Question about Rangemaster Toledo 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range
I have a Rangemaster toledo xt 110 and i need a door insulation kit which iam told are now obsolete,doe's antone no where i could get one from.
grandadfixer
  • 99 Answers
SOURCE: Door handles on rangemaster toledo 110 duel fuel
Yes this is easy to do.We can supply bits if required.
Posted on Oct 23, 2008
FitzOriginal
  • 842 Answers
SOURCE: Timer instructions for a Rangemaster Toledo dual fuel 90 required
OK, here we go, this is actually a fairly lengthy explanation, but I will do what I can to explain.
The timer can be used to turn just one, or both ovens on and off automatically, however the start and stop time must be the same for both ovens, though different cooking temperatures can of course be set, so if you play around with temperatures to extend the cooking time of an item in one oven, you can often cook items needing very different settings for the fixed time you set in both ovens. Note that when the timer is on and the AUTO message is on the display, the ovens are disabled and will ONLY work during the timed period unless the timer is disabled again. (This is a common problem when you first power up, because the AUTO setting is automatically engaged on installation or power up after a power cut, disabling the ovens until you figure this out!). So, with all that garbage out of the way, how to use the timer settings:
For ease of understanding, I will refer to the buttons on the control pannel (Running from Left to Right as: BELL, HOT DISH, COLD DISH, HAND, + and -)
TO TIME SOMETHING THAT'S ALREADY COOKING (Minute Minder). Press and hold down the BELL symbol (Far left), use the + or - to adjust the amount of time you want to cook for (You can check time remaining at any point, or cancel the beeper when the time is up, by pressing the bell button.
TO STOP AUTOMATICALLY AFTER YOU HAVE MANUALLY STARTED COOKING. Press and hold the COLD DISH button at the same time use + and - to adjust your required stop time. AUTO will show on the display. When cooking is finished, the beeper sounds. TURN THE OVEN TEMPERATURE KNOB TO "0" FIRST, then press the HAND button, once to stop the beeper, and again to cancel auto and return to manual mode.
TO START AND STOP THE OVEN MANUALLY: Before you start, decide when you want the cooking to stop and how long you want the food to cook for (The cooker will work back from your stop time and figure out the START time for its self.). Press and hold down the HOT DISH button and at the same time set the minutes and hours you want the oven to cook for with the + and - buttons (You are NOT SETTING THE TIME HERE, you are setting how many minutes and hours to cook. Next, press and hold the COLD DISH button and use the + and - to set the stop time (YOU ARE SETTING A TIME IN THIS OPERATION). AUTO will show on the display. Set the temperature for the oven (or both ovens) that you want to auto cook with. When cooking stops the beeper sounds. Press the HAND button to cancel the beeper and press the HAND again to cancel AUTO and return to manual mode. (Note that the beeper stops after a while if you leave the oven attended, but the manual states you still have to press the HAND button twice to return to manual, I have not personally tested this).
GETTING BACK TO MANUAL MODE. If AUTO is showing on the display, because you have set automatic and no do not need it, or you have just powered the cooker up, any cooking time already set must be returned to 0:00 before you can return to manual, so hold down the HOT DISH button and ensure the display is set to 0:00, once you gave done this you can press the HAND button to return to manual mode
Posted on Jan 23, 2009
SOURCE: RANGEMASTER 110 Cooker FLAME FAILURE DEVICE fitting
the ffd comes has a unit with a gas tap connected to it. can be brought for £90.99 from manufactures.
Posted on Feb 20, 2009
SOURCE: warmer lights up but not getting hot - Rangemaster Toledo XT
Hi Sally
I havd exactly the same problem. I contacted Rangemaster/Aga support line (0845 603 5312 if in warranty, 0870 789 5107 if not) and they told me the heating element was shot.
My cooker is 2 1/2 years old, so out of warranty, but they were good enough to send me a new cooker top (top left hand side only of course) free of charge!!!, I just have to get it fitted.
You have to replace the whole left hand side of the cooker top too - the burner that the wok goes on!
Good luck
Posted on May 31, 2009
SOURCE: rangemaster toledo 110
Hold down two left hand buttons together for a long time. that should do it.
Need to convert my rangemaster from ng to lpg but manufacturer is saying our model is unconvertible - help
Hi Helen.
Especially if you have a rig that calls itself Dual Fuel, it would seem that you should be able to convert. I looked up a manual for the Classic 110
http://www.rangemaster.co.uk/media/868812/toledo-lidded-110-dual-fuel.pdf Page 23 of the PDF (19 of the manual pages) specifically talks about there being conversion kits to swtich to different fuels. It also underscores that this should only be done by a certified gas engineer.
That said, my experience from shopping appliances for our house remodel several years back was that some sales people just stared blankly when we asked about running stoves on propane (we're a bit out in the sticks, no Natural gas hookups). Others would look at the same equipment and say 'oh, you need the converter fixture, which was more or less a flow restrictor to keep the energy content about the same as for the NG (propane is a bit higher energy content than NG).
In short, you should be able to convert between fuels, and the manual from the company itself says so.
Good Luck!
D
Dec 08, 2015 | Rangemaster Classic 110 (Dual Fuel) Dual...
How do I clean the glass on the inside of a rangemaster toledo stove
I just cleaned the inside glass on my maytag "gemini" and you take the inside door panel off, thencarefully lift out the glass and clean it.then reassemble. I found it easier to remove the door and lay it on thekitchen table with a blanket under it. Hope yours is similar as I suspect it is. Good luck and keep smiling. Please rate me...Thanks
Nov 25, 2014 | Rangemaster Classic 110 (Dual Fuel) Dual...
Warmer lights up but not getting hot - Rangemaster Toledo XT
Hi Sally
Good luck
May 08, 2009 | Rangemaster Toledo 110 (Dual Fuel) Dual...
Rangemaster toledo 110
Oct 26, 2008 | Rangemaster Toledo 110 (Dual Fuel) Dual...
Aug 11, 2008 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Faulty plate warmer on rangemaster 110 dual fuel
We have the same problem on a Rangemaster Toledo 110. It is not a fuse.
The 'Hot' light still comes on because that is a different (parallel) circuit.
Examination by a competent electrician has found that the soldering for the wires that power the warming metal strip under the glass is faulty. You will have to ask for a replacement part.
There may be a design flaw, so you might want to enquire about the professional all gas burner top and just use the griddle as a warming plate over the second wok burner.
Good luck.
Jan 20, 2008 | Rangemaster Classic 110 (Dual Fuel) Dual...
Rangemaster Toledo 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range Logo
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Mike Carew
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
