I have an LG425000-ZA LCD tv and when turned on in the morning the left hand side of the screen is quite dark after around 5mins the picture is fine but then sometimes after the tv has been on for hours the left hand side will once again dip into darkness. If I turn it off and on this will sometimes resolve the issue. The TV has just run out of warranty (typical) and i'm sure if we replace the inverter board things will be ok, but i just have a niggling doubt that there maybe some other power issue at play here - could you please deliver the fruits of your wisdom - thank-you.
    Top Expert:
  • Televison & ... Master
  • 74,999 Answers
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Posted on Apr 23, 2017
  • 245 Answers
SOURCE: Hitachi 32'' lcd tv picture runs slow sometime and goes dark
go in touch wit HITACHI costumer help and service and tell them ur problem u old is ur TV?
hope u get a answer from hitachi....and good luck
Posted on Mar 12, 2009
  • 52 Answers
SOURCE: The left side of the screen got very dark after
Sounds like the inverter for the panel for the left side is defective.
Posted on Nov 14, 2009
  • 245 Answers
SOURCE: daily for about 5mins 12inch fon the left hand
go in touch with samsung service center and tell them ur problem after all the set is only 12 months old and they may fix ur problem without a charge
Posted on Nov 28, 2009
  • 8457 Answers
SOURCE: I have a Pansonic TH-50PX60u.
This problems are the 2 Buffer boards X or Z is dead.Sorry must hire a tv to troubleshoot and change the wright one.Could be etheir one or both.
Posted on Jan 15, 2011
  • 2080 Answers
SOURCE: I have a SANYO DP46848,
This is likely a problem with your TCON circuit board inside the back of the tv.
The TCon board usually has 2 (or 4) very thin ribbon like cables running from connectors on the board to the actual LCD screen panel. Each ribbon controls one half (or one quarter) of the screen. If you are lucky, it's possible one of the ribbons came loose or is not making proper electrical contact with the connector on the TCON board.
If your tv is out of warranty and you are comfortable working safely with electronics then you may be able to repair this yourself with a few hours of screwdriver work. The ribbons may just need to be reseated in the little flip up connectors, or you may have to clean the copper at the tips of the ribbons gently with a pencil eraser to remove any oxidation.
If you are unlucky enough to have a bad TCON board or are not comfortable disassembling your tv yourself then you can bring it in to the shop and they can probably repair it for less than $150.
Good luck and please post back with how you make out.
Posted on Jan 25, 2011
Half the screen isa dark, left side
Most likely you have a faulty LCD panel tabs. This can be verified sometimes by turning set on and tapping or squeezing the top left side of the TV. The only true fix is to replace the panel. I've been told that Samsung may offer to replace the panel or give you a discount on a new TV. Samsung is know to have LCD panels with premature tab failure. So it may be worth while to contact Samsung and see what they can do for you. There are videos on youtube that show case the problems and show you how to patch the problem. just type in "LCD panel tab" in the youtube search box.
Feb 17, 2013 | Samsung LN46A550 LCD TV
Samsung TV Screen faulty
t con board failed if its half and half. can also be a lose cable on the screen to the tcon board from the lcd screen side. Tcon is in the middle off the screen on the back.
Nov 18, 2012 | Samsung LE46M51B 46 in. LCD Television
Dark line down the middle of my flat screen tv
Most LCD and PLASMA sets use two boards (some combine them into one board) that drive the Display Panel (the entire front screen unit) so I would suspect one of yours is bad.
The other unpleasant possible cause is where the left board is connected to the Display Panel (entire front screen unit) you have a problem inside that Display Panel and that is fatal as there is no way to get INSIDE the panel---it can cause both lines and a dark picture on one side of the screen.
May 25, 2012 | Sylvania Televison & Video
I have an LG 42" LCD tv with blurred image on half the screen
lg 42 in lcd tv power button blinks nine times before staying on and has sound but no picture
Feb 04, 2010 | LG 42LC2D 42 in. LCD HDTV
Daily for about 5mins 12inch fon the left hand
Nov 28, 2009 | Samsung LA46A550 46 in. HD-Ready LCD TV
Left side of television just started having a shadowing problem?
I have the same problem and was told by a technician that I need to replace the light engine. Probably around $ 700.00.
Oct 15, 2007 | Samsung HL-R6167W 61" HDTV
Televison & Video Logo
94 people viewed this question
Top Televison & Video Experts
