Question about Kenmore Dishwashers
DISHWASHER WON'T PUMP WATER OUT. ALSO THE BOTTOM ARM SEEMS LOOSE.
  • Kenmore Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Mar 18, 2011
Dishes won't get clean. I opened the door, pushed the button and re-latched the door with the door open to see if the water was spraying out of the bottom properly... it is just trickling out of the...
Your lower spray arm is probably clogged. The clog may be caused by grease or scum OR it could be from bits of debris that has not been flushed from the machine.
Generally, the lower spray arm is easily removed by unscrewing a nut or thumb screw on the top of the arm. The arm will lift off easily and you can flush it at your kitchen sink. I sometimes have to take a toothpick, a brush, and/or tweezers to remove bits of paper, bone, or peelings. You can also soak it in ammonia to cut the grease that may have built up inside it.
Then put it in place and rescrew the nut or screw.This should restore the water pressure.
I hope this helps. If it does, please come back to Fixya and rate my solution
Jul 19, 2011 | Maytag Dishwasher
Slow or no drain of water. cleaned out sump covers and ran drain cleaner thru cycle. looking for possible secondary filter.
Hi, if the water doesn't drain from your dishwasher, check the drain line and pump..
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Hope it helps...
Jun 27, 2011 | Hotpoint Dishwashers
Hi, We have Tecnik Dishwasher TKD 795/3 it wont seem to drain the water, we have tried to clear the pipes but they seem to be clear, Can you give us any tips on how to sort this problem out? Thank you
Jun 25, 2011 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Wtaer will not drain. what are things to check.
Hope it helps...
Jun 24, 2011 | Frigidaire FGHD2433KF Builtin Dishwasher
Kenmore dishwasher won't drain. Can hear motor trying to cycle but it sounds like it's locked.
Hope it helps...
Jun 23, 2011 | Dishwashers
Will not drain
Jun 23, 2011 | Thermador DW44Z Built-in Dishwasher
My kitchenaid kudv24 will not drain water out
Jun 21, 2011 | KitchenAid 24 in. KUDS25SH Built-in...
Water will not drain from bottom of dishwasher.
Possible that the drain pump/valve is faulty or is clogged. It is best to check the voltage on the pump/valve of the washer , if absent the program controller must be checked., if present with no drain then the pump/valve is clogged /failed and must be taken out to be cleaned or replaced.
May 17, 2011 | Dishwashers
Dishwasher is not draining
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Thank you !!
Jun 04, 2010 | Frigidaire 24 in. FDB750RCC Stainless...
Water comes in but does not wash the dishes no pressure
It could be a few problems, first of all does the water circulate at all, if not then you most likely have one of two problems, it is either a plugged pump, or the washer arm in the bottom of the dishwasher is plugged, first take the arm loose by turning the big nut at the bottom of it loose and take it too the sink and wash it out as best you can......reinstall the arm, try the dishwasher, if it still does not work, then you have too remove the pump under the washer and clean it out, also you should be running a dishwasher cleaner every six months..........you can purchase this at any grocery store, walmart, kmart, in the dishwasher isle...........hope this helps.
May 25, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Dishwashers Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
