Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Error c 2451 after fuse transfer unit - Konica Minolta bizhub C250 All-In-One Laser Printer
  • secser Mar 16, 2011
    "terminals on the drive circuit is closed"
    on the terminals of the unit transfer the circuit is closed
  • 77 Answers
Plz change the fuse
Posted on Mar 16, 2011
    fuse replaced problem no resolved
  • Umair Ilyas Mar 16, 2011
    check ur circuit is circuit is ok or not
Konica minolta c280 showing error codes 3423, 3334 and 2451 How can I clear the codes
2451 replace the cyan (Blue ) Image unit
3423 replace the fuser unit
3334 No such code
Jan 09, 2017 | Konica Minolta Bizhub C280 Color Copier /...
Error code c-2451
If you wish to get some details; check the site linked here. Pull up older posts. Surf for article abort printers.
http://electro-medical.blogspot.com/
Jan 15, 2016 | Konica Minolta bizhub Office Equipment &...
How can I resolve error code C-2451
Release new transfer belt unit
• A new installation is not detected when a new transfer cleaner unit (image transfer belt unit) is installed. Remedy 1 Reinstall unit. 2 Check there is a short circuit in the fuse of the transfer belt unit. 3 Check the PRCB connector for proper connection and correct as necessary. 4 Change PRCB
Feb 02, 2015 | Konica Minolta Bizhub C550
Error code r80
what is the equipment that is giving you this error?
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Aug 21, 2014 | Office Equipment & Supplies
Error 2451
Sir did you remove all of the tape from the transfer belt. when you installed it the the code has to do with new belt. Pull it out and check for any thing odd.
Apr 21, 2010 | Konica Minolta Bizhub c203 Copier
Konica Minoltra Bizhub C250 Malfunction detected C-2451 This message I got after I changed fuse on transfer unit. How to solve it, or at least what this error code means?
hi, from the service manual:
C2451:
Item:
Transfer Cleaner Unit New
Article Release
Description:
Transfer Cleaner Unit (Image Transfer Belt Unit) is
installed.
for the solution, SM says you should try refitting Transfer Cleaner Unit(misplacing could occur) or change the PWB-M board.
Feb 09, 2010 | Konica Minolta bizhub C250 All-In-One...
Magicolor 2200 DL - replace transfer belt
Is this an error 16 rorate problem? It does seem weird that you still get it having replaced the transfer unit.
However the printer does have a nasty habit of not re-setting things correctly - it creates the error message by blowing a fuse on the unit and it has been known to do this even when a new unit is put in.
There are a couple of places on ebay that sell a kit that explains how to get to the fuse and they supply a new fuse. It appears to be a 1/4 amp slow blow fuse
To get at it you will need to unscrew a black plastic plate at one end of the transfer unit (it is the one that has a square hole with the main electrical contacts poking through. Loosen the 2 screws and remove. the fuse is on a small circuit board that is easily removed. replace teh fuse (needs soldering) and this might do the trick. If you have a tester might be worth removing the small circuit board (wire connector comes off easily) and checking.
This fues usually blows when the transfer unit is old and a sensor unit gets clogged up. However even when teh sensor and the band at the side of the belt has been cleaned the fuse still sometimes blows.
This might solve the problem.
Sep 26, 2009 | Minolta QMS 2200DL Laser Printer
C-2451 on bizhub c450
C2451: New Transfer Cleaner Unit resetting failure
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
Nov 30, 2008 | Konica Minolta bizhub C250 All-In-One...
Konica c6500 c-2451 error
C-2451 - When the developing motor/Y
(M20) is ON, the maximum
detection value of TCR sensor/Y
(TCRS/Y) is the specified value
and the difference between the
maximum detection value and
the minimum detection value is
over the specified value.
relavant parts:
Printer control board (PRCB)
Developing motor/Y (M20)
TCR sensor/Y (TCRS/Y)
- first check that the motor is turning correctly, clean sensor, check toner pipes, that the toner is rally moving from hopper to developing unit.
May 07, 2008 | Konica Minolta bizhub C250 All-In-One...
i think that your fax is not set up right, or maybe the machine is missing admin and machine e-mail address, that can cause too this problem.
Dec 12, 2007 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
867 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
