Question about Craftsman 675 Series 190cc 22" Briggs Stratton Rear Bag Front Propelled Lawn Mower ()
When I try to start it with the key start it will not turn over changed fuse but still no start. How do I check the starting system?
    Genius:
  • 1,114 Answers
What you probably have is either a bad connection to the starter, or switch, or you have a faulty starter, or battery. I would start by checking the wires. Take them loose and reconnect them. If that is to no avail, then you will want to have the battery and starter tested.
Posted on Mar 16, 2011
  • 3 Answers
Check the safety micro switch located under the blade brake mechanism. You should see 2 wires connected directly to the switch, if this switch has failed your mower will not crank with the key but otherwise will start with the pull cord.
Posted on Jul 01, 2013
AVALANCHE 2003 WON'T START NO SPARK
Yes, it can be a fuse. Check the 15amp INJ1 fuse under the hood. Also check the IGN 0, PCM 1 and PCM B fuses.
Aug 01, 2017 | Cars & Trucks
2003 chevy impala, turning the key on, you hear the fule pump clicking on , lights all coming on like normal, but go to start, nothing happens, battery ok, starter ok, the garage changed the ignition ...
That would be a good place to start , I would check it with a test light first but If you do that and it starts sounds like switch or connector terminals and or starter relay in fuse box
Nov 27, 2012 | 2003 Chevrolet Impala
My 2001 buick will not start at all when I turn the key to start....dashlights come on but when I turn the key to start no sound at all.....lights on dash goes out when I turn key to start but when I turn...
The battery is flat. Recharge, check charging voltage, and for parasitic voltage drain and replace if necessary. Don't replace the battery until you are certain you have no large amp drain from any faulty systems on the car. If your battery is around four years old or older then you may as well change it anyway however as batteries tend to start failing at that age.
Nov 15, 2012 | 2001 Buick Century
Oil change light wont go out on a 1999 grand am
Hello Dyno.
Have you tried using this procedure to turn it off?
OIL LIFE MONITOR SYSTEM
Resetting Procedure
  1. Turn the ignition to the ON position, engine OFF.
Drivers Side I/P Fuse Block 86382201
  1. Press and release the RESET button on the drivers side I/P fuse block.
    • The CHANGE OIL indicator will start flashing.
  1. Press and hold the RESET button until an audible chime is heard and then release.
    • If the CHANGE OIL indicator comes back on, the system did not reset. Try the procedure again.
Nov 10, 2010 | 1999 Pontiac Grand Am GT
My chevrolet 2003 tahoe want start it turns over but want start the batery is good fuel system it think
if battery good starters good that still leaves fuel,air,spark or timing you could try disconnecting throttle body hose that comes from the air filter try starting if still no start spray throttle body cleaner in the throttle while someone starts. Do you hear the fuel pump coming on when turning key to the on position. Have you checked to see if it is getting fire to the plugs?
Mar 18, 2010 | 2003 Chevrolet Tahoe
Truck will turn over but won't start
When you are trying to start the truck, does the theft light on the dash flash rapidly ?
- This would be a problem with the key used, PATS is not recognizing it as a programmed key, try another key
- Could be a problem with the PATS transceiver if 2nd programmed key does the same thing, wait on confirm to get into this, kind of long.
Have you checked the Fuel Inertia switch in the passenger side kick panel ( button reached from the top, needs to be pressed down ) ?
When you turn the key from off to run ( do not start ) do you hear the fuse pump run for ~ 2 seconds ? Should be able to verify at the schrader valve at the fuse rail for pressure ( safety glasses and a rag )
- Fuel pump fuse is one to check, Engine compartment fuse panel, fuse # 10 & Fuse # 18
- Fuel pump relay could be a problem, can swap with a trailer tow relay from the battery charge function ( if the trailer tow package is installed ).
- If both of these are no change, turn the truck to the run position ( do not start ) and hit the bottom of the fuel tank with a rubber mallet. Could be the fuel pump is plugged or on its way out.
Other item to check, is the last time the fuel filter way changed.
Oct 31, 2009 | 2002 Ford F150 Regular Cab
1998 HONFA CRV TURNS OVER BUT IMEDIATELLY SHUTS OFF
sounds like a security problem. most hondas have a chip in the key try another key. if your battery went dead that will make your security light come on when you try to start it will run for a few seconds then shut off look at the light indecater that shows a key or says secureity. this light will flash at you and continue as long as you got the key in the start posistion. the car may think its been stolen. using the correct not a spare that is used to unlock the doors.but the key you use every day put it into the door and turn it to lock twice then unlock twice this should reset your system
if you have a security system that is after market look under your dash board for a red or yellow wire that has a small reset button on it. above the pedals or on the left side of the floor board by the fuses. if you have this type turn the key to the on but not start hold the button for 5 seconds then let go. turn the key off wait 10 seconds then try to start your car K HAVE FUNNNNN
Feb 16, 2009 | 1999 Honda CR-V
H2 Hummer
Today 11-12-08 my 2003 H2 Hummer would not start. Checked battery it ischarged. Cables tight. Tried to start with portable booster pak. No go. Tridto jump start with my wife's Suburban. Still no go.
When I turn the switch I hear a single click and that is it. No engine turning over. While trying to start with key the headlights go out. Out of ideas, Will take to Chevy garage in am. Will post solution.
Aug 23, 2008 | 2003 Hummer H2
Craftsman 675 Series 190cc 22" Briggs  Stratton Rear Bag Front Propelled Lawn Mower () Logo
375 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
