Question about Linksys Wireless-G Broadband Router
Laptop wireless internet connection problem
I have D Link 802.11G/2.4 GH2 router.sometime it wireless connection easily connected but sometimes it is very hard to connect.can anyone can help me.
  • 155 Answers
Sounds like th connection between router and ant may be loose or the router just may be failing ither way check connections for loose or oxidized copper.
Posted on Aug 08, 2008
Limited connectivity
Limited connectivity (this phrase occurs first inside the WIN 8 OS) means, that you have connection with your router already, but NOT to the internet. Pls. check, if you have access to internet from other computers or smartphone connected via the same router.
If so, sometimes a driver-update for your D-Link could be useful.
Check also, if other wireless adapters are working with the same frequency, this may disturb. Try to change the channel or change from 2,4 GHz to the 5 GHz Channels, if the router & your D-Link Adapter will support this.
I had the same problem with my WIN 8 - PC and I had to change the (wireless) radio-channel.
Aug 15, 2013 | D-Link D Link Dir 825 Xtreme Dual Band...
Bought a new acer 5750 laptop (i5 2nd Gen, 6GB RAM) which connected intermittently to my router. PC World phone help worked through network adapter enable/disable and then eventually a full default...
I would try:
1. updating driver
2. try connecting via Ethernet, if the issue is only wireless connectivity, try using a USB wireless network adapter, if that works means your lappy has a bad built in network adapter.
3. Are you locating laptop too far from router?
Good luck.
Mar 09, 2017 | Acer Computers & Internet
My router is not gettting connected with laptop. Its hsowing lmited connectivity problem eventhough the signal strength is excellent.
Sometimes the router does not issue an IP address to the laptop and you get this error message.
Right click on the wireless icon on the Task Bar and click on Repair. The router will issue a new IP address to your laptop and you will be able to get Internet connection.
Dec 09, 2010 | D-Link Wireless N 150 Home Router 4Port...
I have F6D4230-4 V3 Enahanced wireless router G. The connection to the internet keeps getting lost and then comes back on. Sometimes I can't get it to connect to my laptop at all, even when the wireless...
1.Log into router. Using either 192.168.0.1 to 192.168.1.1 in a browser window that is ( internet Explorer or Firefox)
2. Verify wireless router name( on the computer) >>> ( on/off) ( router status window)
3.Note router name you are connecting to.
4.. Check the laptop/desktop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address. This set up in the "security tab" in the router. using 192.168.0.1 or 192.168.1.1 to access through a browser.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
8. check for firmware update at the manufacturers site for your model router
9. cell phones, cordless phones, digital TV's, can affect the data signal from a router. Also distance from the router can be a factor. If your router is in a basement place the router to a upper floor and center it in the room.
Sep 29, 2010 | Belkin (F5D8231-4) Wireless Router...
Connecting a laptop to internet via wireless lynksys router.
ok make sure your router is set up connect to your router and check under the wireless settings make sure you have made a custom name for your wireless network and have some network encryption enabled for it i prefer wpa personal over wep as wep can be cracked easily so after you make up a password be sure to remember it you'll need it later, so after all those settings are saved close that out and goto your laptop open up the wireless network connections and click scan after your network comes up double click it and you should be prompted for a password, enter the password you set up on the router and click connect, also windows will sometimes ask you to verify the password after you have entered the password you will hit connect after a short period of time it should connect to your router and internet is yours :) enjoy
Sep 30, 2009 | Linksys Wireless-G WRT54G Router
Wireless Internet through 2Wire router not working
First of all change your router to WPA rather than WEP. WEP is easily cracked now and is not secure. That might be what your laptop is looking at.
Secondly, update the wireless drivers to the current version from the website.
Make sure your router is broadcasting on 'auto' (802.11a/b/g, and N if supported), It ay be broadcasting only on, say 11g and your laptop doesn't support it. Updating the wireless drivers may also fix this.
Jun 23, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Slow or intermittent wireless/then disconnected
thats not enough info. it could be a dead router, too much interface, incorrect settings. try the router at your friend's house. if it works then its not your router. download a software called network stumbler, install it, to run it in vista right click it and click run as administrator. find the channels your router and other routers in the neighborhood are using. if they are the same then its an interference issue and if not then your router has incorrect settings.
Jun 04, 2009 | D-Link DGL-4500 Wireless Router
Dell Laptop with XP keeps dropping connection
find the manufacturer/model # of your wireless adapter and download the latest driver from dell's website (you can go to support.dell.com and enter your service tag/laptop model # if you want).
Jun 08, 2008 | D-Link DIR-625 (790069292637) Wireless...
Linksys Wireless-G Broadband Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
