Question about Acer NSK8458AN Keyboard
Can't get the question mark back - Acer NSK8458AN Keyboard
  • 5 Answers
You probably mean that instead of typing ?, you you're ?. Am I right? (oops, there see I did it) I mean am I right?.
The solution is really simple: Just HOLD CTRL and PRESS SHIFT (once and firmly)!!! If it doesn`t work the first time then just try it again until it does because it sometimes takes a couple times for your computer to respond. This trick works with all PCs.
If you (for some strange reason you want to type ? again just do the same technique.
Note: it also changes " to `` and / to ?
and it makes al ot of weird things happen such as making SHIFT + 2 type " instead of @ (weird I know). Basically this trick I taught you changes your keyboard's language from French to English.
If nothing I've told you works even after multiple attempts, then you need to... START > CONTROL PANEL > on the main menu look under Clock, Language, and Region and CLICK "Change Keyboards and Other Input Methods" > CHANGA KEYBOARDS and from there you can click on English (Canada or US).
Hope this helps,
Awan11
Apprentice
Posted on Mar 28, 2011
  • awan11 Mar 28, 2011
    Sorry, I'm the one who posted the first comment and before I posted I had most the question marks as capital french E's which is what my above solution changes the "?" to, but somehow they all changed back when I posted :(
    Good news the trick still works fine!
2001 toyota camry valve timing instruction
With a loose tensioner...There are timing marks on the crank. Line it up, run your belt up and around cam pulley which will also have timing marks. If it is duel cam marks will line up with each other. Keep all the slack of the belt pulled to the side of the tensioner. Release the tensioner and confirm marks. Turn motor through a revolution by hand and reconfirm marks are lined back up. Put it all back together.
Feb 27, 2015 | 2001 Toyota Camry
On a 1999 Isuzu Rodeo 3.2 V6 DOHC If you put all timing marks together on engine and then put timing belt mark all together on the engine and rotate two rounds with crankshaft does all the marks come
Just the engine. The marks on the belt are to make sure the teeth are in the right place when replacing. It might come back in place on 4 turns of the crankshaft. I have never checked to see if the belt marks came back. But always check the timing marks themselves.
Hope this helps.
Nov 10, 2014 | 1999 Isuzu Rodeo
Toyota timing marks
One mark is on cam gear mark on head line it hole in gear
camshaft intake and exhaust valve rocking that. Tic then on the back of two cam gears have to ,match up turn and match two sets of marks then back to tic them crank gear
one is straight up replace belt I would change water pump and seals also? good luck
Aug 12, 2014 | 1998 Toyota Camry
Cam sprocket moved backward and wont turn fordward.
Sometime the valve it the piston, back up the crankshaft set the camshaft mark and replace the crankshaft on the mark
Apr 21, 2014 | 2002 Saturn Ls 4dr Sedan
How to remove the timeing chian
22R 4 cyl.Get # 1 piston to TDC(stick the harmonic balancer back on temporary)setting the mark to O on the timing tab,pull the balancer back off and slip the chain on the crank gear after finding the single dot on the chain.Set the mark on the cam gear at very top and put the chain mark on that mark on the cam gear.Stick the cam gear back on the cam and bolt it back on.Your set now.
Apr 11, 2014 | Toyota Hilux Cars & Trucks
I want the proper timing marks and how i set the timing for a 4x4 wth twincam.its starting but not runing smoothly and misfireing.would you help me wth a diagram on where the marks should go.
ON THE CAMS THERE IS A MARK ABOVE AN I FOR INTAKE AND AN E FOR EXHAUST LINE UP THE I UPWARD TOWARD THE MARK ON THE BACK OF VALVE COVER AND LINE THE E ON THE EXHAUST SIDE MARK WITH THE MARK ON THE VALVE COVER AS FOR THE CRANK THERE IS AN MARK ON THE BACK OF THE SPROCKET WHICH WILL LINE UP WITH THE A MARK ON THE BACK OF THE COVER GOOD LUCK
Jan 14, 2011 | Kia Sorento Cars & Trucks
How to remove distributor on a 1998 gmc pick up with 5.0 engine, do I have to mark anything or just take off bolt and pull out.
You need to mark in 2 places. With the cap off mark the position of the rotor button on the distributor housing first. Then you need to make a mark on the distributor housing that will line up with a mark on the engine itself.
When you put the distributor back in back the rotor button up before you put it in because the cam gear will turn it ahead as it seats. For example, if the rotor button is at 3 o'clock then back it up to 1 o;clock.
Don't force the distributor down at the end because you can damage the end that drives the oil pump. Fidle and wiggle it as you push and it should line up and drop onto the oil pump. Also DON'T turn the engine over while it's out or you will have to retime the engine. Hope this helps.
Jul 03, 2010 | 1998 GMC Sierra
Replacing a timming belt where are the marks suspost to line up
You didn't get the timing marks lined up between the cam and the valves. You are going to have to open it back up and line the marks back up correctly. Make sure you get the Number 1 cylinder lined up to Top Dead Center on the compression stroke and have the valves lined up correctly then line the timing marks up on the timing gears.
Jun 24, 2010 | 1992 Mitsubishi 3000GT
Timing OK?
You did it the right way. If you tried to make a full cam revolution you would have hit the pistons with the valves. Put the lower timing cover and crank pulley back on. If the cam marks are aligned right and the mark on the lower timing cover lines up with the mark on the crank pulley, you're good to go.
Mar 12, 2010 | 1999 Audi A4
Need timing marks and ignition wiring digram on 2.0 dohc 99 Kia sportage
I can help with your timing marks.
the bottom pulley on your timing belt has a **** grove on the back part of the pulley on the seal plate behind pulley should be a mark or a triangle align those two marks
for the camshaft pulleys there should be an "l" marking on the left pulley for intake and an "E" marking for the right for exhaust side allingn each marking to the grove just above the pulleys on the seal plate directly behind the pulleys
install timing belt and make sure it isnt loose on tension side which is the right side of belt if reusing old belt make sure you have marked belt on which way belt is turning
loosen tensioner lock bolt turn crankshaft two complete revolutions in direction of rotation
make sure that marks are correctly aligned still if not start back to step one.
if ok turn crankshaft to align "S" mark of right pulley or the exhaust pulley to same mark on seal plate directly behind pulley
good luck and god speed let me know how it went
Dec 08, 2009 | 1999 Kia Sportage
Acer NSK8458AN Keyboard Logo
191 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
