Question about Dewalt 18v Battery Hammer Drill Dcd950 Dc925
What are the numbers around chuck used for? - Dewalt 18v Battery Hammer Drill Dcd950 Dc925
  • 8,404 Answers
They refer to the relative tightness of the adjustable built in clutch. The lower the number, the less torque is applied before the clutch starts to slip. At the drill image on the ring, there is no slippage.
Why would you want such a thing??? Well because you don't want to strip a screw yo are installing or possibly break it. Whether you are putting small screws into soft wood or you are installing "TapCons" in concrete, this is a very good feature to have on your DeWalt or other fine battery powered device.
I hope this answers your question ... Please remember to rate this answer. The rating is the only "pay" I get here as a volunteer question catcher./
Thank you for your interest in FixYa.com
Posted on Mar 16, 2011
Any one know where a chuck for Hitachi Power Tools Ds14dvf3 can be purchased, it is a discontinued item, and no parts seem to be around? OR is there a universal chuck that could be used in this drill?
I'm hoping you mean a chuck "key" .... there are only 4 different sizes and can be bought in tool stores as universal chuck keys tool 4 in 1 tool...
May 14, 2017 | Hitachi Drills
How do I remove the keyless chuck on my 14.4 cordless B&D drill
The chuck is held onto the shaft with a Philips screw. Open the chuck, insert the screwdriver and turn CLOCKWISE to loosen the screw. The chuck will still be connected to the outer thread on the shaft. Slide the drill direction slider to the middle position to lock the motor. Put an Allen key in and close the chuck around it. You will now be able to use that to twist the chuck off.
Sep 14, 2016 | Drills
How to remove a drill bit from insert of screw that holds on driver on an elecctric drill?
do you have the "chuck key"? this is the tool you will need to undo the chuck (part which holds the drill bit). it is often stored in holder in handle of drill. If you dont have chuck key you can improvise using 2 slot head screwdrivers: insert one into one of the 3 holes around chuck, then insert the other into the teeth around check and lever against the 1st screwdriver.
Apr 06, 2015 | Drills
I can not change the drill bit. Do I need another tool?
that depends on whether or not you have a keyed or keyless chuck. if you have a keyless chuck then you do not need another tool you must turn the chuck counter clockwise to loosen the chuck and replace the bit. if you have a keyed chuck then you will see three holes around the chuck of the drill ie the part that holds the bit. just below the holes you will see teeth spaced evenly around the drill. a chuck key allows you to put the end of the key in one of the holes and using the teeth you turn the chuck key thereby loosening the chuck and allowing you to change the bit. if you have a keyed chuck just take it to your local hardware store and they can provide you with the correct key and show you how to remove the bit. if your chuck is keyless the hold the chuck put the drill in reverse and pull the trigger use a glove to protect your hand
Feb 24, 2011 | Drills
I cannot open a Dewalt 954 cordless drill chuck. My socket adapter is stuck in the chuck. It is a borrowed tool and I need to return it in the same shape that i received it. Help. No TWO men can exert...
if it is a keyless chuck soak the inside of the chuck with oil. charge the battery so you have max power. put a cloth around the chuck and use a pair of channel locks to hold the chuck and put the drill in reverse. good luck
Aug 21, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
How do i remove the chuck from a Makita 8391D
I think you will find that if you open the chuck fully you will see a cross head screw inside the chuck which you need to undo before removing the chuck. this secure the chuck from unscrewing while being used in reverse to undo screws. Once this screw is out a spanner is used at the base of the chuck to unscrew it from the shaft. this may need a short sharpe shock to get it to move.
Jul 31, 2010 | Makita Drills
A bit is stuck in the chuck of my Bosch drill
Hello. Wrap a towel around the chuck and use a pipe wrench or a pair of channel locks to put a little force on the chuck. J.
Jul 19, 2010 | Bosch Drills
My AEG 630 watt drill SBE630RX. The keyless chuck is seized and will not release drill bit. This is used on a regular basis if this is any help. Many thanks. Trev
The cover on the chuck must be removed by using a punch, tapping around the drill side. this will pop off the cover exposing the jaw's. then use a channel lock and or bench vice on wheel that surround's jaw's. if the chuck is no good it may have a left hand screw in the bore that must be removed to take chuck off.
Apr 20, 2010 | Drills
Jammed chuck
wrap cloth or something around chuck to protect it a bit and using multi grips try to free up .if chuck is faulty youll need to get to left hand screw down inside the chuck to remove it. good luck some are very tight.
Nov 17, 2009 | Bosch BRUTE TOUGH?? 18 Volt 1/2?¶ Drill /...
How to onlock the keyless chuck of my cordless dc988ka drill it was lock to open position
if the chuck is rusted start with some WD-40 on the chuck body. Then what I would do is take a rag and wrap around the chuck collar and using a pair of channel locks grip the collar with enough pressure to hold but not break it and using the tool in the low position pull the trigger switch SLOWLY and see if that doesn't free up the chuck. Let me know if still stuck and I will come up with something else, but this usually works for me.
Jun 10, 2009 | Dewalt DC988ka 18 - volt XRP 1/2''...
Dewalt 18v Battery Hammer Drill Dcd950 Dc925 Logo
235 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
