The motor is starting to get a high frequency noise when running the blower only.
    President:
  • 1,796 Answers
Hi!!
That sounds like dry motor bearings or bushings, lubricate if possible. If motor is older than 3 yrs. you better off replacing it.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Posted on Mar 16, 2011
I have no heat or air blowing out of my vents. Any ideas?
still nothing,????
why do this backwards. ??
or not using simple diagnosis>?
so really you failed to state the beginning symptoms?
was it just just noise. or noise and no blow.
or the noise is gone,, but my fix broke the blower.
there will no heat not moving, if the blower is dead.
get heat , moving in non circ, mode.?
sure i bet you do an that is SOMETHING.
does the blower make sounds like a normal blower, then if no air flow
the dampers are bad.
blower silent? on all speeds, , do say so.
blower works only on high (sounds) ?
if the blower is running, surely you can hear it spin fast.
and there is no flow, the damper is bad or the blower fan blade set screw
is missing and or loose. did you check that screw first. before.
replacing the motor? id not ever skip that step.
we can not help you ,with no facts or symptoms but still nothing.
Sep 16, 2014 | 2006 Jeep Commander
A/c will not blow on high
Could be the high speed blower relay. On most models the lower speeds are controlled by the resistor and high is powered by a relay.
Jul 24, 2013 | 1998 Oldsmobile Intrigue
The blower fan runs on high all the time. Tried a new fuse box but, still keeps blowing on high. ac and heat work but always on high, annoying with the noise!
You have a bad blower motor resisitor. The rssistor is normally under the dash on the passenger side. If you find the wires to the blower motor and follow them it should lead you right to it.
Nov 29, 2010 | 2005 Chrysler Pacifica
Heater blower making noise
Blower motor bearings likely failing....dry ! I have been lucky many times by drilling a hole on high side of motor shaft and adding non-detergent 30 Wgt oil. to front and rear.
I say high side to be sure when motor is remounted...the oil doesn't run out.
Sep 06, 2010 | 1997 Pontiac Grand Prix
The heater fan on my 98 chevy silverado stopped working... worked on high at first but made a high pitched noise and stopped all together
Run 12V directly to the motor and see if it will run, if it dosent than the motor is bad, if it does than the resister is bad, the resister makes the blower run and also regulates the speeds for the blower, but chanses are if it was making a high pitch squeel before it quit the motor went out.
Dec 10, 2009 | 1999 Chevrolet Silverado 1500
Motor noise coming out of speakers
you may have a short in one of your speaker wires, or your antania
Aug 07, 2009 | 1993 Buick Century
02 Dodge ram blower motor only runs on high.
blower motor resistor $15 at dealer and easy to change
May 21, 2009 | 2001 Dodge Durango
Heater/ac only works on high...and on high it's extreamly noisy
sounds like relay to me but what blew it, most likely dry bearings on blower motor causing your noise clean oil fan motor install relay
Dec 27, 2008 | 1996 Chevrolet K1500
Heating & Cooling Logo
133 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
