Question about Mitel PRI Card T1 E1 (9109615001)
I am configuring a pri ckt in mitel sx200icp i cannot make outbound calls i have programmed pri card as per carrier in form 42 with NI2 - NI2bell have tried all procol variant incoming is fine
    Sergeant:
  • 378 Answers
It sounds like the outbound Caller ID is not set up properly in form 22. You will need to insert *6 into the dial string. If this isn't set up, many carriers will reject the call as it doesn't see the correct outbound caller ID.
Sincerely,
Mark
Posted on Apr 02, 2011
Where is the Caller ID for Outbound calls programmed?
Have you resolved this yet? If your CO connection is analog, it's done by your telco. If you have a PRI (T1), then it's in your system's configuration.
Jun 26, 2014 | Nortel Lands Phones
Can i connect a mitel 5224 ip phone to a standard land line connection.
only with a "Line Interface Module". This is a module that attaches to the back of the phone. Once attached a button will need to be programmed to allow it to work.
The phone will still need to connect to the telephone system - SX200ICP or 3300/MCD.
Dec 17, 2010 | Mitel 5224 IP Phone
My Mitel 5340 will not go to voicmail and keeps ringing
You need to set this extension up in the Call Rerouting form in the PBX. Program the First alternative to go to the voicemail extension.
Oct 29, 2010 | Mitel 5340 IP Phone
Two lights on phone mitel 5212 ip phone
It sounds like your phone is in do-not-disturb. Press the blue key. Press the no (# key) until you see DND, then press Yes (* key). Press Turn off (0 key).
Apr 07, 2010 | Mitel 5212 IP Phone
Disable external calls on mitel 3300
This is a function your phone vendor will need to complete for you specifically they will need to setup a Class of Restriction for the set that you would like to block from using your outbound trunks.
Nov 25, 2009 | Mitel 5212 IP Phone
Can make outbound call on Blackberry Bold. Bought 2nd hand unlocked unit from the US. Can receive calls but everytime I try to make outbound calls it says: "Call failed due to SIM Toolkit control error....
This error is due to having an old SIM card.
Please talk to your carrier to get the latest SIM card.
You most likely have received an old SIM card batch.
Hope it helped.
Nov 23, 2009 | RIM BlackBerry Bold Smartphone
Mitel SX-200 D PBX generic 1003 ACD- doesn't support ISDN.
You are not going to get the ANI information you need from the current configuration, the only way to get that information is thru the use of PRI.
Apr 08, 2009 | Mitel 9109-021-000 T1 Trunk Card (24...
Mitel IP3300 Outbound Caller ID
First you will need to contact your carrier. I am assuming that you have a T1 or PRI service. Carrier is usually the one that controls caller id. If they dont have any restrictions please contact your local Mitel dealer. They will need to program your system.
Cheers
Mar 18, 2009 | Lands Phones
Lucent Magix Avaya
Magix is discontinued product. Suggesting upgrading to IPOffice.
Then you will be able to see if carrier is the real problem.
Mar 17, 2009 | Lucent Lands Phones
Mitel PRI Card T1 E1 (9109615001) Logo
210 people viewed this question
Top Mitel Computers & Internet Experts
Martin Murray
Kelley Hopper
Are you a Mitel Computer and Internet Expert? Answer questions, earn points and help others
