Question about HEWLETT-PACKARD Hewlett Packard HP Notebook Battery Li-Ion 8-Cell For HDX18 And dv7 Series KS525AA 464059-222 464059222
Hp battery saying i may consider changing the battery
  • 229 Answers
Insufficient info is provided here. How old is the battery, and how long does it last now. If it is old and runs down easily, then it needs changing. If it is less than 8 months and still runs down fast, then its having issues with ur main power supply. Purchace a new battery and ALWAYS USE IT WITH A SURGE PROTECTOR. Hope this helps?
Posted on Mar 16, 2011
I have a Hp G62 laptop.. From last 3 months, i am getting this error message.. Consider replacing your battery... Tell me some solution..Thanx
Here is the Software through which you can check your battery life.
ftp://hp.com/pub/softpaq/sp54001-54500/sp54256.exe
If this software tell you that you need to replace your battery then you can't do anything other then changing it with new one.
Best of Luck.
Jul 30, 2012 | HP G62144DX Laptop
Everytime I turn on the laptop it says "Insert Smart Card Reader".
Do you want to choose a high quality battery?I can give you some advice.you should Select the battery that made from the Japanese or Korean Li-ion battery cells.Purchase the hp battery only when it is necessary Some of our items have additional option of higher capacity Choose the higher one if there is quality.
Determine it clearly that whether it has pass the CE, UL, Rohs and other approval or not. This will be absolutely good certification for the quality guarantee.If you are considering a few different types of batteries, remember that you can submit forms for more than one type of battery.
The batteries like <a href="http://www.laptopbatteriesinc.ca/compaq-laptop-battery/compaq-presario-b1900-battery">Compaq Presario B1900 Battery</a>,<a href="http://www.laptopbatteriesinc.ca/compaq-laptop-battery/compaq-presario-1500-battery">Compaq Presario 1500 Battery</a> have High quality and cheap price,It would be worth the money spent.
Jan 07, 2011 | HP Compaq nc6230 Notebook
My laptop shows red cross sign in battery and says consider replacing a battery!!what to do does it have any solution and battery life has decreased to 50 min. from 2 and half hour,i bought it just a year...
If the message says consider replacing the battery, I guess the battery life is about to end.
Its good to replace the battery if you have used to laptop for more that 3 years now. Normally that is the max battery life.
However, if the laptop is new and still under warranty, you need to contact your vendor for possible free replacement, since it is abnormal for the battery to wear in such a short time.
Also make sure the replacement battery is perfectly compatible to your laptop. Your vendor can guide you more.
I have replaced batteries in the past. Remove it from the laptop and get the number off of it. Then you can go and Google the number to find a reasonably priced replacement.
Hope this helps you.
Dec 26, 2010 | HP Compaq Business Notebook 2230s
HP Pavilion dv6000z 15.4" Notebook Laptop PC (AMD Turion 64 X2 Duo Core TL-50 1.60GHz, 1GB RAM, 100G... (d6000z) PC Notebook: My battery has become weak and system says conside...
All batteries have a limited number of load cycles, so if your battery/laptop is older or has been used intensively, this could happen.
You can try draining it completely, and then loading it completely, but it will probably not recover completely.
Make sure to save power when running on battery with laptops to maximize the battery life.
May 18, 2010 | HP Pavilion dv6000z Notebook
Message says battery not fully charged but Icon says 100% charged
This machine is roughly 4 years and so the battery does not hold the charge like it used to. It's just suggesting that you should look into a replacement battery that will hold the charge longer than the current one which will give you more time to use the device.
May 06, 2010 | HP Pavilion dv6000z Notebook
Hp 7310 printing with color horizontal streaks across. parts of the artwork are fine, then strirated lines down whole page. changed cartridge color and b/w and says it's installed fine. test page is...
usually when there is a defect on printing out while you have changed the cartridges , you will need to consider changing the printheads of that printer.
Aug 03, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Hp compaq nx7400 - battery died and power cord will not turn comp
Some laptops will not power up with a completely discharged or faulty battery. Remove the battery from the laptop, plug in the power cord and try to boot the system. If the system boots, your battery needs to be replaced. Replace your battery as soon as you can, it's not a good idea to run the laptop for extended periods with an open battery bay.
May 07, 2009 | HP Compaq Presario V2000 Notebook
When should you change out your laptop battery?
Laptop batteries life will vary depending on use. In my experience it is suggested to replace the battery within 3 years. This depends on your requiring the battery.
If you wish to work mobile then a new battery makes your investment a tool, and should be considered.
Apr 14, 2009 | HP Pavilion dv1000 Notebook
Just bought a new hp pavillion laptop. when puttin on charge says 'plugged in not charging' but d battery poer does not increase or decrease?? whats wrong?
Hello
I think your battery is getting old...try consider replacing it...but first try and re calibrate your battery...If its still unsccessful its ok to use the battery but beware that at any moment its likely to go off...try replacing your battery i would suggest.
Nov 25, 2008 | HP Computers & Internet
HEWLETT-PACKARD Hewlett Packard HP Notebook Battery Li-Ion 8-Cell For HDX18 And dv7 Series KS525AA 464059-222 464059222 Logo
83 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
