Question about Gaggia Classic Espresso Machine
Does my Gaggia classic have an internal fuse I can replace myself and where will I find it?
    President:
  • 1,618 Answers
Remove the top panel.
Posted on Sep 23, 2011
Where is pinhole on frothing wand classic gaggia machine
IT IS INSIDE THE INJECTOR ASSEMBLY. IF STEAM DOES NOT COME OUT THE ACTUAL STEAM TUBE THEN ITS CONTROL VALVE OPERATED BY THE ROTATING KNOB IS CLOGGED. REPLACE THE VALVE IF DESCALING WOULD NOT CLEAR OF THE INTERNAL ORIFICES.
Sep 23, 2014 | Gaggia Classic Espresso Machine
When I switch on mygaggia classic expresso machine it will not switch on
The thermal fuse in the Gaggia Classic is likely tripped and it is not re-settable. The fuse has the following stamped on it: MICROTEMPSKMAHDG4A00184C I believe that is what is the culprit for all of us when the "power doesn't come on." Now, what is the rating of this fuse and where to get a replacement? The fuse is the small resistor-like, diode-like part in a clear tube mounted against the boiler, and it must be physically cut out of the line to replace it!
Apr 26, 2014 | Gaggia Classic Espresso Machine
Gaggia Classic won't turn on, no light at power switch
I would suspect rough handling of your suitcase, leading to some loose or broken connections inside. I recommend opening it up and looking for obvious disconnections. If you don't see any, the next step will be to use a tool like an electrical continuity tester (which can also test for a blown fuse). There is a lot of information about Gaggia Classic repair online -- just search for "Gaggia Classic repair".
Jul 29, 2013 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Gaggia Classic Cannot insert coffee
You will have to reseat or replace the head gasket.
May 06, 2010 | Gaggia Classic Espresso Machine
Gaggia Classic Group Head Stuck
try this website http://www.bluebox.com.au/jcrayon/gaggia/
Mar 06, 2009 | Gaggia Classic Espresso Machine
Gaggia Classic - No Heat, Hot Water or Steam
There is a thermostat on the boiler disconnect and check to see if you can get a reading using an ohmsmeter, if no reading replace the thermostat. If you get a good reading then disconnect the element and check for resistance.
Dec 16, 2008 | Gaggia Classic Espresso Machine
Power doesn't come on anymore
I determined that the thermal fuse in the Gaggia Classic that I am repairing had tripped and it is not re-settable. The fuse has the following stamped on it: MICROTEMP SKMAHD G4A00 184C I believe that is what is the culprit for all of us when the "power doesn't come on." Now, what is the rating of this fuse and where can I get a replacement? The fuse is the small resistor-like, diode-like part in a clear tube mounted against the boiler, and it must be physically cut out of the line to replace it!
Apr 30, 2008 | Gaggia Classic Espresso Machine
Seal Kit
Gaggia Gasket Seals can be purchased from most good online suppliers
These can be replaced pretty easily and if required I can provide a step by step instruction guide how to do this.
Feb 03, 2008 | Gaggia Classic Espresso Machine
Gaggia Classic Espresso Machine Logo
90 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
