Question about Microsoft Xbox 360 Console
Xbox consol has red ring only 3 lines not full ring
    Scholar:
  • 78 Answers
This could be a mjor problem.. Kindly Check this picture here for reference..
Or, you could try doing there simple troubleshooting steps:
  1. Restart the console.
  2. If this did not work, there could be a loose cord or cable. First, any cables and power cords that can be removed should be disconnected. Unplug the power cable from the wall plug. Firmly reattach all cables and cords back into the console. Now connect up the power and turn on the console.
  3. If the above step didn't work, then try turning off the console, unplugging the power and then disconnecting the hard drive. Now plug into the power and turn the console back on. If console does not show the three red lights error, turn it off and disconnect the power cord from the wall. Finally, reconnect the hard drive, plug in the power, and turn on the console.
  4. If you are using a defective surge protector, plug strip, or extension cord, your xbox may not be getting adequate power. Try plugging the power brick directly into the wall. This sort of thing happens more often than you might think. My DSL connection used to be very unreliable until I bypassed my surge protector and plugged my modem directly into the wall. I should have done this in the first place rather than making a lot of angry (and useless) phone calls to my internet service provider.
  5. If you think that your machine has overheated, then turn it off and let it cool down. Ensure that the cooling vents are not blocked in any way and keep your Xbox 360 in a ventilated and open area.
    Do not place near it any sources of heat. There are obvious sources like heaters and radiators and such. But less obvious sources include the electrical devices that are sitting on top or beneath your xbox.
    Try removing any dust buildup inside the machine.
    Cool off your console with a small fan.
    Don't forget to keep the power brick cool, so keep it off of shaggy carpeting. Better still, place it on an elevated surface. You can even hang the power brick by its cord off of a hook.
    Keep the rear of the console clear. Don't push it up against a wall and keep any debris away. This includes not allowing any cords and cables to get all bunched up in this area.
    Don't do any all day gaming marathons. Limit your gaming to just a few hours, then turn it off and let it cool down for a while. The warmer the room temperature is the shorter your playing time should be.
if all else fails, consider of having your XBOX repaired by a local tech or the nearest XBOX service center. this could be a little expensive but a quicker option..
Posted on Mar 16, 2011
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
Red light is on around the green on light on xbox
Full ring or partial? Full ring usually implies that your power supply or AV cable is not inserted properly. 3 lights, that's a whole other, more costly problem. Reply with clarification.
Oct 28, 2010 | Microsoft Xbox 360 Console
What happens when you get red rings
it depends on how many red rings you have but if you have 3 red rings or the ring of death it only means that you need to call xbox for the warranty of the console
May 22, 2010 | Microsoft Xbox Console
3 blinking red lights
u my friend hav the 3 red rings it just means that u need 2 let ur xbox rest 4ahale ur lucky its not tha ring of death
Dec 20, 2009 | Microsoft Xbox 360 Console
The bottom right red light is on when i turn my xbox on, what does this mean?
it is similar to the red ring of death on the 360 and it means that it overheated and damaged itself
Nov 23, 2009 | Microsoft Xbox Console
How do i fix my xbox 360 3 red light appears already
Xbox extended their warranty to 3 years for this problem. As long as the xbox hasn't been modded they will replace it free of charge. call 1-800-4-my-xbox
Oct 22, 2009 | Microsoft Xbox 360 Console
3 red rings xbox 360
thats the Red Ring of Death send it in to xbox,call18004myxbox the red rings are a hard ware failure
Oct 15, 2009 | Microsoft Xbox 360 Console
X bow stalls
3 rings would be the ol' Red Ring of Death, while 4 rings means the AV cables are not detected.
Jun 19, 2009 | Microsoft Xbox 360 Console
Game freezes and dots appear on screen
I hate to break it to you, but you may have gotten the Red Ring Of Death. It happens when playing a game and it is transmitted through online play through Xbox Live. 3 red lights will appear around the power button when your console has become infected. The Red Ring of Death may have infected your console causing it to shut down. Most Xbox 360 consoles won't turn back on but some do turn back on but they just won't play games, they will freeze up and have the dotted lines and make the buzzing noise. I'm sorry, but I think you may need a new console. You're in luck if it's still under warranty. Hope this helps!!!!
May 20, 2009 | Microsoft Xbox 360 Elite Console
My xbox 360 has three red rings and one green in the middle
the 3 red rings are the worst and there is no way to fix it, i tried wrapping a towel around it and leaving it for an hour or so and that worked for me... the is a good old xbox remidee, but if that dosnt work then call the hot line and you will have to send it off.. the usually have it back in about a week
thanks, max
Dec 15, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
