Question about Microwave Ovens
The dasher is broken and will not turn in holder
  • 17,970 Answers
According woth the brand and model, search replacement parts in this sites:
- apwagner.com
- sears.com
Hope helps.
Posted on Mar 16, 2011
GE Spacemaker xl1800 microwave oven randomly turns off
While you checked the wall receptacle it could be a loose connection in your breaker panel where the breaker snaps into the buss bar. Try the unit in an outlet on a totally different breaker and see if you have the same problem. I also say this a lot, if you have a bad fuse holder in the unit it can make the fuse go bad by betting hot and melting so you could have either a bad or weak fuse holder or bad wire connections to the fuse holder. These companies are using some pretty cheap fuse holders these days!!!
Oct 31, 2017 | Microwave Ovens
Microwave won't START!!!!!!!!!!!!
It's usually a broken tab on the upper switch holder, allowing the switch to rotate just out of position.
This tab can be hard to see, since it is under the bottom edge of the switch.
While replacing the switch holder is the preferred solution, using hot glue to secure the switch to the holder is much easier and quicker. Just be sure not to let the door be slammed from now on.
We have the R1480 service manual for this model and have uploaded it to our site here to help you. You will need the free Adobe Reader to view or print it.
The best place to order Sharp parts is Tritronics.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 22, 2008 | Sharp R-1480 Microwave Oven
Start button
We have the service manual for this model and have uploaded it to our site here to help you. You will need the free Adobe Reader to view or print it.
On these models, the problem is usually a broken tab on the upper door switch mount.
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site. The best place to order Sharp parts is Tritronics.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
MICROWAVE TURNTABLE
Does it turn for just a moment or does it keep turning?
If it's just for a moment, that's normal.
If it stays on, either your top or bottom door switch is sticking or it's door switch mount is loose or broken.
One test that sometimes helps is to gently lift up on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
What is your brand & model number? We may have the service manual you can download free.
Jul 20, 2008 | Goldstar MV-1501 Microwave Oven
Turntable keeps turning
This is usually caused by either a bad door switch, a loose door switch mount, or a sometimes problem on the control panel.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please reply back here if you still need help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 10, 2008 | GE JVM1440 Microwave Oven
The GE Spacemaker model JVM1440WH04 will not turn off fan or light when door is closed. Does not heat, but it appears to be in the door sensor or something related to the closing of the door. Any advice?
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Jul 08, 2008 | GE Microwave Ovens
Oven doesn't work
There are plastic mounts inside the microwave which hold the door switches and onto which the door hooks latch when you close the door.
Jun 11, 2008 | Frigidaire GLMV168K Microwave Oven
Jenn-Air Microwave turntable not working, microwave works
It's probably a cracked coupler or a weak, slipping motor.
You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Oct 03, 2007 | Jenn-Air JMC8130DD Microwave Oven
Microwave Ovens Logo
12 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
