Question about Bose & Wave& Music System
CD's will not play. I was playing a CD with no problems and in the middle of the CD, it just quit. I tried other CDs which have worked fine in the past and now I can get nothing to read. It will say "reading disk" for about 10 seconds and then ejects the disk and displays "no disc".
  • Bose Master
  • 6,694 Answers
just purchase a lance cleaning cd. It will be available in cd shops. insert it in the player. it will clean the lance. after cleaning insert the CD and watch is it reading. If not then the laser pickup unit of you player have some problem. You have to replace the same.
ok
Posted on Mar 16, 2011
  • Bose Master
  • 6,771 Answers
The Bose Wave Music System is a high end unit and deserves the very best of care. The only option is buy a disc cleaning kit and follow the instructions, this will remove any dirt from the surface of the lens. Now! if this fails I recommend contacting Bose for factory service because they do not authorize anyone to work on their products outside of the facilities.
My car stereo wont play my cds spits them right out
cd player goosed if it doesent accept cd can try resetting if it has a reset button
Aug 25, 2012 | Cars & Trucks
I have a 6 CD player in my escape that has worked just fine for six years. last week when I tried to play a CD, it said CD error. When I tried to eject any of the CD's, it said no CDs loaded. How do I...
Sometimes things just quit working. Not many parts on a car last a lifetime anymore. Chances are your stock radio has gone bad and it would'nt be worth while to have it fixed. Go to a ruputable audio place( best buy, circuit city) have an aftermarket radio/cd player installed, this would be the cheapest fix for your problem.
Feb 16, 2010 | 2003 Ford Escape
My front loader reads disc error or unplayable no matter what disc I insert. It worked just fine for about 2 years. It doesn ot get heavy cd use, but everyday radio/alarm use.
To resolve this issue, try one or all of the following:
  • The Wave® music system is designed to play commercial CDs, CD-Rs, MP3-encoded CDS and CD-RWs. If your system has trouble playing MP3 CDs, make sure the discs were recorded with compatible formats. See Cannot play MP3 CDs
  • The system may not be able to play certain CD-RW discs. Playability is dependant on how the disc was recorded, including the format it was recorded in and the actual disc used for recording.
    Note: iTunes defaults to AAC as the encoding format. In order to use iTunes to make CDs that will play on the Wave® music system, you’ll need to change the format to MP3 How to Choose Import Options
  • Different brands of CD-Rs and CD-RWs use different materials which may affect the ability of a player to read them. If you are burning your own CD-Rs or CD-RWs, experiment with different brands of discs
  • If a commercial disc won’t play, check for scratches, fingerprints or other physical damage. Try the CD in another player. If it still won’t play, there may be a problem with the disc
  • Reset the system by disconnecting the power cord from the wall for one minute, then plug the system back in
Dec 05, 2009 | Bose Wave Radio
Ford cd changer problems
CD player is not working. Motor will not unload or load discs. It will play CDs fine but cannot change them. Unit will need to be repaired by an audio specialoist or replaced.
Sep 07, 2009 | 2003 Ford F250 Super Duty Crew Cab
Doesn't read the cd. says
If any cd player does not play, three things, it either the wrong format, dirty cd or faulty cd player. If your cd player play others cd, it mean others are the wrong format. for example older cd player is not compatible to play some of the cd formatted from the computer. if the cd player does not play anything that mean the cd player is faulty.
Aug 27, 2009 | Sony Audio Players & Recorders
CD player won't play CDs
Try getting a cd cleaning tool come with a disk with tiny brushes on it and cleaning solution to clean the eye or if you are using burned cds try and see what format you are buring such as mp3s mp4s some cd player only will play a certain formats such as mp3s.
May 07, 2009 | 1993 Saturn SL1
I cant play cds on my wharfedale pcd 6200 usb
I think you need to press and hold the Play button (marked PLAY/PAUSE) to switch between CD playback and the USB port (you can store mp3 files on a USB stick and play them directly) on the front of the device.
Try inserting a disc, switching the unit to CD mode, press and hold Play until the display changes and the CD spins up...
Might just work?!
Duncan
Mar 22, 2009 | Audio Players & Recorders
CD player won't play CDs burned on new computer
hi penguinxy.
try get a original cds if it works fine.the next time you burn cd try burn at 8x or low may be your cd lens is not detecting cds burnt at high speed.hope this helps..
May 10, 2008 | Jensen CD-2010X CD Player
CD,s will not play
Read the Manual on Page 2 or get it from:
http://de.jvc-service.net/public/document.cfm?prog=InstrBook.cfm&Model=KD-G321
Just make a reset with a pen or something else.
This should solve the problem.
Best regards
Dirk
Dec 28, 2007 | JVC KD-G421 CD Player
Regarding problem with cd player
Quite a few players from that time did not play mp3's, due to the format's relatively new status. There is no way to play mp3 if the player didn't originally support it. You can try taking the mp3 discs you have and "up convert" to WAV type, then play them on your unit...accordianman
Dec 18, 2007 | Audio Players & Recorders
Bose & Wave& Music System Logo
270 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
