Whenever i charge my k810i, Charging Error, STop charging! always appear on the screen
  • 77 Answers
On charging point the copper or mouser is coming plz clean it and then charge or change the charger
Posted on Mar 16, 2011
My SE w595 appeared 'Serious error. stop charging. stop using the phone. Contact Sony Erisccsion call center' message15 minutes after I start charging the phone. It also can't receive SMS since this error...
The phone told you what to do. Don't charge it, don't use it, and call their support center. 1 866 766 9374 (Toll Free) - 1-877-7XPERIA (1-877-797-3742) should get you moving in the correct direction.
Apr 11, 2011 | Sony Ericsson W595
Dear Sir, I own K 790i, whenever i put for charing i get an error message stop charging error, i have tried charging through differenct sockets still error message continues but when i charge through my...
If its charging on your computer,then the problem is the charger itself.
The first thing to do is try to check you charger and its terminal,pins might not in align or corroded,otherwise buy original sony ericsson charger.Also check the charging terminal of your phone. you can clean it using brush or a pin and scratch each portion so that the power voltage will some it.
Apr 04, 2011 | Sony Ericsson K790i Cellular Phone
After charger is inserted , charging lights come on and battery indicater shows that is charging . After some time , an hour or so , a charging error message appears and says to stop charging . I purchased...
this problem was relating to your phones charging ic to solve this problem please change the charging IC WITH THE HELP OF A HARDWARE MECHANIC
Oct 22, 2010 | Cell Phones
Phone not charging,display says error stop charging
If your phone is not charging and the screen read error stop charging, you can look at the problem from angles, firstly, i suggest you try get a similar charger to charge the phone and see if it will charge it, if it does, it means the charger your charger is the problem and will need to be replace.
But, if after trying to charge with a similar charger and the screen of your phone still reads error stop charging, then, the problem is the charging port of your phone. In this case, you will need to replace the charging port of your phone, in order for your phone to charge.
Check either of the two stated above to solve the problem with your phone.
Take care.
Jul 17, 2010 | Sony Ericsson Z610i Cellular Phone
I am not able to access my cell because of stop using, stop ncharging error..
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Secend Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jul 11, 2010 | Sony Ericsson W350i Cell Phone
When charging my w595 after only 1 minute a message appears on the screen saying serious error stop charging stop using your phone and contact a sony ericsson call center
You are using a wrong charger that is not original. Please change the charger or use a universal charger, you may damage your phone if you insist
Jun 06, 2010 | Sony W595a Cell Phone
My K810i phone doesnt turn on..
let it sit in the charger for 1hour then try to turn on your phone. it could be that the charger cannot charge the battery and turn on the phone at the same time and the battery is too weak to turn it on and needs a better charge.
Nov 11, 2009 | Sony Ericsson K810i Blue Smartphone
Serious error contact Sony
This should be a hardware problem. Take it to the Sony Center.
Oct 30, 2009 | Ericsson SCREEN PROTECTOR MEXXPROTECT...
I have a Sony Ericsson k810i phone since April 2008.Today I connected my cell phone with my pc via usb connection.My phone was turn on and I had choose the "operate as a cell phone" application on the...
First thing is never remove the cable without stopping the USB connection from system tray. Now, as your phone has gone kaput, you will have to re flash the firmware. Checkout some SE forums like esato.com,se-nse. Use a memory card reader to copy the contents of your m2 and don't keep it inserted in the phone while flashing.
If your phone is still under warranty, i suggest you take it to the service center.
Jan 10, 2009 | Sony Ericsson K810i Blue Smartphone
Computers & Internet Logo
98 people viewed this question
David Payne
David Payne
