Question about HP LaserJet 1020 Printer
Text and graphics not printing complitely Half Image and Half take printing from HP 1020 printer. If I give Print command only two or three line print come on paper after that four to five line black again two or three line print with half image.
  • HP Master
  • 1,915 Answers
Try another cartridge as it sounds like your drum is bad. If you measure the distance between the start of two sets of print I can tell you exactly what is wrong.
Posted on Mar 16, 2011
Why does every other line of print have the top half of the print cut off?
The print head prints two lines of text/image at one time. If there is a partial print of alternating lines, you probably have a partially clogged print head. Print a test page to see what you get, and perform head cleaning process if needed.
Dec 29, 2015 | HP Photosmart 3310 All-In-One InkJet...
I have hp laser jet 1020 printer., when i provide print command all commands are showing in different language which i can"t understand
Called "Junk Print"...Check USB cable, Check USB port dry solder mounted on printer mother board., remove & re-fix farmatter board.. If not solved replace formatter board. If ur technically sound replace USB port mounted on board..
See the image farmatter P/No: CB409-60001
Feb 27, 2015 | HP LaserJet 1020 Printer
Printer hp 1020 in it when we print command of more then two paper the second paper jam (half inside and half out paper does not reach to Teflon part section . single paper printing is OK no pro....
Clean the Paper Feed Rollers with wet cloth.Then go to start-ControlPanel-Printers-select Hp1020 printer-properties-features-change the Paper Type as PLAIN PAPER.
May 23, 2011 | HP LaserJet 1020 Printer
HP 1020 produces 2 grey lines at edges of page
it is the problem humadity or laser mirror is dirt clean it and then solve your problem
Jul 05, 2009 | HP LaserJet 1020 Printer
Not printing in foxpro 2.6 dos to hp laser jet 1020
You write "type the above line at command prompt". I dont't know Where exactly to write? Can you tell me!
Feb 05, 2009 | HP PSC 1610 All-In-One InkJet Printer
HP Laserjet 1022 does not print the full date in voucher
adjust the page setting through pagesetup .and then check out in the print preview first before giving the print command.
Dec 10, 2008 | HP LaserJet 1020 Printer
Black line inide right margin of anything with a graphic element
Hello ,
Before printing from application > go to properties > under type, select Rough or heavy and then print it
- NIkhil
Nov 15, 2008 | HP LaserJet 1020 Printer
TO Print the image using IPL.
I've printed images over 500kb. Can you print a small image? If not, perhaps the driver is the problem.
If you're trying to send a text file of IPL commands to the printer, set up a Generic Text printer driver, to to send the file as ascii characters instead of as a graphic image. You can set this up in addition to your Intermec driver.
Go to Printers and Faxes, Add Printer, Next, Select the Port, Select "Generic" Manufacturer, "Generic / Text Only" Printer, and give it a name like "Text". Cycle the printer power to clear previous attempts, then print the file to this printer name.
Aug 22, 2008 | Intermec EasyCoder 3400 Thermal Label...
Hp1020 won't print pdf files
The 1020 Has Known issues printing PDF files. The HP LJ 1020 is a HOST printer with NO SUPPORT for PS (post script) or PLC commands. Most users end up printing the PDFs as images. That was not a solution for us and we trashed our 1020 and went with another brand. Good luck.
http://forums12.itrc.hp.com/service/forums/bizsupport/questionanswer.do?threadId=1153974
Jan 03, 2008 | HP LaserJet 1020 Printer
Regarding printing of envelopes.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00602236&cc=us&lc=en&dlc=en&product=439320&dlc=en&lang=en
http://h10061.www1.hp.com/ccsearch/search?ctry=us&lc=en&dlc=en&mode=lz&tmv=0&method=prodFinder&pid=439428&productBigSeriesOid=14924&spid=439320&pname=HP+LaserJet+1020+Printer&opname=HP+LaserJet+1020+Printer&pname_desc=HP+LaserJet+1020+Printer&st=1&ptype=consumer&stype=pn&qry=printer+doesnt+print+the+first+time&translate=&iqry=&ctflag=&temp_hql=s-001%2Cs-002%2Cs-004%2Cs-003%2Cs-005%2Cs-006%2Cs-017%2Cz-001%2Cc-002%2Cc-001&spname=HP+LaserJet+1020+Printer&cqry=&uqry=
Oct 20, 2007 | HP LaserJet 1020 Printer
HP LaserJet 1020 Printer Logo
235 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
