Question about Whirlpool Washing Machines
My 15 year old Whirlpool washing machine did'nt agitate or drain, could it be the motor? If so, how do you access the motor?
  • Whirlpool Master
  • 8,220 Answers
Look for a broken lid switchMy 15 year old Whirlpool - themobilian_1922.jpgAll the models over the years have changed the way you get into the machines but the basic concept is the same. The cabinet is removed to access and service this washerthemobilian_1923.jpgthemobilian_1924.jpg
Drain and spin is in the same direction on these washers.
It won't spin with lid open. Newer models won't spin or wash eithMy 15 year old Whirlpool - themobilian_49.gifen.
Basically the lid switch has a green ground wire and 2 hot wires. themobilian_49.gif
Jump them 2 hot wires as shown here at the quick connect to look for leaks and noises AND to see if the lid switch has failed.
Manual and more HERE
Posted on Mar 16, 2011
Kenmore 15 year old washing machine, that agitates fine but nO spin or drain, could this be solenoid how do i get to it?
Check the drive between the motor and the drum for the spin/drain cycle. Also check the cam sequencer to make sure that power is being transmitted to the motor at the right time.
Feb 24, 2016 | Kenmore Washing Machines
Drain line clogged on Whirlpool model ET1CHMXKB09. How do I access the drain line?
Hello.
Washing machines, like any other mechanical device, occasionally needs servicing. A common problem with most old washing machine is that the spinner, or agitator, drain,or stops rotating during wash cycles. Fortunately, most washing machine problems are easy to troubleshoot. Any do-it-your self offer can fix it; here's how.
TOOLS NEEDED TO SOLVE PROBLEM ARE BELOW.
Bucket and rags,Screwdriver,
New drive belt (if necessary),
New drive motor (if necessary).
1 Unplug the washing machine, and turn off the water supply to the machine. If necessary, remove the water hoses from the back of the washing machine because they may be in the way of the access panel.
2 Check that the agitator is seated correctly by opening the lid of the washing machine. If it's loose, pop off the top of the agitator--if there is one--and tighten the bolt that holds the agitator in place. Or, in some models, simply pull straight up and then reseat the agitator.
3 Remove the access panel located in the back of the washing machine by unscrewing the screws holding it in place. This allows access to the drive motor.
4 Press on the drive belt that works the agitator. If the belt moves more than 3/4 inch, tighten the belt to fix the spinner problem. If the belt is worn or cracked, replace the belt.
5 Replace the drive motor, if tightening or replacing the drive belt doesn't fix the agitator. Purchase a new drive motor at a wholesale retailer. Disconnect wiring, remove screws holding motor in place and insert new motor. Screw into place, and connect wiring.
6 Check for any black substance leaking under the washing machine. This might indicate a clutch problem, if the washing machine spinner is not working. Contact a professional repairman to replace the clutch.
Thanks.
Oct 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My wash machine wont agitate or spin. i have a whirlpool top loader and it is around 15 years old.. it is in great shape. It turns on fills with water and then goes silent. The timer works. It seams there...
If you're getting no motor noise, the most common cause is a bad lid switch. If the lid switch is good, I would suspect the timer. Here's a video that may help you access the parts.
http://www.youtube.com/watch?v=6XIsK3W_Qcg
Jan 05, 2011 | Whirlpool Washing Machines
Agitator will not spin easily from pully below or
transmission out buy new washer cost to great to repair 15 year old washer
Feb 03, 2010 | Maytag LAT3600A Top Load Washer
Breaker switch flips when machine starts to agitate
Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Aug 20, 2009 | Whirlpool LSB6500P Top Load Washer
I have a 15 year old top load whirlpool washer that is not agitating, the thing in the middle barely spins, Help Vickie
If only the top portion of the agitator doesn't move , then it has bad agitator dogs . If the lower portion doesn't move , then the washer has a bad coupling which connects the motor to the transmission . Both are relatively easy to replace .
Aug 09, 2009 | Washing Machines
Whirlpool Washing Machine Won't Agitate
Hi friend...
it is usually caused by anything stucked below tub,if its not then if is actualy timer,,,check them both...
thank u.....
May 03, 2009 | Whirlpool Washing Machines
Whirlpool agitator not working!
Hello Roger.
Please do the following checks for they might just help.
Check that the water supply valves are turned on
Inspect the filter screens
Test for overheating
Inspect the water pump
Test the water inlet valve
Test the motor
Most probably this case may be due to a faulty motor.Good luck.
Jan 09, 2009 | Whirlpool LSR6232J Top Load Washer
No spin or agitation on washing machine
check the coupler it is the plastic and rubber piece that is in between the motor and the transmission
Dec 30, 2008 | Whirlpool Washing Machines
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
