Question about Raymarine Autopilot ST7002 Display Head ()
I've got a raymarine 7000 autopilot, the previous owner says the linear drive works but the head unit does not communicate with it. I will be at the boat at the end of March and I would like to know what to try to test.
2 Suggested Answers
  • 64 Answers
SOURCE: Clutch failure of Raymarine M81130 linear drive
Try putting 12 vdc directly to the clutch circuit. You should hear the clutch engage. If this is operating properly, then the course computer circuit has failed. If this is not working then the linear drive needs to be rebuilt.
Posted on Jun 14, 2010
How to repair St40 autopilot. Works intermittently.
The autopilot draws a good amount of current. make sure that all connections are good and tight starting with the connection at the fuse or breaker all the way through to the unit. make sure the connection at the autopilot is clean and tight. If the problem persists, it may be internal to the unit.
Aug 24, 2014 | Raymarine St4000mk2 Marine Autopilot Wheel...
I have a Raymarine Autopilot with a control unit ST7002. The display has almost burned and it is hard to see. The control unit has been discontinued and it is hard and expensive to find. Can I change it...
You can probably find another control head on eBay... the ST6002 should also work, though it's smaller. The ST8002 is the same size but adds a knob meant for powerboats, but should also work. All three models are SeaTalk, which is what you need. The ST70 is also SeaTalk in addition to N2K, so I'd expect it to work.
Dec 20, 2017 | Raymarine St8002 Smartpilot Autopilot...
Just interested on ''how'' the Autohelm ST1000 Plus works! is there somewhere on the net that I can check, I just bought a boat with one one it and I know how to make it work, but I want to...
Hi!
The ST1000+ does not have an internal GPS. What it does have is an electronic compass underneath the keypad. When you order the Tillerpilot to steer to a bearing, the unit uses the electronic compass to steer using a series of corrections.
Just in case you've misplaced your Owners Manual, you can use this link to download it to your computer: http://www.raymarine.com/productdocumentfinder.aspx
Click on your language preference, then Autopilots from the drop-down menu, tillerpilots and finally ST 1000+. The pdf file for your unit is 81130_6.pdf
Hope this helps and happy boating!
Jun 14, 2011 | Raymarine St1000 Plus Tiller Pilot
Apr 29, 2010 | Raymarine Type I Linear Drive M81130
Boat on screen does not point the direction the boat is going e-80 series also chart will not go course up or heading up like the radar does unit is set in relative motion mode
The direction of the boat symbol is depending on the compass course from the autopilot. You will see that your GPS course (COG) and magnetig heading on the autopilot differs. Solution is to calibrate autopilot compass. Will advice you to not use course up, stick to north up or heading up.
Sep 08, 2009 | Raymarine C80 GPS Receiver
Problems talking to autopilot
I think you use the NMEA output to the autopilot .
The plotter shows you only when you have a seatalkconection with a Raymarine autopilot on you Plotter
Apr 06, 2009 | Raymarine E120 Multifunction GPS Receiver
St6000
The linear drive should have an adjustment screw on the arm so that it can be adjusted to show when the rudders are central. you will need to centre upm the rudders then loosen the screw and adjust until the guage shows the centre position. May take some fiddling to get right cause sometimes when you centre it the guage won't read correctly in the port or starbord directions (won't go all the way over). May need to re-position the whole unit.
Sep 02, 2008 | Raymarine Smartpilot Autopilot St6002 S1g...
Raymarine C 80 Head up problem
I calibrated my autopilot compass and that resolved the problem. My auto pilot compass was about 100 deg out.
Once i did this the problem was resolved.
Aug 26, 2008 | Raymarine C80 GPS Receiver
Raymarine Autopilot ST7002 Display Head () Logo
65 people viewed this question
Top Raymarine Boating Experts
Steve
Steve
David Burbee
David Burbee
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
