A problem has occurred and windows as been shut down to protect my computer.
  • 981 Answers
Joined the club of 99% of Windows users, you have. It's common, it's sometimes related to drivers, sometimes it's just a soft error, and what you do is to start Windows up again. It is a classic fall down/get back up.
So it's obvious you misfiled the problem. It's a Windows issue, not a PC Desktop problem. You can install another OS and learn about it instead, with no loss in your petty investment so far, and there are many good choices.
If it gives you that error again immediately, start up in safe mode and see if things get any better; if so, you can go determine which driver has somehow gone bad on you (perhaps a soft error during disk write caused it,) if not, it could be a stopped fan, dusty box interior, RAM that has crept out of its socket somehow, or other common problems.
Posted on Aug 02, 2008
My notebook shut down while i was using it the message that comes up is your computer was shut down to protect your computer
That's not any Windows feature I've ever hear of. I think you have a virus. Try starting in Safe Mode and running a virus scan.
Apr 10, 2011 | Computers & Internet
Please help how to unwrite protect my kingston 4gb flash drive
There are two steps:-
Step1:-
You can remove write protection from your usb flash drive using the below method:
1. Open start menu, in the search bar type regedit and press enter. This will open the registry editor.
2. Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Note:
If the registry key StorageDevicePolicies does not exist, you will need to create it manually.
3. Highlight StorageDevicePolicies, and then create a New DWORD (32-bit) Value named as WriteProtect.
4. Double click the key WriteProtect in the right window and set the value to 0 in the Value
Data Box and press OK button
5. Restart your computer and try copying files into your USB drives.
Registry Disclaimer:-
Sometimes this problem is caused by two Windows registry entries that have become corrupted. To fix the problem, you have to use Registry Editor to delete the corrupted registry entries.
However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs.
For more information about how to back up and restore the registry, follow the steps as in the KB Article:
http://support.microsoft.com/kb/322756/
Step2:-
If the issue persists, check what happens in safe mode.
Here are the steps to boot the computer into safe mode:-
1. Remove all floppy disks, CDs, and DVDs from your computer, and then restart your computer.
Click the Start button; click the arrow next to the Shut Down button, and then click Restart.
2. Do one of the following:
•If your computer has a single operating system installed, press and hold the F8 key as your computer restarts. You need to press F8 before the Windows logo appears. If the Windows logo appears, you'll need to try again by waiting until the Windows logon prompt appears, and then shutting down and restarting your computer.
•If your computer has more than one operating system, use the arrow keys to highlight the operating system you want to start in safe mode, and then press F8.
3. On the Advanced Boot Options screen, use the arrow keys to highlight the safe mode option you want, and then press Enter. For more information about options, see advanced startup options (including safe mode).
4. Log on to your computer with a user account that has administrator rights.
When your computer is in safe mode, you'll see the words Safe Mode in the corners of your monitor.
Refer this link for more information.
"Start your computer in safe mode"
http://windows.microsoft.com/en-US/windows7/Start-your-computer-in-safe-mode
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 14, 2011 | Computers & Internet
My usb transcend jf v30 4gb is write protected
Step1:-:-
Note:
Step2:-
Hope this helps.
Cheers!!!!
Jan 12, 2011 | Transcend (589307) Media
I was running the program "windon Defender" on it and walked away. When I returned the computer was off and wasn't turn back on.
The Windows Defender Application is the Antivirus Software which will be pre-installed with the Windows Operating System(Windows Vista, Windows 7).
The Computer will always Shut down after any Windows Updates or any Operating System Updates are downloaded and installed.
If you are connected to the Internet and running Windows Defender, the Computer will automatically download the Updates for the Windows Defender Application.
Once the Updates are downloaded and installed, the Computer will prompt for a shut down.
The count down will be for 10 seconds.
After 10 seconds, the Computer will install the downloaded Updates and shut down.
This might be the reason for the Computer to shut down while using the Windows Defender.
If the Computer still shuts down randomly, the issue might be due to overheating.
All the Processors in Notebooks are designed to shut down automatically, if there is any overheating issues.
The overheating issue mainly occurs due to the malfunction of the Cooling fan.
If the Computer shuts down frequently, the issue might be due to the above factors.
It would be better to get the Unit examined at the Service Center.
Jun 22, 2010 | Acer (56.04145.901) (5604145901) Power...
My pc has been giving me problems for a while. It stops functioning and goes to a blue screens that says that an error has occured and that windows shut down to protect the computer.
hi,
your system might be infected with virus or spyware.
scan with good anitvirus you can use this links
http://www.bitdefender.com/scanner/online/free.html
even though it giving problem format the system and install fresh OS .
I hope this will resolve the issue.
Jun 18, 2010 | E-Machines eMachines Desktop PC
Usb is write protected
Hello heavenly_157 !
Thank you for writing to us. The solution to this problem is little tedious; So go throgh with the steps I am suggesting before you perform them.
Step1:-:-
Note:
Step2:-
“Start your computer in safe mode”
These steps can be followed on Windows Vista or Windows Seven only.
Hope this will help.
Regard's
Anurag
Mar 13, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Samsung ht-x30 sutting down protection error
My samsung shuts down with "PROTECTION".Help me to solve the problem.David ilomo.
Dec 05, 2009 | Samsung Audio Players & Recorders
Shut down problem
you should change CMOS battery.
Feb 04, 2009 | Microsoft Windows XP Home Edition
Window shut down automatically and restart, then shut down again... It happened after a window update yesterday lunch time.
Recovery SettingsOne of the things that is quite different about Windows XP compared to Windows 9x (9x is shorthand for Windows 95, Windows 98, and Windows Me in all their various versions), is that one can control how it responds to certain critical errors—those that cause the infamous Blue Screen of Death (BSOD). In Windows XP, the default setting is for the computer to reboot automatically when a fatal error occurs. If that fatal error only occurs when you're shutting down, the system reboots automatically.
If you haven't changed any of the system failure settings, you should be able to see the error by looking in the Event Log. But a better long-term solution is to turn off the automatic reboot so you can actually see the error when it happens—chances are it will tell you enough about itself to let you troubleshoot further. To change the recovery settings to disable automatic rebooting:
1.
Right-click My Computer, and then click Properties.
2.
Click the Advanced tab.
3.
Under Startup and Recovery, click Settings to open the Startup and Recovery dialog box.
4.
Clear the Automatically restart check box, and click OK the necessary number of times.
5.
Restart your computer for the settings to take effect.
Now when you go to shut down and a fatal error occurs, you'll at least see it and it won't cause an automatic reboot. You still have to sort out what's causing the problem, but that gets us to the next section quite nicely.
Nov 04, 2008 | Computers & Internet
Compaq 7500 hard drive rebooting over and over
the same problem is occurs in my friend computer.
and this is due to Virus.
I think u have to format your harddisk and reinstall window.
May 14, 2008 | Compaq Computers & Internet
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
