Question about Whirlpool Washing Machines
Whirlpool gas dryer heating problem first a get orange flame and then blue flame appears for a few minutes than off . I heard a rattle sound and orange goes on but goes off after 30 second. what part do I need to fix problem
  • 5 more comments
  • pccabana Mar 16, 2011
    Daniel thank you . Do you have a number for thermostat
  • pccabana Mar 19, 2011
    I replaced thermostat and is not fixed. After replacing thermostat it appear to worked. I left it running for 15 minutes and tried it another cycle and it for 10 minutes and than I shut it off. After I washed some clothes I placed clothes in dryer and when I went checked batch after 15 hotminutes I noticed it was not hot. What is the next I need to do resolved this resolved problem . thank you Norman
    Daniel
    Ireplaced thermostat in rear of dryer. It appeared to work. I ran the dryer for 10-15 minutes and blue flame was still on . I shut cycle off and tried it for another 10 15 minutes seem ok.
    I washed and placed batch in dryer and after 15 minuted I checked batch and drye was running but no heat was coming from unit. What do I need to do next to get continous heat
    thank you. Norm
    Replaced thermostat problem still not fixed what is next thing to do?
    Norman
  • pccabana Mar 21, 2011
    Dan
    I replaced thermotat and this did not solved the problem What do i try next.
    thank you norman
    Whirlpool Model NO. LGR 8858 EQ2
    replaced thermostat I used was part no. 3387134
  • pccabana Mar 22, 2011
    Daniel
    Igniter tested okay flame sensor replaced same problems, what is next solution
    Whirl pool gas dryer Model LGR 8858eq2
    thank you
    Norman
  • 4,323 Answers
Hi
I believe that everything else is fine rather it is the thermostat that is located inside the rear panel to the exhaust duct that is bad and should be replaced. If you want you can test this fuse for continuity and if bad replace it as it cannot be reset. If the fuse is fine then check the dryer belt and idler pulley...Hope this helps...please post back for further assistance.
Daniel
Posted on Mar 16, 2011
  • 2 more comments
  • Daniel Scott
    Daniel Scott Mar 16, 2011
    You can buy the parts from this link.
  • Daniel Scott
    Daniel Scott Mar 19, 2011
    Hi Norm
    Please let me know the model# of your whirlpool dryer.
    Daniel
  • Daniel Scott
    Daniel Scott Mar 21, 2011
    Hi Norm
    Daniel
  • Daniel Scott
    The issue can be with the igniter or the flame sensor, you can test the igniter first, if it tests fine then replace the flame sensor. Check these diagrams
What causes my gas dryer to heat and the flame goes out
Try using timed dry insted of sensor dry if runs ok you need aew sensor strips. also make sure dryer vent is clean.
Aug 10, 2014 | Whirlpool Dryers
Kenmore gas dryer #41793142300 electronic start doesnt heat up
if you first have heat and then like 10 to 20 minutes later no heat you could have bad gas coils,on most gas dryers there's a plastic cap you can pop off on the front panel so you can look in and see the ignitor,if at first the ignitor glows orange and the flame lights then after a few minutes the ignitor glows orange and the flame doesn't light you have bad gas coils,they are located on the top of the gas valve,easy to change.part number 5303931775 go here and look at part 71
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-41793142300/0582/0151200/R0310102/00005?blt=06&prst=0&shdMod=41793142300
Mar 25, 2013 | Dryers
Sg7800 maytag dryer stopped giving heat
Sounds like burner not igniting. On front of dryer in the lower right there should be a gas valve/burner access panel. Usually you just have to pry out at bottom of panel & swing out and up to remove. This gives you access to valve coils and igniter. With panel removed set timer for heated dry and start dryer, observing first the igniter which should glow bright orange-red, then after a couple seconds you should hear a "Click" which is gas valve opening and a blue flame ignites for heat. If no glow is seen after a few seconds or at least a minute, igniter is bad, if it does glow and no click is heard from the gas valve, the coils (electro magnets) on the valve are bad, or the "Flame present" sensor is bad. Chances are it's either the coils or igniter.Try this on all heat settings, if you get heat at only one setting it might be in timer contacts, but not common. Again you can repair/replace both the igniter (usually just plugs into a receptical) and the coils (2 donut looking objects on the gas valve, replace both.) Access door may be on back if not on front, but normally their on lower right of front.
Feb 13, 2011 | Dryers
The dryer has no heat when turned on.
Check your coils & igniter. Access door usually located in lower right front of dryer. Remove (pry up & out from bottom of panel, if no screws, exposing burner assembly. Set dryer for heated dry and start, you should see the igniter glow bright orange (give it at least a minute) followed by a CLICK sound,(again, a few seconds) this is the coils opening the gas valve, followed by a blue flame for heat. If no glow, replace igniter. If igniter glows bright and no click, replace the coils.
Whirlpool Model LGN2000KQ0 ignighter glows, flame turns on for a few minutes then it goes out and the ignighter never glows again nor does the flame return
The problem is the dryer coils have failed. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a link that should help troubleshooting a gas dryer
Sep 25, 2010 | Whirlpool GGQ8831L Gas Dryer
Whirlpool dryer lgr6620pq1 flame goes on for only 6 minutes the orange glo tries to relight but no flame. can I get a repair manual for it?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 23, 2010 | Dryers
Gas dryer heat is intermediate
does the igniter glow white or orange? if it is orange you need to replace it. has to be white hot to ignite. if the igniter is white it could be the coils not opening the gas valve all the time - an intermittent problem.
Oct 04, 2009 | Kenmore 73952 Gas Dryer
Whirlpool gas dryer "ultimate Care 2" does not dry my clothes.
yes, the gs coil is not opening. Go to www.repairclinic.com put the model number in and get the gas valve.
Aug 31, 2009 | Whirlpool LGB6300 Gas Dryer
Dryer heat shuts off
Hello, reading between the lines I'm going to assume you have a gas dryer. This problem is going to be your safety valve coils...basically they get old and over time of heating then cooling develop a short when they heat up...It may appear the gas lights to start but then goes out until the safety valve coils cool back down. Here is a picture of the coils 57d5263.jpgThis should solve your problem. Hope this helps, Please feel free to comment again if you have any further questions or concerns. Good Luck! Mike
Jul 24, 2009 | Whirlpool Dryers
Whirlpool LGR4634JQ1 Ignites the first time, then will not ignite
Hi, You will need to change the coils on the top of the gas valve. They are a plug in coil. This is a very common problem. If you need assistance on how to change them or the part#, I can help you. I would need you model#.
Thanks
Vic
May 13, 2009 | Whirlpool LER4634J Electric Dryer
Washing Machines Logo
160 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
