Question about Fanimation Ceiling Fan - 157082
Where can I purchase Hampton Bay Ceiling Fan PC Boards? Remote control operates fan blades fine. Electrical testing of fan light switch tests fine. NO lights at all. All bulbs test fine in table lamp. No help whatsoever from HomeDepot stores or online.
3 Suggested Answers
SOURCE: mika aire remote fan
Not sure if this addresses your problem or not, but with my Minka Aire ceiling fans, the fan has to be moving in order to change the fan direction. Turn the fan on (any speed works), then push the reverse button. The fan will speed up to max, then you'll hear the gears switching. The fan will slow to a stop, change directions and get back up to speed in the new direction.
Posted on May 09, 2009
ViscamTech
  • 528 Answers
SOURCE: I recently purchased THE DRACO
Some fan models create a strong wind. These usually have somewhat shorter, more slanted blades.
In science we say there is a equal and opposite force to any force (Newton's third law as I remember). Therefore when creating a strong wind, much larger force (compared to other fans) is exerted on these blades. To avoid swaying of the fan due to this force, the fan is made heavier.
Although this type of fans are rare these days, it was common in good old days.
Hope this answers your question. If it does please rate my answer.
Thank you for using FixYa!
Posted on Sep 21, 2011
My light on my ceilinf fan will only stay on dim.. What can I do to fix it.. It only operates bt remote
if fault is not on remote , you may need to bring down the ceiling fan and check on stuck electrical contacts and sensors to fix the problem.
Dec 28, 2013 | Hampton Bay Indoor Ceiling Fans and Light:...
Need to program Hampton Bay Ceiling fan remote control CHO88T7030T, HELP!
Change the battery. This is the first step when troubleshooting a ceiling fan remote. The easiest fix to any remote control problem begins with battery replacement. A 9-volt battery is needed to operate all Hampton Bay ceiling fan remotes.
Check the light switch used for the ceiling fan. The light switch found on the wall must be in the "on" position. This allows the ceiling fan to be operated by remote control
Re-program your remote. If battery replacement fails to get your remote working again, try to reprogram the remote. Open the battery cover you will see 4 dip switches. These switches must be set to the same position as the receiver on the fan. Use the screw driver to move the dip switches either up or down.
Follow the previous step to change the frequency if the ceiling fan is randomly turning on or off. Other electronic devices such as garage door openers can interfere with the ceiling fans receiver, causing it to randomly turn on or off.
Sep 10, 2011 | Televison & Video
We have a Hampton Bay silver ceiling fan that was from the former tenant in the apartment. It is a five blade with four silver encased lights. It has a remote control. It does not operate now. I have...
you need to make sure there is not a wire loose inside the ceiling fan electrical housing you lost power somewhere they also have small electronic control boards installed in them now check for broken wires or shorts first. You will need to take the screws out at the top by the ceiling. It will be the round cover up by the ceiling with the rod coming down through the middle. Make sure to turn off power first.
Dec 17, 2010 | Hampton Bay Heating & Cooling
Missing remotes for hampton bay ceiling fans
https://www.google.com/search?q=remotes+for+hampton+bay+ceiling+fans&rlz=1C1PQHB_enUS689US689&espv=2&biw=1536&bih=748&source=univ&tbm=shop&tbo=u&sa=X&ved=0ahUKEwik3qiMx4bTAhXh5oMKHV3vDJ4QsxgIGg
Apr 02, 2017 | Hampton Bay 52 In. White Redington...
Hampton bay ceiling fan stopped lights work
you can test the light switch by temporarily hooking up the light bulb to where the fan normally goes ....the bulb will only work on the highest speed setting but can prove if the switch is bad or not . turn power off before woking in there ... if you know someone with a volt meter then they could quickly test the switch for you .. they can also test the motor for continuity .. .. most of the time the trouble is simply bad connections inside the wire nuts ... like insulation not skinned properly or wire not in the wire nut properly ..you can remove and inspect each connection (power off of course) ... sometimes there is a seperate power line for the fan and light ... so they can be independently controlled externally ... thats not needed when the pull chains are the only off on method ...
Apr 15, 2010 | Hampton Bay 52 In. White Redington...
How to make the fan reverse
There 'should' be a small switch just below the fan blades on the center dome that will slide up or down. It is usually square and black. Slide it in the other direction....
Jun 24, 2009 | Universal Remote Control Hampton Bay...
Hampton Bay Ceiling fan wobbling
The fan came with one or more clips and some small weights that easily stick to the blade. Now with the clip you put it in one of the blades, starting from the far end and coming inwards, little by little. Try putting the clip in the middle of the fan and turn on the fan and see if it continues wobbling, if it continues wobbling try moving it to left and right and every time turn on the fan and see what happens. When you find the correct spot, there you glue the small weight.
Apr 09, 2009 | Universal Remote Control Hampton Bay...
How do I reverse the direction of the fan blades to counter-clockwise on the fan? The fan is a Hampton Bay ''Clarington'' with a remote control.
There is a small black switch on the switch housing directly under the blades. When the fan is completely off, move the switch to the opposite direction.
Mar 31, 2009 | Universal Remote Control Hampton Bay...
You have a dangerous electrical situation call an electritian to test the wiring.
Oct 20, 2006 | Hampton Bay 04379 Madison Avenue Ceiling...
Dryers Logo
29 people viewed this question
Top Fanimation Dryers Experts
Michael Galve
Michael Galve
Paul Bade
Piyal Perera
Piyal Perera
Are you a Fanimation Dryer Expert? Answer questions, earn points and help others
