Question about Garden
I am trying to find a part but I don't know what its called. Looks like hoses plug into it on each side of a small (size of a quarter) round plastic piece. One hose is about 3/4" the other about 1/4" or less.
  • 784 Answers
Adapter
Posted on Mar 16, 2011
1994 chevy blazer s 10 size vaccum hoses at
There should not be an open vacuum hose. Look around it for a place it may have come off of. If there is enough play, you can trim a quarter inch of the end, if its stretched out, and replace it back on its fitting. If you really cannot find where it goes, just plug the end with somthing till you figure it out. A small screw, or similar usually works.
Sep 15, 2011 | 1994 Chevrolet S-10 Blazer
Where can we get a part to plug the hole so the water will drain out the hose? The hole is not round so it makes it more difficult to plug. HDN 655E 65 pints Thank you. Bob
Bob, you don't need to plug the hole for the water to drain out the hose. Once you remove the hose connection cap and connect a hose, no longer than 5 feet (a garden hose will work), the water will drain from the hose and not into the bucket. That is, unless the drain tube is clogged. In which case, an 18" long, plastic, Zip Tie, appropriately sized to fit in the hole, works well to unclog it.
Hope this helped you. Please let me know. Thanks.
Jun 25, 2011 | Haier HDN655E Dehumidifier
Don't know how to get detergent into the ultimate x pressure washer (1500psi)
To the right of the Brass fitting where your garden hose attaches there is a small round plastic cover piece, pull on that and it will pull out a clear tube with it which goes into any container containing your detergent, it will pull the detergent as you use the pressure washer. Push the tube back in after you are done using it. You can also buy a replacement detergent bottle for other pressure washers if you wanted to.
Jun 05, 2011 | Garden
What exactly is the "round
that is where your heater core is. Its leaking, or the feed hose to the heater core is leaking. You really need to pull the plastic cover off, just below the dash on the passenger side to look. the heater core looks like a small radiator. If coolant is leaking out of it, replace it. the coolant will cause problems in the long run, if you don't fix it now. After fixing it, steam clean the passenger side of the suv, to stop having a smell, and stop the corrosion. hope this helps
Jan 04, 2011 | 2001 Dodge Durango
There is no fuse box cover inside of 1991 galant to see where the turn signal relay is? Where can I find free diagram to locate what fuse is what?
hello, turn signal relay is round, it plugs into your fuse panel, it should be the size of a quarter round, you have relay for brakes and turn signals, both are round, and they are only about 1 inch to inc half long, eay to spot them, they are only two round plastic things that plugs into fuse box,
Feb 06, 2010 | 1991 Mitsubishi Galant
2001 ford taurus 3.0-engine leak behind left rear engine head-car runs good-does not overheat-cannot find leak-no leaks in radiator or heater hoses or water pump.
It may be the freeze plug in the back of the head leaking, it looks like a small round cup about the size of a quarter it presses into the back side of the head, to remove hit the outer side of the inside of the cup with a screwdriver and hammer. To install use the apropriate size deep well socket with extension to hammer the new one in don't hit it in too far just until flush and also use permetex black sealant around the rim before installing to ensure a good seal also drain antifreeze completely before attempting job and be sure the seat where the freeze plug is going into is clean and dry.
Dec 29, 2009 | 2001 Ford Taurus
Where is cmos battery located in Dell d505?
It's called the Reserve Battery in a Dell Latitude D505.
(It's also called an RTC battery in others, {Real Time Clock battery}, and CMOS battery in older laptops)
1.Remove the AC adapter if plugged in. (Charger)
2.Remove the Battery.
3.Right up against the outside edge of the battery compartment, in the middle. you will see the battery latch.
Push it down. The Reserve Battery Cover will come loose at the top. Rotate the top, towards the inside of the battery compartment.
The Reserve Battery is right there.
Pull the Reserve Battery towards the battery compartment.
(Comes right out of the small rectangular compartment it is in)
(It looks like three round coins put side by side, and has a green plastic coating around it.
In actuality, there are coin sized watch batteries inside that green plastic cover)
You will see a Red wire, and a Black wire twisted together, that go to a small white connector. The connector is two piece. Separate the connector, and you can take the Reserve Battery out.
http://support.dell.com/support/edocs/systems/latd505/sm/reserve.htm#1123661
Dec 19, 2009 | Dell Latitude D505 Notebook
My blower control stays in defrost mode even while turned to dash or leg vent. I recently changed my plugs but I don,t see any loose wires or vacuum hoses that might effect this. Could I have done...
I'll bet when you changed the spark plugs,one of the small vacuum hoses got disconnected or cracked.look the small plastic hoses(1/8)size on the right side,near the firewall, bending them lightly.
Oct 06, 2009 | 2004 Ford Ranger
Can't locate the oil drain plug to change oil.
Around the base of the motor there should be small round cap about the size of a quarter with two small round quarter inch high posts on it - that is for finger leverage.. Unscrew it and tip the mower so all the oil comes out.. Replace oil and cap.
Sep 23, 2009 | Poulan Pro 22" Self Propelled High Wheel...
I Do not know what the part im trying to fix is called
if this is on the drivers side back of engine you should be talking about the heater control valve/there should be a small vac line hooked to it/replace the heater hoses to
Aug 23, 2008 | 1991 Volvo 740
Garden Logo
15 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
