Question about Canon imageRUNNER 400S Copier
IF PAPER HAS NOT JAMED BUT MACHINE ARE SHOW PAPER JAMED
  • 3 Answers
Try cleaning the rubber paper feed rollers. If it fails to pick up the paper in a pre determined time it will show paper jam. The pick up tires must pick up paper when turning, if not the paper will not feed into the machine and it will show paper jam with no jammed paper.
Posted on Mar 16, 2011
Printer show paper jamed without paper in it
There's a small piece of paper on the sensor. 4 in 1 Cleaning Paper for Laser Ink Jet Printers 12 Pack Perfect Data PD... You need paper path cleaning sheets like tho ones here. That should clear the jammed condition.
Aug 12, 2016 | hp deskjet 3600 series
Canon 2870 image runner. Paper jam error. But no paper was jamed. How to clear this error
sometimes switching the machine off at the machine and switching back on will clear a code fault.
Nov 07, 2014 | Office Equipment & Supplies
How do you take out a paper jam canon ImageCLASS D320?
First you have to know the position of the paper that has jamed.
the cardinal thing to do is to loosen and open doors that must be opened in order to have a clear view of the paper.
How to open see the marks on the machine. Mainly the paper jams between the drum and the fuser, so make sure you see any green nobs meant for seperating the presssure roller and the upper roller so that the paper is free to move out in case it jamed between the fixing rollers.
See the manual on how to remove paper jams.
Jul 12, 2011 | Canon imageCLASS D320 Digital Copier
It says clear paper jam
what brand of fax machine do you use?
try to open the fax machine ande see if there is any paper jamed or piece of paper jamed at the sensor.
Nov 11, 2010 | Office Equipment & Supplies
Has paper jamed in machine can not acess paper though any of the openings can see the paper though front bay it is jamed in between front rollers.
Not seeing this machine, if the drum can be taken out this can help.
If nothing can be taken out, be very careful when attempting to pull the paper out. Paper can scratch the surface of the drum and can pull stripper fingers out of place. Also there may be mylar fingers in place that may be bent or broken off causing further jams.
Using long pliers might work.
More description of this area needs to be given in order to pull this paper out. There might be other internal parts that need to be checked in order to keep this type of jam to occur again.
If al else fails place a service call by a copier service representative.
Oct 07, 2009 | Canon Office Equipment & Supplies
PAPER JEM WHILE PRINTING. I NEED A HEIP TO REPAIR THE PRINTER.
first, if thare any paper is jamed in the paper tray, pull the paper stright out. take out the remaining paper. close the paper tray.
opne the front cover pull out the toner cartirdge, remove the jamed paper.
open the inner door (where the paper exit). make sure there is not paper jamed it.
close the front door. if any paper jamed inside of the machine, it should automatically eject it out.
Note: reset the printer by opening and closing the front door.
Apr 03, 2009 | Samsung ML-2510 Laser Printer
MF5750 All-In-One Laser Printer DOES NOT PRING indicate paper jam I check and there is no paper jamed in the printer. It starts as it will pull the paper to copy document and then indicates in the display...
It starts as it will pull the paper to copy document and then indicates in the display that the paper is jamed.
Can anyone explain what the problem my be?
Please assist me.
Jan 19, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
Panasonic FP-7750 will not feed paper through machine correctly
Look where you remove the last jamed piece of paper closest to the fixing unit. Dose it jame when you make one copy? If it dose jam in the same place, I would have to say the problem is in the fixing unit. Look, in the unit for any pieces of paer jamed and remove them. Also, is it only happen with one paper tray and not the other. If so make sure you haze the tray and paper are set correctly.... Really need some more info.
Aug 05, 2008 | Panasonic FP-7750 Black and White Copier
Paper jam lite-still on
If your machine is showing a jam it could be that you have a piece of paper stuck in the machine. There are many areas to check. There is a help function on the machine and it will show you all of the areas to check. Use a flashlight because there may be a small piece of paper ripped off by a sensor. I would also take out the paper trays and shine my light inside. Make sure you check the duplexor cover also. This is on the right hand side. It open up and there are blue labeled areas to check. Just take your time and systamatically check all paper jam areas and you should find it. It could be a bad sensor in which case you may have to call a repair person. Good luck http://www.tonerovernight.com
Mar 25, 2007 | Toshiba e-Studio 350 Copier
Canon imageRUNNER 400S Copier Logo
365 people viewed this question
old marine
old marine
