Soundlab sp500, Was working perfectly, one day i turned it on the fan spins so still powered, but the lights on either channel are not lit and no sound output?
3 Suggested Answers
techman
  • 3130 Answers
SOURCE: No sound from speakers
In most recivers or amps yes if there is a short in one channel all the amps go into shutdown or into the protect mode. Now if you know how an amp works then you should be able with a schematic to find out what amp is causing the over load simply by see in the schematic where the speaker output is on the curcuit and then measure for a DC B+ . Thats the amp you would disconnect to conferm that all the others were ok as an output on an amp curcuit shouldnt have more then .3 to .8 volts dc unless its unbalanced.. Seek a pro to assit you if you dont have the equipment to test the amp and for sure get a service manual or schematic diagram. Good Luck
Posted on May 16, 2006
  • 547 Answers
SOURCE: No sound from front left channel
Try swapping the connectors for front-left and front-right (just swap right at the back of the amp)
After the swap, does the front-left speaker work, and now the front-right is dead? If so, then it's a problem in the amp.
If not, then the problem is in the wiring and/or the front-left speaker itself.
Post back here with your findings, and we'll troubleshoot whichever part of the system is broken.
Posted on Apr 08, 2010
Okay so first off I have ALOT of important docs and what not on my laptop so it is a must that I require these items ! okay So I just got back from Denver and had used my laptop only once and it worked...
Sounds like a graphic card problem. You should be able to remove your hard drive and connect it to a desktop computer and access the drive and get your important files.
Aug 06, 2010 | Toshiba Satellite A215-S5837 Notebook
Philips 60pl9200D/37. Two Red lights on power button.
If the power button is displaying the bulb fault indicator AND overheat indicator lights at the same time, it indicates a faulty cooling fan. The television is smart enough to detect when either of the two cooling fans in the chassis have failed, or aren't spinning fast enough. To prevent overheating and damage, the set will not turn on if a fan is faulty. You'll need a replacement fan.
Jun 20, 2010 | Philips 60PL9200D Projection Televisions
Hp desktop power wont turn on
When you powered it on, does the power supply fan spinning? If not, then you might need to change the power supply. It may got the led light lit on, but it does not have enough power to turn on the entire computer.
Dec 21, 2009 | Cameras
Logic soundlab plx 46 red led lit in center of board what does it mean?
does it have sound if not it may be on a protect or themal mode try taking our=t your main fuse when the system is in and put it back in
Dec 17, 2009 | Logic Soundlab PLX-520 Car Audio Amplifier
My Acer Aspire 9300 laptop wont turn on......light indicators are on (motherboard light blinks once, light bulb and battery lights on) but no power to fans so no start up. have had this happen before but...
Very possible that something has short circuited on the motherboard. I would also try re-seating the memory located on the bottom of the laptop(which could be loose explaining the intermittent nature of the issue). On an IBM I once fixed that had the same issue I took out the CMOS battery and battery for one week and then re-installed and that fixed the issue. But good luck to you!
Sep 23, 2009 | Acer Aspire 5315 Notebook
Casablanca ceiling fan lights flicker out
here is solution for you.
instead of put all Fluorescent light bulb, put one incandescent bulb.
Dont' ask why but it works. (use 60w or above)
Mar 15, 2009 | Dryers
Car audio
Product Details and Features PLX-520
Key Features
Amplifier Type grayquestion.gif Dual Channel Bridgable grayquestion.gif Bridgable RMS Power at 2 Ohms 400 W x 2
Performance
Frequency Response 10 Hz - 50000 Hz Signal to Noise Ratio grayquestion.gif 102 dB THD at Rated RMS Power 0.01 %
Crossover / Equalizer
Bass Boost grayquestion.gif With Bass Boost Low - Pass Frequency 50 Hz - 120 Hz High - Pass Frequency 80 Hz - 800 Hz
Other Features
MOSFET Circuitry Yes 3 Way Ready Yes
Dimensions
Width 10.4 in. Depth 17.7 in. Height 2 in. ..This is what I found for logic soundlab PLX-520 Amplifier, hope its what you were looking for. Don't forget to rate answers.
Mar 31, 2008 | Logic Soundlab PLX-520 Car Audio Amplifier
SoundLab SP500 Amplifier
I strongly recommend that you replace all output transistors at once, and the drivers also. Also look for arcing across small low value resistors about the output stages, and small signal diodes also for 0.6 volts barrier potential voltage(they often go short circuit also). soft start the amp with a variac if you have one, or an incandescent 60watt 240v(110v if in the US) lamp in series with mains power to limit the current that can flow to protect the amps circuits if there are still faulty parts about. Check
DC conditions everywhere you can. If both channels appear to be ok, Then some careful observation of voltages with a DMM will help you to find any more problems.
Amps by design with high potentials and direct coupling ascociated with DC feedback loops, make this sort of work hard to do even for an experienced tech as it is very easy to damage the parts you have previously replaced if you do not check things well enough before firing the unit up. Softstarting with a variac or some sort of limiting in the power supply are generally the safest ways to approach this sort of repair. If you dont think you are up to it, refer the work to an experienced audio tech, or hitme back here and I can assist you if you wanna have a crack at it. Cheers. A "fixya" rating would be great for my 2 cents worth here. :)
Jan 16, 2008 | Audio Players & Recorders
35 people viewed this question
 Grubhead
Grubhead
