Question about Vacuums
No water coming out my vax 6131 when trying to clean the carpet
reddevil6
  • 1673 Answers
SOURCE: Vax problem
Could be a bad pump.
Posted on Feb 22, 2008
SOURCE: vax carpet shampooer wont release shampoo
if you unscrew a bit on the base that allows you to take off the brush, you will see a black plastic strip with very small holes in it. These are where your shampoo comes out of. Take a needle and re-pierce these holes and it should work again. I have just sorted mine out. good luck .
Posted on Mar 08, 2009
ukvacfan
  • 328 Answers
SOURCE: VAX Petvax Operating Manual
Check Vax.co.uk they have an online user manual section.
Specificially:
http://www.vax.co.uk/support/vacuum-cleaner-user-guides
Dont forget to rate appropriately, thanks.
Posted on Mar 27, 2009
EwingElect
  • 276 Answers
SOURCE: VAX 2000 manual lost
If you want a manual for the Vax 2000 hopefully the one on the Australian website will help.
Try http://www.vax.com.au/Downloadsusermanual.html and you'll see V2000 listed.
Posted on Mar 31, 2009
SOURCE: water lesking from vax rapide carpet washer
i have been using a vax v26 carpet cleaner and the washing water is leaking from the bottom then the solution will not come out has the pump given up?
Posted on Jun 14, 2009
Carpet cleaner vax
did it work before? if so then you could have a blockage from the outlet (where the pipe connects to the water tank which model do you have ? and was the filter present when you was working with the trigger only?
Apr 15, 2014 | Vacuums
Vax rapide
I brought a rapide ultra carpet washer today , cleaned half of my front room brilliant then stopped spraying water using the trigger on the handle, as the handle comes off for easy storage I took it off, and what\'s happing is when you pull the trigger to release water a piece of plastic pushes on another piece ov plastic to release water and it was not working only by me pushing my finger on the other piece of plastic in side the handle bit, so mines going back ,
Aug 14, 2013 | Vacuums
I need an instruction manual for a Vax Rapide Classic carpet cleaner
i have recently been given a vax rapid deluxe unfortunatley it didnt come with the manual.my problem is the water isnt coming out ? please help
Sep 11, 2010 | Vacuums
My Vax rapide is not sucking up water?
I had the same problem. Then I took off the brushbar (it's underneath at the front). It just pops off. Then it worked fine. I guess you only need it for long carpets.
Jul 02, 2009 | Vacuums
How do you use vax 2000 to shampoo carpets. do not have a manual
Set up is complicated unless you are patient.
Remove the paper dust bag from the bottom of the canister and then filter ring. Then put in the recovery bucket of which 4 litres of warm water should be added and a capful of floor cleaning solution.
Then remove the pump wire on top of the Vax motor where the blue filter circle is (keep the filter in, do not remove it!).
If the 2000 has a separate pump notch on the rim of the Vax motor head on the outside then you should plug the black cord in that has a washer screw type metal connector. Push, twist and lock in. Then the black cord which eventually leads to a clear pipe with the older clip on wash handle that has to be clipped to the main hose handle has to have the black and see through cord clipped to the main hose and eventually down the extension pipes until you get to the floor head. If you have the older style T shaped floor head the cord should slip into the floor head easily. Then either squeezing the trigger to release the cleaning solution in, switch the Vax on and hit the secondary pump button. This will pump the cleaning solution and water into the carpet. To stop the pump you can either lock the wash trigger to stop the liquid or squeeze the trigger to make sure no other liquid comes out. Generally you can see the foamy carpet solution flowing through the see through rubber hose and eventuallly through the floor head.
To **** up the rest of the carpet solution, stop the pump button and the Vax can be used to **** out all the dirty solution/water in the carpet. Its a big and tedious task generally!
See an alternative manual for the Vax 1000 which is an older model but similar to the 2000. It is free and in pdf downloadable form:
http://www.vax.co.uk/downloads/pdf/VaxGuideNo8a.pdf
Jun 15, 2009 | VAX Appliances 2000 Canister Vacuum
Water lesking from vax rapide carpet washer
Jun 07, 2009 | Dirt Devil CE5500 Floor Keeper Upright...
Mar 31, 2009 | VAX Appliances 2000 Canister Vacuum
Vax rapide not realising water out
I have just managed to fix the problem i had with my vax rapide not releasing water. I also tried tilting it and that did not work. I unscrewed the brush from the base of the carpet washer and there is a black plastic strip with holes in where the water comes out of and onto the carpet. I used a needle to unblock these tiny holes which had become blocked after the last use. I now have it working again.
Nov 12, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
Vax problem
Feb 07, 2008 | Vacuums
Vacuums Logo
328 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
