Question about Cell Phones
I'm beginning to think that there is no solution to my problem with my Phillips VOIP 841 internet phone. However here I go again.When I set up my phone it worked that evening but come the morning instead of my Skype name and credit balance the message " System setting up " was displayed. The only way I could use the internet phones was to switch off the router and base unit power for approximately 30 seconds, switch on and reset the Base Unit power. The phone would then work as it should do. I noticed that when it was working fine there was a Green LED llit just below the RJ cable on the Base unit and when the " System setting up " message was displayed there was another Green Led lit above the Rj cable on the Base unit. Hoping these symptoms ring a bell so that I can sort this phone out once and for all
  • lowflier469 Mar 16, 2011
    Hello. Your E-mail to hand a few minutes ago. My VOIP 841 Base Unit is connected to the Broadband router via an RJ 45 cable. The Router is a 4 port model and the Base unit is the only thing connected to it as my laptop is wireless. The Base unit and the router is connected to the phone line via DSL filter. I can connect the laptop to the router via a RJ45 cable if required as they are very close together. Hope this helps.
    Hello , lowflier469 again. Did you get my reply to your request. I'm not sure if i pressed the right button.
  • Cell Phones Master
  • 12,061 Answers
Hi, yes these symptoms indeed indicate a problem, within the Phone itself, i fear.
http://www.retrevo.com/support/Philips-VoIP841-Telephones-manual/id/2457ci770/t/2/
please find above your user manual, this may provide some setting up assistance if you don't have one at hand.
You see I think what may have happened is that during the time between when it worked, and when you discovered it wasn't, it has developed an internal "Fault" most likely to do with "Handshaking" between the router and your Phone.
These LEDs you describe, are the Connect and activity LEDs usually whenever there is a successful connection and data transfer, one should illuminate all the time, and the other usually Flashes.
Also please avail yourself of the support website below, contact them, and they will assist you. Also if they indeed concur with what I have proposed, they can then tell you what you need to do to effect a remedy to your problem.
Using the manual, perhaps try a step by step reinstall, reset, so remove them from the Power momentarily, the router and phone, now set the phone up, as per instructions... IF after you do this all again, AND there is still NO improvement, then there is NO option but to replace the phone, and see if it works, if the problem is still there then the router may indeed be faulty..
Also check that your router hasn't got any Firmware upgrades outstanding? Also have you made sure that this Phone and this router will actually "Play well together"? as often they will not, often there is a golden list, of things that will work together.. it may pay to check?
see with problems such as this one MUST introduce a new element into the picture to tell which instrument is at fault, substitution often is the only answer, if all else fails.
http://www.philips.com/support
Posted on Mar 17, 2011
  • 1,555 Answers
It's fine you told me your base unit is connected via RJ 45 can you tell me kindly how that wall mounted unit is connected via two wire rj11 or something else. In these type of cases media is important I may ask you to connect the rj 45 to a pc or laptop in order to get the delay.
Posted on Mar 16, 2011
How to do internet settings manually on nokia e71
BEFORE YOU BEGIN, please note the following:
On the Nokia E71 some of VoIP settings are hidden by default, and you will need Nokia's new VoIP SIP application.
This application can be used to configure VoIP settings on your Nokia. You can create new VoIP profiles and modify the existing ones, and create and modify VoIP parameters and NAT/Firewall traversal settings and that are normally not visible on the device UI, such as codec settings and SIP domain-specific NAT/FW settings. It is also possible to save all the VoIP profile settings to a text file. It also enables VoIP over WCDMA which means you can make VoIP call over 3G Internet connection.
Using your PC you can download free Nokia SIP VoIP application from here or you can check Nokia web sitefor latest version.
Extract and install SIS file using Nokia PC Suite software on your PC.
Once installation is complete you will be able to see "SIP VoIP Settings" application under Applications menu on your Nokia, which you will need in STEP 5 of this configuration guide for better voice quallity or enabling VoIP over 3G Internet connection.
Here you can find Nokia E71 SIP settings for voip setup and SIP client configuration guide with VoIPVoIP service.
STEP 1 Go to Tools / Settings / Connection / SIP settings. Create the following profile
Profile Name: VoIPVoIP Service
Profile: IETF Default
Access point: (your WLAN AP name)
Public user name: 5551231234@sip3.voipvoip.com ( Instead of 5551231234 account number example, use the account number assigned to you when signed up for VoIPVoIP service. When recorded your phone will show sip:5551231234@sip3.voipvoip.com )
Use Compression: No
Registration: "Always on "
Use Security: No
STEP 2 You do not need to enter Proxy Server settings
Proxy Server Address: none
Registrar Server:none
Realm: none
User Name: none
STEP 3 Enter the following for Registrar Server settings
Registrar Server: sip3.voipvoip.com (When recorded your phone will show sip:sip3.voipvoip.com)
Realm: voipvoip.com
User Name: 5551231234 (Instead of 5551231234 account number example, use the account number assigned to you when signed up for VoIPVoIP service. )
Password: Enter the password that you chose when you signed up for the service.
Transport Type: UDP
Port: 5060
STEP 4 Go to Tools / Settings / Connection / Internet Tel. Settings
Create a new profile for "voipvoip"(555123xxxx), name it "voipvoip"
Choose "voipvoip" as Preferred profile
STEP 5 For better voice quality or in order to be able to make VoIP calls over 3G internet connection you need to use Nokia SIP VoIP Application you installed.
Go to Applications on your phone and click on "SIP VoIP Settings" application. Choose VoIP services/VoIPVoIP (or the name of your VoIPVoIP account Internet profile.)
Click on "Profile Settings" and find "Allow VoIP over WCDMA" option and change it to "ON" This change allows VoIP over 3G connection on Nokia phones.
For better voice quality go to Codecs and delete all codecs except G729. There should be only G729 codec left under codecs setting
STEP 6 Reboot your phone. Once your phone is back on it will automatically register to VoIPVoIP.
Once it is registered you can start making calls.
Default call type: To switch between normal GSM calls or VOIP calls, navigate to Tools / Settings / Call / Default call type. Select Cellular to make normal calls to the phone number or Internet to use VoIP to call the number or address
Make Calls!
To dial any phone number that is part of the NANP (North American Numbering Plan), you must dial:
1 + Area Code + Phone number
To dial any phone number that is outside of the NANP (North American Numbering Plan), you must dial:
Country Code + City Code + Phone number
For example if you want to call Brazil (country code 55) phone number in Rio de Janeiro (city code 21) you must dial 5521 and phone number. + sign can also be used and number can be dialed as +5521xxxxxxx
BUT RATHER THAN FOLLOWING THESE PLS CALL TO YOUR CUSTOMER CARE THEY WIL GIVE THE SETTINGS. SAVE THEM. THEN FOLLOW THE INSTRUCTIONS. THIS DOES NOT COST ANY COST. PLEASE TRY THIS
Jul 07, 2010 | Nokia E71 Smartphone
Tip
How to reset your VOIP modem
If you are having trouble connecting to the internet, please try these steps.<br /><br />1.Unplug the power to your modem. This is the box from your cable or DSL provider. <br /><br />2.Unplug the power to your VOIP phone adapter. If you don't have one skip this step. <br /><br />3.Unplug the power to your router. Wait 45 seconds, then Plug in your modem and wait for lights to stabilize on a specific pattern. (Usually takes about 1 minute) <br /><br />4.Plug in your VOIP phone adapter (if you have VOIP service) and wait until you have a dial tone on your phone again. If you don't have VOIP or know what VIOP is, skip this step.<br /><br />5.Plug in your VOIP phone adapter (if you have VOIP service) and wait until you have a dial tone on your phone again. If you don't have VOIP or know what VIOP is, skip this step. <br /><br />You may need to restart your computer for this to work :)<br />
on Mar 16, 2011 | Computers & Internet
Tip
VOIP works
At its best basal level, <i>VOIP</i> artlessly break bottomward calls and encodes them into packets that can again be transmitted over the internet. When they get to the advised recipient, they are again reassembled into sounds for the listener. <br /> <br /> The affection of the complete will depend on the codec's acclimated to encode the sounds and factors such as the affection of the connection.<b>IP phones</b> can now be begin in abounding forms.<br /> <br /> There are ATA phones that assignment through a affiliation amid the net and absolute blast jacks, those that affix through any <i>Wi-Fi</i> or <b>Ethernet access</b> and <b>softphones</b> that assignment throughcomputer application installed on a <b>computer</b>.
on Dec 26, 2010 | Computers & Internet
Phillips voip 841 mac driver
i use this phone via a mac. i don't recall any driver being necessary. but check philips website. type 841 into search box and then click software and drivers. link below.
good luck
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=CA&slg=ENG&cat=INTERNET_TELEPHONY_DEVICES_CA&sct=DUAL_PHONES_SU&session=20090612180105_70.79.183.10&grp=PHONES_GR&ctn=VOIP8411B/37&mid=Link_Software&hlt=Link_Software
Mar 24, 2009 | Philips VOIP8411B/37 IP Phone
Philips voip 841: no sound on skype calls, but fixed line works f
We have had this issue recently as well with both our parents and now our own.phone.
Simple solve I found here:
1. Remove batterys
2. unplug base
3. replug in base
4. Put batteries back in
Worked for us - must be a virus or something
Feb 16, 2009 | Philips VOIP8411B/37 IP Phone
Philips VOIP 841 - Change Skype Account
Your skypin number should be associated with an account on skype. So all you have to do is to login using the associated account when you turn on your phone, do this by using the phone's controls to enter in your skype account and password.
Dec 20, 2008 | Philips VOIP8411 IP Phone
Philips VOIP 3212
The VOIP321 from Phillips does NOT connect to your wireless router. It requires to be plugged into a USB port on a WINDOWS ONLY desktop computer, which needs to be left on/logged-in with Skype running to send and receive calls. It wont work with Vista either.
Additionally Since Skype Version 3.8.0.188 (Release date: November 19, 2008) and all later versions (including Skype 4 Betas) the software Phillips supply no longer works with Skype and the VOIP321 phone. The latest VOIP321 <a href="http://tinyurl.com/6b2xrp" rel="nofollow">driver from their website</a> suffers the same issue, even though it states "The VOIP321 USB Phone Driver V 3.8.3 which can be downloaded from Philips web site is compatible with Skype software version from V2.0.0.x until V3.8.0.x". This is plainly no longer correct with the latest stable release of Skype, V3.8.0.188.
Skype developers are <a href="https://developer.skype.com/jira/browse/SPA-599" rel="nofollow">unable to do anything about it</a> and Phillips wont update their driver (Quote "... no more development/fixes are being incorporated into the VOIP321.EXE file"). Phillips would probably rather sell you a newer bit of hardware.
Don't waste your time on Phillips Skype phone devices, as their driver support is lacking when Skype is updated, so you buy a product for a few hundred dollars and it becomes useless 12 months later.
Another reason to not purchase the Phillips Skype phones is that it is Windows Only. No Mac or Linux support or drivers offered.
Dec 16, 2008 | Philips VOIP3212 IP Wireless Phone
Skype phillips voip 841
Unplug power cord of base , then power on.
Also unplug the handset battery , and set the battery back .
Basically, it is software jam
Sep 29, 2008 | Skype IM
I have an Arris modem TM502g. internet and cable TV are working fine but I have no phone service. all the LED lights are blinking except for the 2 telephone lights and they are solid green.I have tried...
Hi sorry about the chat session the other day, i was not able to see your chat message so I end the session, but to help you with your concern, since internet is already working, then the problem here is the VoIP settings on your modem (since you said it has phone ports on the modem), usually resetting the modem wont change the VoIP (Voice over IP) settings. It would be better if you ask you VoIP provider to check if the modem's VoIP settings is setup correctly. If yes, and you have internet with the modem then upgrading the firmware may help.
If you dont have a VoIP provider then you need to get one in order for the phone line to work.
If you already have one, then contact them so they can configure the VoIP settings on that modem.Get your money's worth with their service
Sep 20, 2008 | Computers & Internet
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
