Question about Samsung Televison & Video
Samsung hlp5663 have a HLP5663
Samsung hlp5663 have a HLP5663 WIDE SCREEN TV- 2005. New colour wheel and filter changed 2007. This week it has been shutting off now and then- today its totally shout off. There is sound but no picture. ON/OFF button flashes LAMP or sometimes STAND BY. Can you please help Thanks
  • 3130 Answers
SOURCE: Samsung 46" DLP
The lamp drive Circuit. There is a Ballast that could be bad. The ballast is located here: Or the DMD board located here: Or the power board located Here: Good Luck
Posted on Jun 20, 2007
  • 149 Answers
SOURCE: No picture, new lamp
Did you reset the hours on the lamp with the menu options on your set? Sometimes, if you do not do that it can mess with the tv performance thinking that its over hours. It needs to be reset to 0 again...
Posted on Sep 24, 2007
  • 4402 Answers
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Posted on Feb 06, 2008
SOURCE: samsung hlr4667w dlp tv
Posted on May 28, 2008
SOURCE: No picture, no sound on my Samsung 56" Projection TV
You probably need to replace the lamp. It's about $150, and if you buy it with the housing, it's a really easy fix, just unscrew and pull out the old one, and pop the new one in. Go here:
Posted on Nov 18, 2008
Samsung hlp5663
What is the problem?
Aug 01, 2008 | Samsung Televison & Video
Replaced the lamp bulb on my samsung HLP5663. It went on right away. Though the problem was fixed. Turned the tv on a little while ago and the picture is gone. The timer light is blinking. Any ideas what's...
Now tv turn on.Hear alots of clicking or squiling,loud motor noises turn on?Alot of clicking,the Ballast board it dead,this board help ignite the projection lamp.Tv also have a colors wheels.The colors wheel is dead,if hear squiling noises,loud motor noises.
Jul 14, 2010 | Samsung DLP HL-P5663W 56" TV
My bikes engine oil is changing into black colour with in a two weeks duration.while i change the oil it seems to be smooth.plz suggest me a solution
hi mate it will change colour quickly but a thing that will make it change quickly is the oil filter are you changing this/cleaning this
Aug 30, 2009 | 2005 Bajaj Pulsar 150
New samsung 40 inch LCD. When in the wide mode
if you are watching cable or satelite, you need to change the screen format output from the source to make sure it matches with the TV
Jun 14, 2009 | Samsung LN40A550 LCD TV
My rca tv not working
the lamp which you rteplaced is not seated properly.and also it can be the problem of colour wheel or the check out all three just check out this links 1 by 1 for colour wheel with diagram and procedure
for lamp in 5 minutes with diagram and procedure
for ballast with diagram and procedure
Feb 09, 2009 | Toshiba 32AF41 32" TV
Shadow top to bottom of screen on left side about 2" wide...
This can be the sync wheel assy, failure in the drive circuit for the display chip, or an illumination fault. You will have to give the set out for service.
Jerry G.
Nov 26, 2008 | Samsung DLP HL-P5663W 56" TV
MS Office repair:
Go to the "Add and Remove Programs" in your Control panel. Click the "Change" and do the 'repair program' utility.
That should fix it, good as new.
Be sure to have your INSTALL disk handy (for all Microsoft products).
Dec 02, 2007 | Microsoft Office Professional 2007 Full...
DVD PLAYER - plays 'red'
had this problem when I start using it with "component" video cables on a new digital wide screen TV. I fixed it through the DVD player's setup menu, by changing the "video output" setting. On my Samsung player there are 3 options: S-video, 525i and 525p. It was set to S-video, and by changing it to any of the other two settings the problem was solved.
Apr 10, 2006 | Samsung DVD-P241 DVD Player
Televison & Video Logo
118 people viewed this question
Jerry Greenberg
Jerry Greenberg
