Question about Dell Dimension 2400 PC Desktop
I have a Dell Dimension 2400. It will power up but nothing will display on the monitor. monitor says it is still in sleep mode. The green power light is on and also the other green light flashes along with the light on the disc drive. I have tried shutting down and starting back up. Same thing. Any suggestions?
  • 961 Answers
Http://support.dell.com/support/topics/global.aspx/support/my_systems_info/manuals?c=us&cs=19&l=en&s=dhs&SystemID=DIM_PNT_P4_CEL_2400
This a link to get an owners manual from Dell for your system, if you don't already have one. There should be a toubleshooting section as well as sugesstions on how to get out of modes. Ifyou need help with this, let me knowin "add comment' at end of solution.
Posted on Mar 16, 2011
  • 1 more comment
  • randylesan Mar 16, 2011
    Thank you for your response. I have read the troubleshooting section of the manual. In the section that talks about the diagnostic lights on the back of the computer it gives different light configurations for different problems. The light configuration that I have is not covered in the manual. LED A flashes green, yellow, green, yellow constantly. LED B Is yellow. LED C is green and LED D is green. All four lights blink on and off. Any help?
  • David Petry Mar 16, 2011
    I glanced at what your talking about whnI pulledup the manual but, I'l have to look again In my manual (530) there was a trouble shoting section and start up's.
    First, for giggles, i would shut down computer, unplug(30 secs) , plug back in, then, restart. If nothing happens then, I would try the 'memory test". Memory or "ram" , or memory sticks as they are called clip into your moherboard. If you don't know what or where they go, they are in the manual. Hopefully you have more than 1 stick. You pul all out and replace one, then restart, If it works it's probably one of the other sticks which you check the same way.
    Dave
Dell monitor flashing green power button black screen.
Your computer is in sleep mode, a low power mode that conserves power by turning off the screen and hard drive.
Push the power button on the system and the computer will resume.
If you don't like this feature, you can turn off sleep mode in the power options in Control Panel
Jul 26, 2011 | Dell Dimension 2400 PC Desktop
I have a dell dimension 4600 computer. I usually put the computer in sleep mode when I am not using it. Usually I press the ESC button and the computer wakes up. All of a sudden, the monitor won't...
Plug the monitor into another computer to determine if the monitor is damaged or working properly. You can also plug another monitor into your computer to determine the same thing.
May 21, 2011 | Dell Dimension 4600 PC Desktop
Monitor power light on but nothing else
Disconnect the video cable from the computer and power on the monitor. If you see the color bars floating on the display then the monitor is functioning. Your computer has a problem.
Jan 09, 2011 | Dell Dimension 2400 PC Desktop
I have a Dell 2400 it starts up fine but after about ten minutes the light turns from green to yellow and I lose any picture it reminds me of a sleep or hibernation mode but I know it does not have that....
Is this light on the computer, or on the monitor?
I suspect that it happens when you try to watch a movie or listen to music - something that doesn't involve typing on the keyboard or using the mouse? If so, then your computer goes to suspend mode. You have to open the Control Panel, Power settings, and select an "Always on" power scheme, and additionally change the "monitor off" option to Never. Then click "Apply", close the window and you should be fine.
Jul 10, 2010 | Dell Dimension 2400 PC Desktop
I am working with Dimension 2400 with monitor 773c blank or no display, drivers load after safeboot, but I am not sure what to do from there, nothing happens when I push enter, but the monitor works with a...
Refresh Rate, the reason why it works in safe mode and not normal mode is because in safe mode the system only loads the most basic and reliable drivers and sets the screen resolution and rate to their default values. In safe mode right-click on the desktop and go to properties, go over to the tab Settings and click Advanced. You should see another tab that says Monitor, there you can change your Hz, change it to something like 60hz to be on the safe side.
Jan 27, 2010 | Dell Dimension 2400 PC Desktop
Monitor keep going into "sleep" mode
Check the power setting in control panel of windows. If you have a monitor from another computer swap them and see if the problem stays with the computer or monitor.
May 12, 2009 | Dell Dimension 3100 PC Desktop
Monitor rejects computer
I'm just guessing, but it could be that the resolution you are using on your MS-DOS monitor is not compliant with the new monitor you are trying to use. Check the supported resolutions of the monitor that you would like to use, and then make sure you set that resolution before switching monitors.
May 10, 2009 | Computers & Internet
Monitor displays slowly after the computer starts.
try to turn off you screen saver just turn off power monitor to see monitor easy wake up after long time.if ok means windows screen saver have problem if still same look like is you monitor something wrong need to check
Jan 03, 2009 | Dell Dimension 2400 PC Desktop
Memory detected/Memory failure on Dell Dimension PC
So basically the computer does not start. Because I am not sure that is what you are saying.
I think from my understanding it is an issue with vista rather than with the computer. Somehow the new driver has put your computer in sleep mode. The computer of friend of mine starts by itself.
Another I want to say that the memory cards are fragile they can go bad. The way you touch them it is important.
Feb 01, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
88 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
