Question about Yard Man YardMan 173 cc OHV 19" 3in1 Rear Wheel Drive Mower with Electric Start ()
What type of engine is in the yard man 173 cc ohv 19" electric start rear wheel drive lawn mower from sears? and are tune-up parts easy to get spark plugs, air filter.
5 Suggested Answers
MNfisherman
  • 11896 Answers
SOURCE: Yard man mower 139cc OHV spark plug
You can purchase a boot puller or take a pliers and grab exactly on top of spark plug and pull off. Some do stick on harder than others.
Posted on Aug 17, 2009
rwvanlue
  • 486 Answers
SOURCE: oil change in yard man lawn mower
Some mowers are designed to drain oil out of the dipstick tube. remove dipstick and tilt the mower to allow oil to run out into a drain pan. 2/3 rds of a quart or 20 oz is what to expect.
Posted on Dec 06, 2009
SOURCE: we have 42'' Yard Man riding lawn mower need to how to change oil
have a 46 ins yard man ride on need to know what grade oil it uses
Posted on May 15, 2010
  • 46437 Answers
SOURCE: Got a yard man 19 hp kohler courage mower ran fine shut off. And went to restart will not fire up.has a weak spark will not fire under starting fluid any help
disengage the mower deck
Posted on May 08, 2016
Why does Mtd 19 In. 173 CC OHV 3-In-1 use a lot of gas
If the unit runs too rich, then replace the carb.
Jun 02, 2014 | Mtd 19 In. 173 CC OHV 3-In-1
Belt drive
If you post the model # it would be helpful. You can often times find the engineering drawings at partstree.com/parts. YardMand is actually made by MTD so you would have to look in that category under walk behind mowers.
Sep 28, 2013 | Yard Man YardMan 173 cc OHV 19" 3in1 Rear...
MY LOWN MOWER DO NO ASELERATE WHEN CUTIN HIGHT GRASS
Kut it moor offtan to it tont Det to hight. ????? O tay.
Jan 13, 2013 | Yard Man YardMan 173 cc OHV 19" 3in1 Rear...
How do i change the drive belt, having accessing belt to remove it. directions in the manual aren't very specific.
Try looking under the machine a lot of yard machines have guards underneath to access belt after removing blade. Good Luck...
Aug 16, 2011 | Yard Man YardMan 173 cc OHV 19" 3in1 Rear...
Mtd 19 In. 173 CC OHV 3-In-1 self propelled. Drive will not engage. Appears as if the belt is too loose even when the drive control bar is depressed all the way. Is this adjustable? This mower hasn't...
Between the handle and the connection to the drive system, look for adjustment screw or nut and screw on cable. Maybe even check the spring tension, if handle is spring loaded and the spring is stretched it will not engage drive system. If no adjustment to be found then you must get new belt. Good Luck...
Jul 19, 2011 | Mtd 19 In. 173 CC OHV 3-In-1
What is the proper weight oil for most walk behind mowers.
SAE 30. If you run synthetic (hard to find in SAE 30W) then you can get away with using a muti-viscosity oil like 10-30W. Briggs and Stratton are very adamant that ONLY SAE30W be used in their small engines.
May 07, 2011 | Yard Man YardMan 173 cc OHV 19" 3in1 Rear...
Just looking for the oil typ and amount for this engine 173 cc ohv
if its a briggs and stratton engine of older vintage always use straight 30 wt. about a litre will do then check level
Apr 02, 2010 | Mtd 19 In. 173 CC OHV 3-In-1
Yard Man YardMan 173 cc OHV 19" 3in1 Rear Wheel Drive Mower with Electric Start () Logo
102 people viewed this question
Top Yard Man Garden Experts
Richard Schanie ...
Phil Walker
Phil Walker
itsman
Are you a Yard Man Garden Expert? Answer questions, earn points and help others
