Question about Onkyo Audio Players & Recorders
Onkyo Integra A-8500 Serial No. 1909011056, no volume
Onkyo Amplifiers & Preamps
Hi ,try cleaning your volume control ,here is a video so you can DIY or contact your local service. :)
Dec 17, 2013 | Onkyo Audio Players & Recorders
Onkyo integra dtr 6.8 protrection problems
The audio output stage has load issue, check speaker wires for shorts, if okay! the problem is in the semiconductors and this is where a professional is needed.
Apr 03, 2012 | Onkyo TX-SR605 Receiver
I need a onkyo m-506rs meter driver circuit board 1786
This is a driver circuit board for an Onkyo power amplifier model Grand Integra M-506RS. It is unlikely that this assembly can be found, amd I suggest that the existing assembly be repaired.
Dec 22, 2011 | Audio Players & Recorders
I have an older onkyo integra (TX-870) which pop when I change stations, then no sound. Need to turn off and begin again. Can this be fixed or should I purchase a new 2 channel sys?
Hi, It sounds like you are listening F.M. radio and the F.M. muting button is engaged ( as well it should be-otherwise you will have static between the stations ) sometimes there is almost a "THUMP" sound when you switch stations-this is caused by the receivers P.L.L. circuitry losing then locking in on stations, if you do not lower the system volume you will amost assuredly cause an overload of your final drivers, that's why it will come back on when turned off-it has reset. Turning off fm muting will get rid of the "POPPING" noise-it will however leave you with unbearable static which in turn should cause you to lower volume momentarily eliminating the need to constantly turn off the receiver. Thank for asking FixYa, I hope this helps, let me know how I did or if I can be of more assistance, good luck Prodzilla
Apr 13, 2011 | Onkyo Audio Players & Recorders
Connecting Airport Express to my Onkyo Receiver
Plug it into the cd input, with the two rca cables. We've had this set up for years. No longer use a cd player at all.
Mar 24, 2009 | Onkyo TX-SR803 Receiver
Onkyo Integra A-809 input selector switching by itself
This is not an IR problem. Could be just loose connectors and dry joints. You'll need to open the unit and visual inspection of the PCB and connector for abnormality.
Good luck.
Jan 20, 2008 | Audio Players & Recorders
230 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
