Question about Electronics - Others
How to connect mitashi mh 5001 wireless headset to my computer??/
Hi-fi s xbs wireless headphone
http://somemanuals.com/M-AUDIO,MH-2001,ICJJGEC.PDF
Jun 06, 2014 | Radio Communications
Hooking my device to my computer
The headset you have is a bluetooth model. In order for you to connect this headset to your computer, you'll have to have a bluetooth connection on your computer.
If you don't have it, you'll have to purchase an adapter.
If you do, sync up the device to your computer and tell Windows to use the headset as the default speaker/microphone.
Usually, the headset won't have the capability to do this, but it just might.
Mar 05, 2011 | Logitech Traveller (980399-0403) Wireless...
When I connect the USB for headset into system it messes up my internet wireless connection. when I take USB out my internet will work fine again
The wireless transmitter for your headset is causing interference with your wireless network.
If you can move your wireless networking equipment away from the USB transmitter then this may lessen the problem.
Perhaps using a usb cable extender will allow you to move your USB transmitter away from your computer?
Hope this helps,
Chris
Mar 02, 2011 | Logitech H760 Wireless Headset
Hi, I purchased two units of logitech cordless
Your friend should be able to use the headset if your friend's computer has Bluetooth feature. THe computer will send and receive the Bluetooth signals with one transmitter/receiver like your computer does and then connect to the wireless lan with a different transmitter/receiver system on a different frequency. Just make sure your friend's computer has Bluetooth feature turned on and then setup the headset by the "pairing" process.
Jun 15, 2009 | Logitech Cordless Headset for PC & Mobile...
No audio from computer to Motorola S805 Headset
I posted this problem a long time ago. I updated to Windows 7 and my headphones immediately worked flawlessly!!
Dec 29, 2008 | Motorola Mobility S805 Wireless Headset
Atheros 5001 Mini pci lan adapter
If it is a LAN adapter, It is not a router.
A router enables you to connect several computers(256) with DHCP IPs
Sep 21, 2008 | Toshiba Satellite M35X-S109 Notebook
Wireless router
Yes I can help you... Do you know how to access the routers programming? If not open a web browser like internet explorer or Netscape. Enter the ip address of your router in the address bar of your browser. By default the ip address should be set to 192.168.10.1 or 192.168.1.1 By default the username is
admin and the password is motorola. Now you see a menu says Motorola broadband wireless router... Click Networking you should find all the relevant information your looking for in there look for the tab that says Port Triggering. SlingBox requires you to forward the 5001 ports. So name the port trigger SlingBox1 make sure its enabled and set TCP incoming to 5001-5001 Another one should pop up name it Slingbox2 set to UDP ports incoming 5001-5001 and that should be it. Now click the ADD button and then click APPLY at the bottom of page.
May 01, 2008 | Arris WR850GP Router
Gigatech mh - 5510 headset
make sure you have the mic mixer turned up an on. Look at your settings and check the mixer.
Apr 26, 2008 | Audio Players & Recorders
Logiteh wireless headset
Unfortunately thats the side effect of bluetooth technology and battery design. These lithium or NI-MH batteries have a few hundred to thousand cycles and then burn out like a neutron star..
So there comes another environment landfill / recycle issue..
Try a full discharge until you totally run out of juice, recharge it again...IT may work for a few more weeks or more..
Mar 18, 2008 | Logitech Traveller (980399-0403) Wireless...
Electronics - Others Logo
271 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
