Recording device/sound card
I have recording software but error message says there is no recording device on my laptop. I can "rip" cd info but not "record" in real time. What do I need?
  • 1 more comment
  • Anonymous Aug 23, 2008
    trying to get on skype and says no recording device
  • aidenjay Sep 10, 2008
    it says no recording device why
  • Anonymous Mar 17, 2014
    How to erase my voice in the cd recorder and to record and a new audio voice
  • 56 Answers
Update the firmware of your dvd drive or try reinstalling the device driver for your sound card.
Posted on Sep 17, 2008
Copied CD will track recording but no sound
When the CD was copied, a copy protection mechanism may have stopped the audio from being recorded. Essentially, playback of the original is normal, but software prevents recording by sending only silence, for the duration of the track, to the recording device.
Windows Vista, or newer, does this if you try to record from a streaming service (Rhapsody, Spotify, etc.) or directly from audio being played from a file.
If this isn't the case, try ripping the CD with a different program and re-burning it.
I don't know how it was copied (or ripped), so I can't give you a definitive answer.
Apr 23, 2016 | Audio Players & Recorders
Sound card not working after XP install
Does the icon come up in the tray if so check
to see if it is not muted
Go into device manager/propersties and see if
it lists any problem,if it says everything is working
properly remove it and let it check for changes in
device manger when it reisstalls see if that works
Dec 03, 2007 | Toshiba Satellite A105 Notebook
Why do i get format error when i put songs from a cd on the eclipse?
1. Why do i get format error when i put songs from a cd on the eclipse?
= This is probably because the format that your songs are currently in is not supported by your device. Supported devices on the Mach Speed Eclipse 180 MP3 player are: mp3, wav, and wma. If your music is for example filename.cda, it won't be able to play because of the file format being .cda.
2. I also see the song on the eclipse but it says drm protected and will not play the song.
= When ripping your music, check your ripping options in whichever ripping software you are using that protecting music files is off, this may be the reason why your music cannot play - it may be protected to only play on the computer that ripped(recorded or duplicated) the song.
Sep 17, 2012 | Mach Speed Eclipse 180 MP3 Player
No sound at all
1) Go to: Start > Settings > Control Panel > Sounds, Speech, and Audio Devices > Audio tab 2) Check what's under "Sound playback: Default device" and "Sound recording: Default device". It these fields are grey and non-clickable, then most probably the audio card driver is missing or less probably the audio card itself is broken. 3A) If you have an original CD of your computer, motherboard, or audio card, insert the CD and install the driver from it. 3B) Or alternatively insert the CD and go to: Start > Settings > Control Panel > Performance and Maintenance > System > Hardware > Device Manager, find any unidentified device in the list, or expand the "Sound, video and game controllers" branch, identify the Audio card > Right click > Update driver... > Install the software automatically > Next 3C) Or alternatively download and install a free driver updater software, e.g. http://www.innovative-sol.com/drivermax/index.htm - let it scan and update all your missing drivers. P.S. These steps mentioned above are for Windows XP, but will be quite similar on other Windows versions, too.
If you tell me your laptop's model name, I could find its website where you can download audio drivers. For example if you have HP laptop, go to www.hp.com and enter your laptop's model number and look for driver downloads offered.
Mar 07, 2011 | Computers & Internet
Code 19- philips cdrw/cvd scb5265 ata device how do i fix it
Do you receive the following error message?
Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. To fix this problem you can first try running a Troubleshooting Wizard. If that does not work, you should uninstall and then reinstall the hardware device. (Code 19)
Code 19 is a common error message, your computer sends because NERO, Roxio, and similar CD/DVD recording software and also and update for Windows VISTA (KB938194) is causing issues. It can create problems with your sound as well.
Even if you uninstall these it will not resolve the issue, because these programs leave the problem inside your registry.
What is happening to your computer?
Device Manager sees the drive, but you get the yellow exclamation mark and it indicates "Your registry might be corrupted. (Code 19)"
How most people try to fix this error – and you are probably doing the same - without any luck…
If you try to uninstall the device and the driver and read new hardware - no change.
You can try to update the driver and the wizard will say there is no better driver found for the hardware.
You can try to run the install CD (copied it to a flash card and ran it from a flash card reader since you can't run it on the DVD drive) - same problem will occur.
You can't do a repair install of Windows since it is on CD and it won't boot properly from the drive.
You can try to use an external DVD writer (HP dc5000) through the USB port and it will get the same code19 error.
Even if you try manually copy the drivers listed in driver details for the device - no luck
Jun 14, 2010 | Samsung Philips CD-RW Kit 4x4x32 ( CDRW...
"unable to open audio recording device. Device may not support..
sorry its a software every time when you recieved a fetal error its came from software's corrupted dll file
Aug 30, 2009 | Edirol UA-4FX External Sound System
Sound drivers or sound card not working
in control panel go to sound and audio devices. in this you can test all the audio hardware and mic also.
under voice tab there is also an option for test hardware.
you said that you cannot use the mic in skype or google talk. i think that you didn't configure the mic properties in those software.
just go to start->all programs->accessories->entertainment->sound recording. just record ur voice using mic. if it works then the problem is with the configuration of the software skype and gtalk
hope this helps.
Apr 19, 2009 | Computers & Internet
Media device not found
download and run the belarc advisor from
http://www.belarc.com/free_download.html
write down the sound card info and go to the device manufacturer website to update the drivers.
Nov 27, 2008 | Compaq Presario 700 470024-192 Notebook
Unable to rip music with Windows Media Player 11 and Creative Labs CD5223E
I had this CD Rom drive in my older PC (200 MHz). I was able to rip audio CD's to MP3 with no problem. I used the program Cool Edit Pro. I would look to see if it's a setting with your sound card. Check to see if there are any settings that select the recording source. There has to be a path set up to record from the CD rom. With cables, you might also try taking the audio out from the sound card and feeding that into the audio in port on the sound card.
Jan 18, 2008 | Creative Labs (CD5233E) Internal 52x...
Sound device
my laptop sound is not working, its a sahara laptop, it keep on showing error messages everytime a try to play a cd
Oct 16, 2007 | Computers & Internet
Computers & Internet Logo
141 people viewed this question
David Payne
David Payne
