Question about Hotpoint Washing Machines
Need to know the best way to get something out of a locked up pump. Diagram of pump too.
    Brigadier General:
  • 6,277 Answers
(If you haven't done already, may I suggest you follow these tips on filters and pumps? Also I doubt a diagram 1] is available - manufacturers provide them to their engineers only- or 2] would be of use. Pumps are just 'fans' with blades called impellers. Sorry if this 'solution' does not help you)
Here are my complete, general pre-typed guidance notes for checking both the filter and the motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 16, 2011
Fuel gauge wiring diagram
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Aug 14, 2016 | Ford Cars & Trucks
1993 ford F250 dual tanks replaced back fuel pump. Have checked reset,relays and fuses. Still has no power to the pumps. What else could it be?
You need to look at a wiring diagram an check voltage an ground for that circuit . If you don't know how to do basic electrical testing your best bet is take your vehicle to a qualified repair shop that does . You replaced a fuel pump that didn't need replacing . Basic Electricity for Service Techs Ohm law Current Flow Opens Shorts
You can find a wiring diagram at
http://bbbind.com/free_tsb.html
Jun 12, 2016 | Ford Cars & Trucks
The lock on the back of my 2007 HHR tailgate door does not lock.
Well if the lock actuator is bad you'll have no choice but to replace it ! An no there isn't anything common with these ,they do go bad ! An before replace parts you need to test the electrical circuit ,power an ground. If you don't know how to do that there are some good videos on youtube on basic automotive electrical testing an how to read a wiring diagram , because you need to know what wire is what ! Here is a video check it out , if you can't do this then your best bet is to take your vehicle to a qualified repair shop that can . GMC Chevy Door lock actuator window fix
Jun 03, 2016 | 2007 Chevrolet Chevrolet HHR LT
My Chrysler 300 M still won't start and it isn't
I need model year and engine size?
How long since a tune-up? Any applicable trouble codes?
Are you missing anything besides fuel, meaning, engine cranking you have spark at the plugs and fuel injector pulse? If your missing all three, have to check crank and cam sensor signals.
I need model year to look up wiring diagram for fuel pump and relay.
Aug 12, 2017 | Cars & Trucks
Fuel diagram
Without knowing the year of the bike, the following link is about the best that can be done.
Fuel Pump schematic Yamaha Xj650lj 1982
Feb 16, 2014 | Yamaha XJ 650 Motorcycles
Fuel pump dont get power
You should have four terminals on the relay. One is power for the pump, one goes to the pump, the third terminal is power for the magnet in the relay, and the fourth is ground from the computer.
You would need to figure out if you have power on two of the terminals, and if the fourth is giving a ground connection from the computer. You may need a wiring diagram to know which wires.
Jun 27, 2013 | Daewoo Lanos Cars & Trucks
Emissions pump locked up need diagram
The pump is not repaired, it is replaced.
Sep 20, 2012 | 1985 Pontiac Grand Prix
I need the wiring diagram of pump it has 5 pins coming out of pump
hello, i holding a wiring diagram central locking system,model 201,it have a 6 pin,
  • pin no.1 brown goes to ground
  • pin .no 2 black ignition on
  • pin no. 3 red permanent 12 volt
  • pin no. 1 yellow trunk lid switch
  • pin no. 2 blue driver door switch
  • pin no.3 green passenger door switch
hoping it"s help to solve your problem,ty
Apr 28, 2009 | Mercedes-Benz 190-Class Cars & Trucks
Fuel pump removal from gas tank?
no actual diagram really.... the pump turns out there are no actual bolts holding it from what i know of
Dec 17, 2008 | 1993 Chevrolet K1500
Washing Machines Logo
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
