Question about IBM ThinkPad R50e Notebook
Why my computer mouse freeze? - IBM ThinkPad R50e Notebook
    New Friend:
  • 46 Answers
I hope you are using Windows 7 because i do, i ran into same problem before and i was able to find the solution on internet with the help of a website. hope this help you. Mouse Freeze Problem
Posted on Apr 29, 2011
    Problem Solver:
What operating system on laptop?
pre windows xp was a common problem I had
turned mouse switch on and off and sometimes regained mouse. switch is usually right by mouse pad to either use pad or external mouse. I am by no means an expert but had problem like that. Also had the dreaded blue screen of death till went to XP and now have windows 7. Well hope that helps some>!!
Posted on Mar 16, 2011
Nextech mouse through usb continues to install successfully, then freezes while trying to move about my laptop! No, it is not that the Lptp is working in the background, leaving the mouse to freeze th
Step 1:
For a standard trackball mouse, unplug the mouse, turn it over and then twist the retaining ring counter-clockwise to remove it. Remove the trackball inside the mouse. Clean the trackball with warm water and dry carefully. Clean the rollers inside the mouse with a cotton swab dipped in rubbing alcohol. Replace the trackball, then secure it with the retaining ring. Clean the outside of the mouse with rubbing alcohol and a cotton ball. For an optical or wireless mouse, clean the bottom of the mouse and the surface it sits on with a damp cloth. Solve Hardware Problems Make sure the mouse is connected properly. The connector will either be USB or PS/2. A PS/2 connector is color-coded green and can only be inserted in one direction. Check for any bent or broken pins or damage, then carefully plug it in, making sure the connection is secure. Reboot the computer. Connect the mouse to another computer, then reboot the PC. If the mouse works after testing it on another computer, the problem is most likely with your PC or operating system. Also, try a different mouse on your computer. If there is no PC freeze, your mouse is probably malfunctioning. Switch to a different USB port. Sometimes mouse freeze will occur if the mouse is connected to a USB hub. Connect the mouse directly to one of the USB ports on your PC. Try different ports until you find one that works. Replace the batteries. If you have a wireless mouse, replace the batteries with fresh ones. Also, try using a different kind of mouse pad. Sometimes surface imperfections can interfere with the operation of a wireless or optical mouse. Install more RAM or memory. If your PC doesn't have enough memory, PC mouse freeze may occur when you are running resource intensive programs. Installing more RAM will help your PC run more efficiently. Solve Software Problems Check for device conflicts. When you install another device on your computer, it can sometimes conflict with a PC mouse. Remove any new hardware and drivers you may have installed, then reboot the computer. Reinstall PC mouse drivers. In Windows, open "Control Panel" then "System." Select the "Device Manager" tab, then scroll to and select your mouse. Uninstall any drivers that are listed. Unplug the mouse and reboot the PC. Plug the mouse back in, reboot the system, then allow Windows to reinstall the drivers if prompted. Remove viruses. PC mouse freeze and other serious problems can be caused by viruses lurking on your system.Set the program to run a complete scan every 24 hours. Also make sure the virus definitions are updated regularly. Turn off video acceleration. Sometimes video acceleration can cause PC mouse freeze. Go to "Control Panel," then click "Display," and then "Change Display Settings." Click the "Advanced Settings" button, then the "performance" tab. Set the acceleration slider to "None," then reboot. Repeat the process moving the slider up one notch until you have the maximum amount of acceleration with no mouse freeze
Feb 18, 2013 | Computers & Internet
Cursor freezing
Remove viruses.
hope this helps
Oct 09, 2012 | Sony Vaio VGN NS20E Laptop Car- Air DC...
Mouse will not unfreeze after i put router on my computer
Take the router off and see if it unfreezes. I doubt that your router has anything to do with your mouse freezing. I would say you might have a virus or infection so run a scan. Also you mouse might be going bad.
Try booting up in Safe Mode and see if your mouse freezes. If it does not, surely a virus or infection is attaching your mouse.
Make sure you are not pulling the mouse out of the computer if the end that goes into the computer's green port is round. The round mouse (PS2/Serial) cannot be pulled from the computer and expected to work unless you reboot.
The Flat USB mouse (the end that plugs into the computer is flat) is a plug and play mouse and can be pulled and reinserted into the computer without rebooting.
Apr 11, 2012 | Computers & Internet
Mouse will freeze using Ubunto linux
Hook the mouse up to another computer. If it works without freezing then you'll need to go into Ubuntu and see what programs start up when you go into Ubuntu and disable some of them so it frees up memory.
If the mouse freezes up on another computer then the batteries are going weak and you'll need to replace them.
May 14, 2011 | Wenger DAYTONA II Mouse
My Gigaware ubs mouse keeps looking up, how do I stop this?
You should try replacing the batteries in the unit, if it still freezes after that, try unplugging and replugging the wireless receiver. If it still freezes, try it on a separate PC. If it freezes still yet on a different computer, then you know the mouse has a hardware problem and should be replaced. If it doesn't freeze on the other PC then you will need to reinstall the software for the mouse on your main computer.
Sep 09, 2010 | Ultra Max Gigaware Wireless Laser Mouse
The mouse froze up
Hi
First try rebooting your computer and see if it works.
else
Take a look at how many programs you have open when your mouse freezes up. If you are running multiple programs at once and have limited RAM, this can be a major cause of mouse freezing. The solution is either run fewer programs or simply purchase additional RAM.
You also want to make sure your mouse drivers are up to date. In these cases simply go to the manufacturer website and check for any driver updates you may have missed out on.
But the most common cause of mouse freezing is due to errors in the Windows registry. The registry contains settings and commands that are utilized by the mouse to run properly. When there are errors in the registry this can cause a breakdown in the communication between your mouse and system. When your computer cannot communicate properly it will lock up or freeze.
Unfortunately there is no way to manually fix this problem. The registry is an extremely complex directory that is also sensitive to alterations. If you adjust or remove the wrong registry files your entire system can collapse.
This is why I highly recommend scanning your computer with a top flight registry cleaner. Not only can it fix mouse freezing, it will also speed up your computer considerably. So stop asking why is my mouse freezing. Scan your computer for free below and fix the problem today.
Sick of your mouse freezing up? Want to repair computer errors the easy way? Scan your computer for free and fix corrupt registry problems with the #1 registry cleaner on the internet. After scanning your computer, I promise you will be quite surprised by all the errors on your system.
http://www.registry-clean-up.net
Jul 29, 2010 | HP Compaq Presario CQ60615DX Notebook
Why does my mouse freeze?
Possibly a bad mouse.  Either try another mouse on that same port or try that mouse on another computer.  If you want to, try that mouse on another USB port on your computer
Mar 07, 2009 | Logitech Wheel Mouse Optical
PM2F 100005615 Mouse
When you start up, have to mouse on the one that freezes and then switch off that one. (turn on the one that freezes first and have the mouse set it. then once it is on boot the other one and then switch mouse.
Nov 26, 2007 | Computers & Internet
Mouse stops responding randomly
The issue may not necessarily be with the mouse. Are you able to use the keyboard once the mouse freezes? If you not even able to use the keyboard, there is some application installed on your computer or a virus due to which the mouse freezes. If, in case, the keyboard works even though the mouse is stuck, try changing the USB port or try a different mouse. Please revert back with any other observations. Good Luck
Mar 30, 2007 | Logitech Optical Wheel Mouse M-BT58...
IBM ThinkPad R50e Notebook Logo
128 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
