Question about Viking VDSC307-4B Dual Fuel (Electric and Gas) Kitchen Range
There's a small tension spring that became unattached in the oven door. How do you take the door off to get at the hinge area.
  • 47 Answers
Paper towel in the hinge area on the door bypasses the finger clasp and the door comes off. Get a model and serial and call your local Viking distribution for parts
Posted on Nov 26, 2014
  • Viking Master
  • 8,220 Answers
Viking stove Manual page 38 is not very clear. Viking parts and service online
Posted on Mar 16, 2011
The door spring came off of hamilton beach 31100
The door of the Hamilton Beach Model 03008 or similar toaster oven does not stay closed when the door return spring or the hook it connects to breaks. The repair is very simple and takes just a few minutes!
The door spring is about 1 inch long and connects to a small clip on the inside of the left side panel of the unit. To see the small clip and the door spring, you simply remove the left side panel of the toaster oven which is done by removing just one screw.
The mounting clip on the side panel for the door return spring is located about half way up the side panel near its front edge.
The other end of the spring (its bottom end) connects to a metal hook. If the spring is not connected on its bottom end then the wire hook is broken. This is a simple repair that only requires a few inches of metal wire.
The other end of the metal hook (its bottom end) is connected to the bottom of the door hinge where it inserts into a small hole in the left side mounting hinge of the door.
When the steel hook breaks on either end then the spring cannot function, so the door does not stay closed.
To fix this problem, you simply get a piece of steel wire that is about 1/16 inch thick and a few inches long.
Bend the wire to make a hook at one end that the spring will connect to.
Then insert the other end of the wire into the small hole on the left side mounting hinge of the door. Then bend the wire on the inside of the hole to make a U or hook so the wire stays mounted in the hole of the door hinge.
Then adjust the position of the bend on the other end of the metal wire so the spring will have good tension when it is attached to the hook and to the clip on the side panel.
To do this you make the U shaped bend on this end of the wire to be about 1/2 inch from the end of the open end of the spring when the top end of the spring is attached to the mounting clip on the side panel.
To attach the spring to the wire hook, first remove the spring from the mounting clip. Then hook the spring onto the hook (bend) you made at the top end of the wire, then just stretch the spring to connect it to the mounting clip. The door will now stay closed.
Nov 10, 2013 | Hamilton Beach 31197 120 Watts Toaster...
I own A Euromaid oven, model 1505 TI Turbomaster. The interior glass has become unattached to the seal that holds it to the metal of the interior door. I want to remove the door from the oven so I can take...
On page 20 of the manual it tells you how to remove the door. The link for the manual is: http://www.euromaid.com.au/site_folders/125/docs/ABCDEF/1505TISSBMSS7_manual.pdf
Dec 14, 2010 | Ovens
How to increase Dacor oven door spring tension
The hinge is most likely out of adjustment as the tension should not have to be much to hold the door closed. The pivot point and the attachment to the door must be correct however.
The hinges usually have a hole exposed when you open the door to put a nail in so the hinges will be held open to work on them.
Feb 08, 2010 | Kitchen Ranges
Oven door won't stay tightly shut
Oven door hinges are not adjustable, assuming you have fitted the door back correctly, and it is still not closing properly, then the only solution is to replace the door hinges.
Jan 20, 2010 | Whirlpool RBS275PD Electric Single Oven
How do I release the tension on a spring loaded hinge?
If there is a cylinder on top of the hinge with small radial holes in it, you need to find a way to twist that cylinder. A special spanner wrench serves this purpose, but you can probably get away with using locking pliers (Visegrips). You will be twisting the cylinder in the direction that INCREASES the tension, so just turn it a littlle bit. That takes the tension off the door hinge (putting it on you instead). Be very careful that the spring doesn't snap free and injure you. There should be a way to then allow part of the spring to retire one rotation in the direction that would reduce the tension.
Dec 05, 2009 | Hardware & Accessories
My oven door does not close tight
These hinges are now obsolete and you cannot get them anywhere. The poblem with this type of hinge is not with weak springs or anything like that, it is with the pivot pin in the door hinge. Follow these instructions and it will not cost you anything for the repair.
It is best to remove the oven from the housing. Remove both sides of the oven panels, you have to remove the top first, then the sides (remove about 20 screws all together). Support the bottom oven door first by tying a bit of string between the bottom and top oven door hand rails. This will stop the door falling down when you remove the springs. unhook the springs and the door will just slide out. (Use a loop of string attached to the back end of the spring to pull it from its holes.)
Dismantle the door by removing the screws. You will probably find that the the hinge pivot pins have come away from the U shaped hinge bracket. The secret is to make sure that these are fixed firm back into the bracket. What I did was to nip the U hinge bracket in a vice, (or use pliers) so that the pin will now protude slightly each side of the bracket. This allows more surface bearing area so the pin will not pull itself out of the hinge. To further make sure, I glued the ends of the pin with epoxy resin.
Then reassemble.
My door now feels like a new one even though it is 15 years old.
Sep 16, 2009 | Stoves 720EF Electric Double Oven
Door won't latch/microwave won't turn on
The door does come apart. Open the door and where the hinges are, there are openings where the hinges enter the door, this plastic piece (goes all the way around the door) With a small flat blade screws driver VERY carefully pry it (plastic) off, once off, check the latch end for the spring, typical failure for a Sharp is the little tab that the spring hooks to on the door, the only way to repair this so it will last is to replace the door frame. they are not too expensive, about $50 or so Part# FCOVB166KIT
is the door frame assy
Jan 07, 2009 | Sharp R-1405 / R-140 Microwave Oven
Whirlpool oven
You have to get the tension off of the hinge and it will drop right in. The spring loaded arm on the door needs to be drawn back until you can (depending on the style) either lock the u-arm into the notch on the other side of the hinge, or put a small bolt through the aligning holes in the side of the hinge. Once you get the arm straightened out a bit and relieve the spring pressure, you should be able to sit it right in there. Be careful though, that spring is strong
Oct 25, 2008 | Whirlpool RBS245PDS Electric Single Oven
2002 Thermador Gas Oven door - can't get back on after removal!
You have to get the tension off of the hinge and it will drop right in. The spring loaded arm on the door needs to be drawn back until you can (depending on the style) either lock the u-arm into the notch on the other side of the hinge, or put a small bolt through the aligning holes in the side of the hinge. Once you get the arm straightened out a bit and relieve the spring pressure, you should be able to sit it right in there. Be careful though, that spring is strong.
Oct 25, 2008 | Thermador PGR366 Gas Kitchen Range
Dacor Gas wall oven
is there tension on the door at the point where it doesnt seal,is the spring broken/missing,when the door opens and closes is there enough travel from point a to point b inside the cabinet on both sides of the hinge area, is the sping loaded mechanism damaged .
Dec 30, 2007 | Ovens
Open Questions:
Viking VDSC307-4B Dual Fuel (Electric and Gas) Kitchen Range Logo
503 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
paulcarew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
