Question about Admiral Washing Machines
Hello My washer filled up with water and quit.. Is there a reset button?
  • 1,998 Answers
If the washer just filled up with water and stopped most likely it is the lid switch that has went bad try to see if the washer lid switch still makes a clicking sound if not replace the lid switch the switch is actually what actuates the motor to start to agitate if there is no presence of the two points connecting it does not start the cycle another way as a temporary repair till you get a new switch is to take a jumper wire and connect between the plug position 1 and position 3 this causes the switch to be by passed so that you may finish you clothes if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
Posted on Mar 16, 2011
Hot water keeps filling tub and does not quit
the washing machine is designed with a timer limit switch have the switch checked.
Oct 19, 2012 | Samsung WF448AAW 4.5 cu. ft. Front Load...
Bought in 2006 and quit working all together in 2007 then pulled it out today and the thing started working until the end of the wash cycle and wont come on at all again... it drained well but at the
Hello Kimberley,
It appears that a part of your question is cut off so i may be off base here but what i am reading is that your washer will go through the wash cycle and drain the wash water then just quit?? is that what is happeningIf yes that is whats going on i think what is happening is that after the wash cycle it fills with only COLD WATER for the rinse cycle and its not filling with the rinse water and just sits their until the rinse cycle water is filled and if its not getting cold water into the washer its not going to do anything If it is filling with cold water my apologies my bad for misinterpreting what the question reads and i ask ya to re-ask it.
GENE
Nov 03, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Whirlpool calupso FL (over fill) flashes....The manual says the washer will beep every 10 seconds and the pump will cycle one half minute on, one half minute off until the over fill switch is reset or the...
Hello & Welcome to FixYa
FL error indicates flood condition and is caused due to any overfill condition that occurs inside the washer. To clear the display you can press and hold the STOP/CANCEL button. Usually this error is caused when overfill switch trips due to excessive water in the tub. You can also try to clean the drain hose and check the water inlet valve. Please get back to me if you have any other questions.
Kevin
Oct 08, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My Kenmore washer would not stop filling with water. i checked and the pressure sensor hose was of the switch, i rehooked it, but it still does not stop filling with water. do i need to do something...
Hello.
Kenmore washer come in a variety of s and styles,including extra-large dishwashers and dishwashers that are accessible for thedisabled.
A Kenmore washer automatically resets itself every time a washingcycle completes.
If you want to reset an Kenmore washer in the middle of acycle, you can easily do so. Resetting a Kenmore washer takes only a fewseconds to complete.Instructions.
1 Press the"Start/Stop" button.
2 Hold the buttonfor three seconds and release.
3 Select the program and options on the frontpanel you want the dishwasher to use. Press "Start/Stop" to restartthe dishwasher. You have now reset a Kenmore washer Thanks.
Jul 30, 2011 | Kenmore Washing Machines
Washer quit working in rinse cycle before spin cycle tub full water does nothing but fill with more water when you increase water level
99% of the time the lid switch is what causes this issue, below are two links one where you can get the lid switch and the other explains how to take the washer apart to test and access the washers lid switch.
Cheap Appliance Parts Click Here
Good luck with your repair!
How To Take Kenmore Washer Apart Click Here
Mar 05, 2011 | Kenmore 26882 Top Load Washer
Maytag Performa wont fill hot water
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Nov 27, 2009 | Maytag Performa PAV2200
My whirlpool front load washing machine accept hot water and no cold water entering on the machine.
Apr 01, 2009 | Whirlpool GHW9400 Front Load Washer
I have the washer on cold water, but it runs warm, stops, trickles, then comes out warm again, stops, trickles, then warm again ect.On the rinse cycle it will only trickle out.
Mar 03, 2009 | Washing Machines
My GWL11 won't fill correctly or wash!
Hi there you need a new cold valve in the washing machine. :)
Sep 17, 2008 | Fisher and Paykel GWL11 Top Load Washer
My FWT645RHSO front load washer does not fill with enough water.
Hello Twisted1,
If you have adjusted the level to reset and then to where you want it and it still won't fill to the level you want, I would suspect the level sensor in the washer itself. Most washers have to be switched to reset before setting a lower or higher water level. I hope it's as simple as the reset level switch for you.
Good Luck.
Feb 28, 2008 | Washing Machines
Washing Machines Logo
151 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
