Question about Toshiba Televison & Video
Power light flashes... Tz61v61 - Toshiba Televison & Video
    Problem Solver:
  • 10 Answers
Power board needs replaced
Posted on Mar 16, 2011
Toshiba Flat Screen TV Model TZ61V61 Serial #23960912 problem with wiggles and shadows in the corners
Could be video card or screen its self. Does it start out with distortion as soon as tv is turned on or does it distort as it warms up?
Mar 01, 2015 | Toshiba Televison & Video
Tv will not turn on and there is a red flashing light
Power supply problem.Maybe deffective regulator transistor.Need for repair and troubleshoot and replace deffective parts.
Jul 09, 2011 | Toshiba TZ61V61 61" Rear Projection...
My TZ61V61 rear projection 60 inch television turns off randomly. The red light by the on/off switch blinks. Sometimes the TV will still work though.
The blinking red light is telling you the code. Watch how many times it blinks. when it pauses for a seccond, watch again. Write down the number of times between each pause. Then repost with that info and I might be able to figure out what is wrong. Hopefully before it is permanent.
Jun 11, 2011 | Toshiba TZ61V61 61" Rear Projection...
I have a tz61v61 toshiba rear projection. The bottom half of the screeen is ghosting red, blue and green. it looks like 3d without the glasses. top half of screen is fine.
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Feb 24, 2011 | Toshiba TZ61V61 61" Rear Projection...
WHY DOES MY TOSHIBA TZ61V61 loose picture but not sound. Unplug from power wait a few minutes plug it back in and it works
The vertical deflection has stopped which cuts off the picture tubes to prevent burn in. Check the vertical output or the deflection board may need replacement.
Aug 08, 2010 | Toshiba TZ61V61 61" Rear Projection...
My theaterview tz61v61 has no sound or video i checked the fuses on the on board circuit and, with the ones i could see, seem to be fine i have little knowledge of tv ciruits and tv troubleshooting. ...
U get all solid LED lights indication front of bazel panel of the tv?U got power LED light flashes or no LED light at all?Check for DM power supply board,for dying leakage bulges up capacitors on it tops or puffing up on it tops.Replaced dying capacitors."LAMP"LED light indication on stay on or flashes.The projection lamp is dead,require changing,also hear alot of clickings too.Mean the the board call the Ballast board is also dead,require changing too.This Ballast board help to ignite the projection lamp.
Aug 05, 2010 | Toshiba TZ61V61 61" Rear Projection...
My tz61v61 red and blues are out of line
It is the convergence chips in the tv. They can be replaced at a repair shop or by any one with experience in soldering. You can find them online
Jun 28, 2010 | Toshiba TZ61V61 61" Rear Projection...
Red convergence is not lining up with blue wat those that mean
go into menu and adjust convergence. if red moves, it just needs adjusting from your remote. if it doesnt move or is bent then you have a bad convergence ic. possible fuse. suggest local service center. sorry
Nov 10, 2009 | Toshiba TZ61V61 61" Rear Projection...
Tz61v61 toshiba 61 rptv theaterview
If the relay clicks you most likely have a leaky diode or bad transistor in the stand by or start up circuit. There is a manual available for that model called. Toshiba Power Supply and Shutdown circuit Troubleshooter. Its available at the following link. It gives step by step instructions so you can figure out exactly whats wrong with your set. The site emails it too you after you place your order and they also provide free unlimited tech support so you will have a resource for help if you need it. I am one of their on line support techs. I highly reccomend that Manual to any one with a toshiba that will not power up. Here is the link.
http://servicemanuals.vstore.ca/
Apr 12, 2008 | Toshiba TZ61V61 61" Rear Projection...
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
