Operating faip teorema..? - Computers & Internet
What will couse the pump not to build pressure
To many things to list.
i recommend giving our free tech support person ell a call when you can be at the washer and they can walk thru the process of diagnosing it.
1-888-279-9274
Oct 21, 2014 | FAIP Vertical Shaft Pump MTPV93501
Why does washer leak excessive water?
Some times the power washer are made poorly. If the leaks are at the hose connection you can replace plastic with a better one made of brass and the use of Teflon tape. Good luck
Sep 08, 2014 | FAIP Powerwasher Pw1400z 1,400 Psi 1.5 Gpm...
How to set a high pressure unloader valve on a FAIP 1500 H120 washer
Are you talking about the electric switch that shuts off the motor when the trigger is released?
If so, there is an arm that comes out of the high pressure side of the manifold and is connected to a spring loaded piston. The piston extends under high pressure (spray trigger released) and retracts when spraying. At the opposite end of the arm is an allen screw and locknut. The allen screw bears on the microswitch arm to control the electric motor. When properly adjusted, the motor should turn off when the trigger is released. If it doesn't, loosen the locknut and adjust the allen screw slightly outwards toward the switch. Pull the trigger a few times and verify the motor starts up and shuts down when you release it. Tighten locknut.
Hope that helps.
Jul 11, 2014 | FAIP 1500 PSI Electric Power Washer
How to fix 12POE-150 power washer leaking gun wand
There are no parts available for the inside of the guns. All you can do is replace the gun.
see parts in link.
http://www.ppe-pressure-washer-parts.com/12POE-150-power-washer-parts
May 01, 2014 | FAIP 1500 PSI Electric Power Washer
Faip model H120 doesn't shut off
The contacts on the microswitch have probably eroded a bit with age. The simple fix is to remove the red cover and adjust the setscrew that hits the microswitch plunger. Loosen the locknut and use an allen wrench to adjust the set screw. If you aren't sure which to adjust, power up the washer and pull the trigger while watching the motor assy. You'll see an arm moving outward when the trigger is released and in when you pull it. Follow this arm to the adjusting screw. Had the same problem with mine and had to move the screw OUT a half turn.
Hope this helps.
Apr 18, 2013 | FAIP Garden
I need a user manual for FAIP-1500 Pressure Washer
Is this the one?
http://www.power-washer.us/images/stories/manuals/H150.pdf
Oct 23, 2012 | FAIP 1500 PSI Electric Power Washer
What type of oil is used to fill the a FAIP PV93501 pump and what quanity.
I don't know about that brand of power washer.
We used several types of power washers over the years, and they each called for 20 or 30 weight non-detergent oil in the pump. SAE 20 or SAE 30
The pump oil comes about half way up inside the pump.
The engine oil is 10W30
Do not turn a power washer on its side or upside down or oil will run into carburetor.
Oct 14, 2010 | FAIP 2100psi 2gpm Faip Power Pressure...
Where can I get seal rings and o rings for my pressure washer pump without buying an entire seal kit? Faip 193490.
Alot of people have tried doing this as the genuine o-ring and seal kits are so expensive and sometimes hard to source, but many companies make orings and seals that are unique and cannot be found aftermarket,
If you are lucky you may find some but the only way of doing so would be to take the actual seal and orings down to your local bearing and seal supplier and they will measure it up and do their best to find some for you...
Regards
Brad
Dec 17, 2009 | FAIP Garden
Lance
Here is a link where you can look up your exact model and replacement parts from coleman...
http://www.ppe-pressure-washer-parts.com/coleman-powermate-pressure-washer-parts
Looks like your model may be out of production though so here's a generic kit that will 99% work with your washer...
http://www.silverbin.com/FAIP-PowerWasher-Universal-Pressure-Washer-Gutter/A/B000EEQ9KM.htm
Hope that helps...
Feb 09, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
