Question about Samsung Microwave Ovens
How do you change the weight setting to metric on the Samsung MW6194ST Microwave?
How do i use thye defrost
You read the weight of the food on package (in lbs)
Put the food on a microwave safe plate /container.
Close the door.
Press the Defrost by weight button
Enter the weight of the food. The time will be set automatically.
If you have a defrost by time, just decide on the time duration and enter it
Nov 28, 2013 | Microwave Ovens
I need to know how to use the defrost on the microwave
Close the door.
Setting level power of microwafe samsung
You can either choose to select the SET levels for the heat which can be a direct button or you can select the power button and scroll up or down the settings. Also the weight of the food must be chosen to be effective for the heat.
Click on Microwave
Jan 31, 2013 | Microwave Ovens
How do i change from imperial to metric
on a microwave?
there may not be a way to do this.
Nov 08, 2012 | Microwave Ovens
Time and weight setting doesn't works
There will be a reset switch button on your microwave's timer or somewhere on the appliance. Try the button and if it doesnt work then call customer care. It seems like a minor problem and can be fixed quickly..
Jul 29, 2012 | Panasonic NN-C994S Convection/Microwave...
Just need the mounting screw size. They got lost somehow.
they're usually metric and around 3" in length. you will probably need to order the original.
Aug 03, 2011 | Samsung SMH9187ST Microwave Oven
I am not knowing how to operate the microwave tobake a cake...i am unable to set the time after i select the cA mode
The baking mode for cakes relies on wet weight of the mixture, not time as there is a humidity sensor that sorts that out.
Press the CA button to select Cake and the weight button to select the weight then start.
Jan 02, 2011 | Electrolux Microwave Ovens
I wish to change my Panasonic Microwave weight indicator Kg to Lb
If it's a US model, and you've lost your owner's manual, you may be able to download one here.
If it's a non-US model, look at the support links for your country via Panasonic.net.
May 03, 2010 | Panasonic Microwave Ovens
Microwave Ovens Logo
97 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
