Question about Welding Tools
I have a dayton model 3z744. got it at garage sale .no ground on it. were do i hook a ground to it inside?
  • 2,510 Answers
An arc welder is a very simple transformer, Inside it you will find there are two sets of windings, a lighter one and a very heavy one, the lighter one is the primary which works off your home mains and the heavy winding is the secondary that supplies your welding current. The secondary winding has several taps for different currents - these go to the connection for the 'torch' the end of the winding is the ground tap and would usually appear to come from the bottom or the beginning of the secondary coil.
Hope this makes sense to you. If not, come back to me and we can try work it out.
Posted on Mar 16, 2011
How do I hook up the exhaust on a Dayton Gas Garage heater?
Well you have to buy reducer to get it down to 2 inches. Are you sure it's 2 inches or 3 .
Maybe this is a high efficiency heater so design to use a 2 inches pvc pipe
Dec 19, 2017 | Dayton Gas Furnace Heater
I have installed a Dayton G73 heater in my garage along with a 240V outlet. I am using a 3 prong dryer cord and I am having difficulty figuring out which wire to hook to L1 and L2. I have determined the...
here's a link to the install guide
www.air-n-water.com/manuals/G73.pdf
http://en.allexperts.com/q/Electrical-Wiring-Home-1734/Installation-Dayton-G73-Garage.htm
Nov 02, 2009 | Heating & Cooling
Need wiring info on DAYTON 3E342A. All info needed .
if you will google the make and model number you should find a pdf owners/ service manual
Dec 17, 2008 | Dayton Electric Heater
Hooking up my heater
The white is the common neutral, it is probably a 3 wire unit, and you are missing the ground wire. Check inside the control panel and see if someone wired it using the white wire for the ground, it will be screwed into a terminal lug. Check the schematics to see if the unit requires a common neutral to run the controls.
Nov 24, 2008 | Dayton G73 Utility Heater
Installing a Dayton G73
How many amps is your service? And what gauge wire did you use for the heater?
If your service is only 40amps that is your problem. You don't have enough amps for the heater and the rest of your house, you will have to upgrade your service.
Nov 02, 2008 | Dayton G73 Utility Heater
Lot of the wires came off the on the back of the Heater
We have a Dayton Unit Heater in the garage, gas. the wiring is a mess do you have schematics?
Sep 23, 2008 | Dayton (3E386) Heater
Dayton G73 wire hook up with 10/3 NM-B wire
Red wire is not needed. Be certain 208 volts is read across black and white. Cap off the red.
Jul 04, 2008 | Dayton Electric Heater
Welding Tools Logo
179 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
