I need a filter cartridge KSA1254. - Computers & Internet
  • 28 Answers
Old Intex pool and 03f filter system. Where can I get filter covers for inside the pool?
Intex makes 3 main types of cartridge filters. Types A,B, and C. Stores usually have atlest 2 of the 3 and amazon would have all 3. You just need to find out what one you need.
Jul 30, 2015 | Intex Pool & Spa
Where is the water filter frs24wscb
Good Afternoon Friend,
I understand you want to know where the water filter is located on your Frigidaire refrigerator, model# FRS24WSCB. The water filter is located in the top back right-hand corner. To change filter follow the instructions below:
It is not necessary to turn the water supply off to change the filter.
1. Set ice maker lever (wire signal arm) to the OFF (up) position.
2. Hold filter cup firmly, and unscrew counter clockwise. (Some water could leak out as you remove cup. This is normal.) Filter cartridge should come down with cup. If cartridge remains in housing, pull down gently, while twisting filter back and forth.
3. Empty cup of any substance.
4. The large o-ring that seals the filter system sets in the o-ring groove down inside the cup. Should the o-ring fall out during filter cartridge replacement, simply place it back in the groove prior to screwing the cup back in place. If the o-ring becomes damaged, you will need to order a new one from the Consumer Assistance Center.
5. Discard old filter cartridge.
6. Remove new filter cartridge from packaging, and install.
7. Place filter cartridge in cup. The end with the small o-ring should be up, out of the cup.
8. Screw cup, with filter, back onto housing. Do Not Use Wrench To Reinstall Cup. Filter cartridge will self-align as cup is tightened. Be sure cup is completely tightened with PureSource Plus Logo facing outward. Do Not Tighten Past Stop.
9. Set ice maker level on the ON (down) position.
10. Check for leaks. Open refrigerator door. Wipe any water drops from the filter cup. Run a glass of water. If there is a leak, unscrew filter cup, and reinsert the filter cartridge. Check placement of large O-ring. Reinstall filter cup, making certain it is tightened completely.
11. To condition filter system and purge air from water line, run several glasses of water through water dispenser. This will also assure that the purest water possible is stored in water tank.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 01, 2014 | Frigidaire FRS26R4A Side by Side...
Where is the water filter on frs24wscb?
Good Afternoon Teresa,
-Best Regards-
WP
Jul 01, 2014 | Frigidaire Refrigerators
No pressure in Hansgrohe shower when on hot setting
This is most likely debris in the filter screens on the thermostat cartridge or the thermostat cartridge has worn out. Cleaning the filter screens may resolve the issue. If cleaning the filter screens does not resolve you may need to purchase a new thermostat cartridge. If you need further information feel free to contact me at Hansgrohe. 1-800-334-0455. Press 2 for tech and ask for David Scarborough. I'd be happy to help.
Oct 27, 2012 | Hansgrohe Shower 26101 Pharo Prestige...
My Galaxy side by side refridgerator is leaking from the water filter system. When I removed the water filter the leak stopped. Do I need to replace the filter cartridge or is it something else?
Start with the cartridge. If the cartridge was frozen then you'll more than likely have to change the housing as well. This is only if the filter is on the inside of the machine. If its located underneath then change the filter and just check the lines that go to it by removing the kickpkate and taking a glance
Jun 03, 2012 | GALAXY Microsystems 25.4 cu. ft....
After i change the water filter de button of water still red
The water filter status light, located at the top of the refrigerator
compartment, will help you know when to change your water
filter cartridge.
Style 1 - Standard status light (on some models)
When the water filter status light changes from green to yellow,
this tells you that it is almost time to change the water filter
cartridge (90% of the filter life has been used). It is recommended
that you replace the base grille water filter cartridge when the
water filter indicator light changes to red OR water flow to your
water dispenser or ice maker decreases noticeably. See
"Changing theWater Filter Cartridge" later in this section.
After changing the water filter cartridge, reset the water filter
status light by pressing the light switch 5 times within
10 seconds. The water filter status light will change from red to
green when the system is reset.
If you need Adobe Reader Click=> Adobe Reader X (10.1.0) (50.25 MB)
If helpful please rate this solution, Thanks Sea Breeze
Click Photo Below for User Manuals
Jul 29, 2011 | KitchenAid Superba KSRG25FK Side by Side...
I need to replace the filters on my culligan reverse osmosis ac30 and i got them mixed up...which one goes where
The Sediment filter goes in LEFT cartridge
The Block Carbon filter goes in the RIGHT cartridge
The Membrane goes in the CENTER cartridge
RJ
Sep 17, 2010 | Culligan Under Sink Water Filter
Need to find water filter on my amana model scd23vw refrig.
Install Water Filtration Cartridge (some
models)
a. Remove bypass cartridge from water filter head in rear
right corner of refrigerator section. Twist cartridge
counterclockwise 1/4 turn and pull down to remove.
Save bypass for use at a later date.
b. See Water Filtration System Installation and
Operating Instructions provided with water filter
cartridge for filter installation and operation.
Aug 16, 2010 | Amana Refrigerators
Need to Replace a HD-920 Culligens cartridge
Take a leather belt, stick the end into belt loop, slide loop over cartridge. If belt tighten-up against cartridge keep pulling until cartridge is loose, if belt doesn't tighten turn belt over and reattach to cartridge.
Jul 07, 2009 | Culligan Sediment Water Filter Heavy Duty
Brita filter needs replacement, but is stuck. any advice?
Hold filter cartridge in one hand and slowly turn on water. The water pressure will push the cartridge out of the housing.
Jan 09, 2009 | Brita 35516 Pitcher
Computers & Internet Logo
571 people viewed this question
David Payne
David Payne
