Question about Sony STR-DE505 Receiver
Speaker Channels? STR-DE505
I bought this unit for $10 at the salvation army. I'm just curious as to what might have happened to it. I haven't taken it apart yet, so i'm just going on observation. When turning the unit on, without the surround being on you have no relay clicks, and no sound (with both A and B turned on). If you turn surround on, you hear a relay click and get sound out of the rear/center channels. Pressing/Depressing A will then give a relay click. I wonder if there is a problem with the amp, or the relay? any ideas?
Hi There,
Maybe can clarify the reasons you have different output configurations.
I worked for Dolby in London for ten years and cinema processing was an area close to me.
To cut a long story short;
The number of factors and different combinations possible for a fully equipped cinema offering Dolby and / or other protocols to the guest is large to say the least even within the Dolby formats.
For Sony to try to offer a range of home units (recievers or tuner/amps/decoders in this case) was to say the least ambitious .but hey!..........who else can give the public what they think they need.,,,good old Sony
I have looked at this unit and it seems the "amplifier section" is used for various configourations
and power output ratings vary depending on the configuration you choose.
Stereo 2 ch L+R is 2 x 75w
Surround requires more channels (centre and mono rear) and of course new signal routing to and from these blocks which of course will draw from the modest power supply.
So 4 channel surround will deliver 4 x 50w.
etc. etc.............what you hear are the relays which are reconfiguring and re - routing the signals.
Basically you cant have all the sections working all the time due to cost /design restraints
So speakers A OR B can be used but not BOTH when in surround mode....where the centre and surround are needed. .you cant have A and B at any time....push both buttons an NEITHER will work ....release one button and there you go.............it saves "letting the smoke out of the box".........which you should never do...........cos they never work without it. :)
Sorry for boring you ...............but I think you will find the unit is working just fine.............you could read the manual but that's not too informative.
Right...off to get a life now
Nik
Posted on Nov 22, 2008
I purchased some furniture from The Salvation Army. The furniture was infested with Bed Bugs
That's not good. Keep it outside and treat it with Diatomaceous Earth. It's a natural powder and it works! You can buy it online. If not interested in that option, take it back to the S.A. They should understand and refund your money.
Feb 04, 2017 | The Computers & Internet
LOOKING FOR A MANIUAL FOR THIS TYPE OF KEY BOARD I BOUGHT AT THE sALVATION aRMY.
sorry we do not know what make or type crockpot has a keyboard . Most you find in those places are thrown away because they quit working .
Feb 20, 2016 | Crock Pots & Slow Cookers
Can I hookup a Sony receiver STR-DE505 to a Bassbite 2 KLH Audio system and how??
Yes.
It's frustrating that KLH manuals seem impossible to find anywhere online BUT a simple picture will suffice...
Go here and supersize the picture of the rear of the sub...
http://cgi.ebay.com/KLH-Audio-Systems-Bassbite-V-Model-E214708-Speaker-/110673631693
Run your front channel speaker wires to the CLEARLY-MARKED connectors on the sub and daisy-chain your front speakers to the CLEARLY-MARKED connectors on the sub.
Adjust the sub volume to match the front speakers levels. This will give you local volume control at the Sony.
Jun 04, 2011 | KLH BB-II Subwoofer
Hai.i have a sony str-de505 amp. one day i put the volume high n on the unit.suddently the sound goes high n then no more produsesing a single sound.when i switch on the souround n on the uni,the sound...
You cooked it. Maybe you lucked out and just blew a speaker.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
May 31, 2011 | Sony STR-DE505 Receiver
NEED A MANUAL, BOUGHT THIS FROM THE SALVATION ARMY. THANKS
www.bushnell.com/manuals/telescopes/78-9512_Deep%20Space.pdf
Hi please find you user manual for this series above.. enjoy.
Aug 29, 2010 | Bushnell Deep Space 78-9512 (120 x 60mm)...
I need to find how to program a toshiba vhs to a
Can't pin down the code for your model, so you will have to try these! Bear in mind that some codes could work some parts of the VCR but not all, so test all:
1004, 1023, 1038, 1175, 1176, 1188, 1190, 1191, 1200, and 1239.
Nov 06, 2009 | Televison & Video
Sony STR-V333ES repeatedly clicks when i try to power it up. is there an internal fuse???
You most likely have a short in one of your speaker wires (+ and - are touching somewhere) causing the receiver to enter a protect mode "Click!". Disconnect all speaker wires then connect and test each one at a time to find the culprit. I've seen this happen with speaker wire or a subwoofer cable that is too small of a gauge. Hope that helps.
Feb 19, 2008 | Sony STR-V333ES 5.1 Channels Receiver
Giannina express
I just bought mine at a salvation army today ( it looks brand new , and it has a blue molded rubber gasket on the bottom side of the top piece )
Nathan H.
Nov 18, 2007 | Giannini Coffee Makers & Espresso Machines
208 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
