Question about Samsung SyncMaster 930B 19" LCD Flat Panel Monitor
Syncmaster930b problem when turned on keeps flashing analog/digital also turns itself off then back on
    Scholar:
  • 66 Answers
Http://www.fixya.com/support/t859266-koss_kld2700_lcd_tv_no_picture
As in almost all lcd type tv/monitor the backlight will go out and the inverter should be replaced at the same time. Your cost about 50.00 if you do it yourself.
Take care
Kevin
Posted on Aug 02, 2008
Left turn signal indicator turns on itself and flashes twice as faster
it should never do that automatically. ever.
it proves the switch is bad, or its wires shorting together.
use the drawing at alldata.com to see how it works
newer cars the switch is pure digital, not analog direct path.
in that the switch tells the BCM to flash by grounding a wire (logic 1)
rtm.
Jan 18, 2014 | Toyota Corolla Cars & Trucks
Lg w2234s keeps turning itself off, all cables ok so is video card, any ideas
try pressing on source key, the monitor has two input sources one digital and one analog maybe it's on the wrong input (digital connected while monitor on analog or vice-versa)
Oct 14, 2011 | LG W2234S 22" LCD Monitor
Monitor keep flashing analog and digital when i turn it on
Hi Ichandler422,
This usually happens when the monitor does not recognise that it has been plugged in. Please check that there is either a blue analogue or white digital cable connect to the monitor and the computer.
Thanks. Edge.
Jun 29, 2011 | Samsung SyncMaster 214T Monitor
How do i turn back the hands one hour
The analog clock hands on the Casio 2747 will only turn in a clockwise direction, but there is a way to speed them up when you have to move them far around the watch face.
1. In Timekeeping mode (i.e. Date is shown in the digital display), push button "C" (bottom-left) 6 times to enter Hand-Setting mode.
2. Hold down button "A" (top-left) until the digital time starts to flash.
3. Press button "D" (bottom-right) to advance the analog time by 20 seconds, and hold down button "D" for High-Speed.
4. Alternately, for High-Speed, press button "D" (bottom-right) and button "B" (top-right) together at the same time, and then let go. The hands will continue to move automatically. Press any button to stop them BEFORE they arrive at the desired time, then press button "D" several times to arrive at the time of your choosing.
5. Press button "A" (top-left) to exit.
6. Press button "C" (bottom-left) if you want to return to Timekeeping mode.
Oct 28, 2009 | Casio DBW30SG7AV Databank Analog Watch
Converter box turns off by itself while we are watching the tv
Check in the menu of the converter box for a power save mode or auto shutoff feature. The settings for this feature are usually set to 4 hours or less. Change it to the always on setting.
Jun 12, 2009 | Insignia Digital-to-Analog Converter for...
Why does my converter box turn itself on and shut itself off?
set your power down to off most boxes are set to turn off in 4 hours
Jun 10, 2009 | Insignia Digital-to-Analog Converter for...
Digiatal input indicator keep flasing
The flashing digital input for DVD means its digtial input is either not connected or not transmiiting. If yoy still hear the DVD it is probably because you also have the analog cables attached. Is that right?
If you had both attached the receiver would opt for digital over analog but would default to analog if the digital signal was not there.
If you can connect the DVD's digital cable you will get actual 5.1 surround sound from DVD.
http://www.sherwoodusa.com/pdf/RD-6500(English).pdf
Apr 04, 2009 | Sherwood Audio Players & Recorders
Won't keep digital signal
If you're connected to a digital cable box, I would try using the external component connections and bypass the TV's tuner. If all you have is straight cable coming into the house, it could be the cable signal itself or a defective tuner in the TV assuming all the menu settings are correct in the TV.
Jul 25, 2008 | Toshiba MW20H63 TV
Viewsonic VA712b issuses
Digital-to-Analog Converter - DAC When referring to Audio, DAC is also short for Digital-to-Analog Converter and is the process of converting a digital signal into an audio signal.
Random Access Memory Digital-to-Analog Converter - RAMDAC Pronounced Random Access Memory Digital-to-Analog Converter, RAMDAC is the ... the digital data to an analog signal to be displayed on a computer monitor.
Good Luck, Please dont for get to Vote/Thank you.
Dec 19, 2007 | ViewSonic VA712B 17" Flat Panel LCD...
Samsung SyncMaster 930B 19" LCD Flat Panel Monitor Logo
213 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
