Question about GE Ovens
My GE electric oven appears to turn on properly, but never heats up. It just stays at 100 degress (preheat), but doesn't acutally get hot.
  • GE Master
  • 8,220 Answers
My oven doesn't heat up
It could be the switch or heating element
Mar 17, 2013 | Thermador SM272 Electric Double Oven
Top oven doesn't heat properly
What is the model number of the unit?
Dec 03, 2012 | Ovens
Oven does not work , the element doesnt glow and the temp never reaches above 100 degress
oven display element supply all working perfectly
only 1 problem i face oven did not heat up...
plz help me quickly
thank you
Regarded
Hannan Ashraf
Sep 02, 2011 | GE Profile JK915 Electric Single Oven
Oven takes a long time to preheat and will not stay heated
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Feb 14, 2011 | GE Ovens
Turn the oven on to preheat, it beeps says that it is preheated but heats at about 100 degrees less than what I have set it for. This just started.
heatman101
Jan 20, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
My oven is not getting hot. The preheat button is staying on.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
heatman101
Oct 27, 2010 | Frigidaire Ovens
Power was turned off. I reset the clock to proper
We have the exact same problem. It doesn't heat to above 135. Help!!
Jan 13, 2010 | Dacor ECS130 Epicure Electric Single Oven
I am attempting to pre-heat oven to 400 degrees but oven heat will not raise above 100 degrees
Hi, Upon reading your post I immediately thought of a bad ignitor for the oven, but I am not sure whether you have a gas oven or a conventional electric range. So...If it is gas, I'd suggest replacing the ignitor for the hot surface ignition. If it's electric the bake element may be at fault although most range's use the broil in the preheat, so it should still climb up to 400, it would just take a really long time. Maybe you can clarify if it's electric or gas and I can try to move you forward from there. Macmarkus :)
Dec 09, 2009 | GE Ovens
SLOW HEATING OVEN
you may want to check your broil element
turn the unit on and wait a few minutes
see if you can feel the heat from the upper broiler elemnet
some model use both elements to preheat
i dont have your productiuon number so i cannot be sure with your model
anyway
14-20 mins is the industry standard for a 350 preheat...
Oct 25, 2009 | GE 30" Built-In Single Electric Wall Oven...
GE Oven MODEL J KP27WOP2 WG - WILL NOT HOLD TEMP
You can re-calibrate the oven as follows;
press BAKE pad.
select temp of 500 degress or more.
immediately PRESS and HOLD the BAKE pad until "00" appears.
Then press the + or _ pad to adjust temp up or down 5 degrees at a time.
When fimished press the Clear/Off pad.
Mar 15, 2009 | GE JTP15 Electric Single Oven
Ovens Logo
178 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
