear the audio from the surround speakers, then press the A-MODE button on ur remote to select different type of sound modes. press again and again to select different sound field. select one which suits u.
ok
Dec 27, 2010 | Curtis DVD5091 Theater System
Center and wireless speakers not working
are you tryng to get digital surround ? you can only get left and right audio or virtual surround sound if there is no optical or coax digital audio input connected from the sources digital output for that selection
Mar 06, 2009 | Panasonic 1000W 5.1-Channel Home Theater...
Reciever only allows 2 channels(speakers) at a time.
If the amplifier is not receiving a surround sound signal, you will get nothing from the rear speakers and probably nothing from the front centre. Play a dvd in dolby surround and it will work.
Apr 14, 2017 | Pioneer VSX-918V Receiver
I had this problem too. Finally, after using the MCACC setup and making sure all the speakers worked, I found I had to set the source to FM, TV or whatever from the remote control and set the mode to advanced surround sound using the front panal button on the upper right. Had to fool with them a lot. Good luck.
Jan 03, 2009 | Pioneer VSX-818V-K Receiver
1 front speaker and 1 surround speaker won't work on cable selection
theres probably a problem with the right channel cable or plug that connects the tv to the reciever, or the tv is set to mono audio.
May 17, 2008 | Yamaha HTR-6030 Receiver
Not getting sound from right speaker
How do you have the audio hooked up from the TV set? If its s video or RCA plugs? If it is switch them around and see if it swaps channels that goes out . If it does then the output cable or the jack is bad. If your using an HDMI ir a scart cable. The cable or connections could be bad. Unplug it and reinsert it or while the units on mover it around and see if the audio comes back on.
Sep 22, 2006 | Yamaha RX-V550 Receiver
46 people viewed this question
 Grubhead
Grubhead
