Question about Konica Minolta bizhub C250 All-In-One Laser Printer
The printer is not accepting the paper - Konica Minolta bizhub C250 All-In-One Laser Printer
  • 83 Answers
Check PF senser from where you want to feed
Posted on Mar 16, 2011
Printer doesn't accept the paper,power led only glow
It's onboard failure message(eeprom, rom, or microprocessor), just replace your mainboard and calibrate the machine. It solve the problem, perhaps.
Jan 19, 2012 | Epson Passbook PLQ-20 Matrix Printer
Epson Stylus R1800 refuses to accept art paper through the single sheet feeder at the rear When loading the paper the unit will pull it into the correct location and then on print command it backs the...
First check to see if there any any bits of paper stuck by checking the front and the rear feeder.
Also consult your manual to see if it accepts that thickness of paper.
It can be found here:
http://files.support.epson.com/pdf/r1800_/r1800_ug.pdf
The steps in the manual to clear a jam are on page 89 and types of accepted paper are on page 11.
Hope this helps.
Mar 20, 2011 | Epson Stylus Photo R1800 InkJet Printer
Im trying to make legal size copies
Check your owners manual to see what the acceptable paper sizes are. Legal paper is 8.5"x14". If legal paper is listed in the acceptable paper sizes there should be a tray to handfeed this size paper. Look for the term "single sheet manual bypass" in the owners manual. I beleive this tray or slot is on the left hand side of the printer.
Dec 06, 2010 | Brother MFC-7340 All-In-One Laser Printer
I have a stupid question where the heck do Iload the paper in my Lexmark X2350 printer??
Facing towards front of the printer, on the back of it you have raiser - paper support panel, with side slider on the left hand, push slider towards left in full.
Paper accepted by this printer is all standard grades, like A4, L4 and fall in these dimensions:
width min/max - 76mm to 216mm (3" to 8.5")
lenght min/max - 127mm to 432mm (5" to 17")
Printer will accept paper weight between 60g and 180g, that meant that all standard weight of paper including cardstock will be accepted, printer as well will print photo and envelopes.
• The paper is loaded against the right side of the paper support.
• The paper guide rests against the left edge of the paper.
1. Put paper long way vertical on raiser (paper support), about 80 to 100 pages of standard paper will fit there (depends on thisckness),
2. Push paper against right side
3. Adjust width with left hand slider. Do not buckle the paper!
After print paper is ejected at front bottom slot, printer side up. if you use photpaper or gloss paper, remove it immediatelly as need longer drying time and will get smudget by next printsheet.
You can find information with pictures in your manual on page 13/14.
Hope this will help you print beautiful pictures!
Aug 11, 2010 | Lexmark Z2300 InkJet Printer
We have tvs speed 40 passbok printer problem is that all light is blinking and printer dose not accept paper what is wrong with a printer
May 16, 2010 | Office Equipment & Supplies
Won't accept photo paper
Only load photo paper do not mix it with plain paper, this will happen on all printers.
May 03, 2017 | Brother MFC-260C All-In-One InkJet Printer
Paper light will not go off
You may have a small jam or a piece of paper that is still inside the printer.  You may have to look for a smaller piece of paper.  I have had this happen to my laser printers before and it was because there was a plastic arm that is inside the printer that came loose during a paper jam and it wouldn't accept paper until I reattached the arm and then the printer would accept the paper.
Feb 02, 2009 | Brother HL-2040 Laser Printer
Printer won't accept paper to print when starting to go though it just stops..
pls check the ff:
- leading edge of your paper, must be straight
- clean the feed rollers, w moistened cloth, maybe dirty thats why it is slipping
- check paper orientation, must be leveled to the tray
- did you changed any configuration under properties?? check also
we can start from this
pls mark my solutions if it does any help
Jul 30, 2008 | Canon PIXMA iP1600 Printer
What jam code are you getting. I suspect a registration clutch issue. But there should be a code associated with the jam.
I would like to look that up and narrow it down for you.
Mar 13, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
PAPERS PRBLEMS ASSOCIATED WITH LQ2180
check paper feed machanism and paper in sensor open your printer and clean the sencer
Oct 02, 2007 | Epson LQ-2180 Dot Matrix Printer
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
