Question about Logitech Cordless Mouse
Wireless mouse does not connect to the computer model number C-B033
5 Suggested Answers
yooperbud
  • 8637 Answers
SOURCE: Wireless Mouse a Problem
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch. Hope this helps you. Bud
Posted on Jan 16, 2009
  • 51 Answers
SOURCE: Computer not recognizing Keyboard, only Mouse
Go through the process outlined in the instruction manual for connecting the keyboard to the wireless adapter. If this does not work, then replace the keyboard batteries and do it again.
Posted on Aug 17, 2007
  • 8 Answers
SOURCE: how do i connect my
you will need a little USB bluetooth or infrared dongle should be in the box
Posted on Sep 14, 2011
I believe my mother got it from someone an I don't see the usb
Posted on Jun 03, 2013
My gateway wireless mouse won't sync
- Have you tried the steps mentioned in the link to connect a wireless keyboard and mouse to the Gateway computer? http://support.gateway.com/s/desktop/2009/gateway/zx/zx4800/ZX4800faq3.shtml
http://www.support.gateway.com/s/Manuals/Profile/WirelessKb_MouseGuide.pdf
Also follow the generic troubleshooting steps mentioned in the link to connect a wireless keyboard and mouse to a computer.
http://support.microsoft.com/kb/838398
Note: The steps provided in the link mainly works for Microsoft hardware but the steps can be applied to any wireless keyboard and mouse. Do not install any software given in the link as it will not help you if you do not have a Microsoft Hardware.
It would be helpful if you could provide us the exact computer model number and also the make and model number of the keyboard and mouse.
Feb 14, 2015 | Gateway GM5664 Desktop PC
How do I setup a wireless mouse on a desktop
To setup a wireless mouse regardless of its type, do the following:
1. Insert the USB transmitter (this could look like a mini plug or a stick) and wait for windows to complete installation.
2. Once this is successful, turn on the mouse by holding down the power button. Or insert the disc that came with the mouse and run the installer. The installer will install the device drivers and setup your mouse's configuration panel which will reside in your system tray.
Make sure that the mouse has batteries and that it is switched on for it to work. It will glow red when it is switched on.
Jul 06, 2011 | Gigabyte Wireless Optical USB Mouse GMW7C
I can't get my hp wireless mouse workn
The first thing to determine is whether or not you are getting a connection. Check to see if there is power on the device that is plugged into your computer. (The device which plugs in via USB). If you are not getting power to that, try a different USB port. If you are getting power to that device, follow Step 2:
The next thing to try is to look underneath the mouse. If you see a red light, it means the batteries are fine. If you don't see a red light replace the batteries. If that doesn't work, follow Step 3:
The next thing to check are the drivers on your computer. You will probably need a wired mouse to do this though. Unplug the wireless mouse, then plug in a wired one. Since I'm not sure on the model of your mouse, go to HP's website and click into the Drivers and Downloads section. Locate your mouse model number underneath the mouse or wireless transmitter, then search for the drivers. Once you have located the drivers, download them to your Desktop, but don't install them. Once they are downloaded, unplug the wired mouse from your computer, then plug in the wireless mouse and proceed to Step 4:
Before you install the drivers, go Start > Control Panel > Device Manager > Mice and Other Pointing Devices, then uninstall each mouse driver listed in here. You're doing this in case another mouse driver is conflicting with your current one. Reboot your computer. Once the computer is rebooted, go on to your Desktop and install that driver you downloaded from HP's website. Press the sync button on your wireless receiver (if there is a sync button), then try your mouse again.
Feb 18, 2011 | HP Wireless Optical Mouse
My acer mouse model number mg-0919 stops working after about 2 minutes. I have to turn the mouse off then back on. This happens constantly. What is going on? Is it defective? My mouse is under...
I had the same problem. This mouse came with my Acer Revo which was still under warranty. Tech support basically says to check the obvious (batteries, USB connection, RF interference). Their obviously canned answer goes on to detail a manual reconnect procedure that does not apply to this model. And when all else fails, get a new mouse.
This is what Acer tech support emailed me:
If you are experiencing issues with your wireless mouse not working properly, perform the following steps to troubleshoot the wireless mouse.
1) Ensure that the receiver is 8-inches from other electrical devices. Avoid placing the cordless devices on metallic surfaces.
2) Verify that the USB connector from the receiver is properly plugged into a USB port on the computer. Try plugging the receiver into a different USB port to ensure that the USB port is working properly.
3) Remove the batteries and then reinsert the batteries into the mouse, making sure that the battery polarities are correct.
4) Test the batteries to ensure that they still have a charge.
5) Try the manual connect procedure.
Manual connect procedure:
1) Press and release the Connect button on the receiver.
2) Within 30 seconds, press and release the Connect button on the mouse.
If the issue persists, we can replace your computer's wireless mouse.
We will ship the new wireless mouse within 3-5 business days.
Before placing an order for wireless mouse we would like to confirm the following.
1) Complete shipping address:
2) email address:
3) phone number:
In order to place an order for wireless mouse, the computer must be registered.
Oct 06, 2010 | Acer Aspire One PC Notebook
Hi there, I've got a Toshiba mouse, model number
Maybe mouse needs new batteries.
Take that "Small(wireless) part and put try it in another usb port
Aug 25, 2017 | Toshiba C99704 Mouse
I have Model 1058 Mouse bought 12/09. Computer crashed (motherboard) and had to get new one. Can't find installation disk for mouse. Can you help?
change the mouse battery and there is a button named connect on mouse keep pressing the connect button for 3-4 minuts and keep mouse near wireless device which is connected to the computer in USB port then restart your computer and mouse will work fine.
Mar 30, 2010 | Microsoft Wireless Laser Desktop 4000...
Does the labtec wireless mouse turn itself off when not in use
You should always safely shut down and turn off your computer before plugging or unplugging the mouse from the PS/2 mouse port. If you do not safely turn off your computer, you may damage the mouse port, the mouse, or both.
Your Labtec mouse should detect and function by simply connecting it to the computer´s PS/2 mouse port or USB port. If you have 3 Button Labtec Mouse (M/N: M-CAC64), your mouse will work in the PS/2 and serial port with the supplied adaptor. If you are using the 3 Button Labtec mouse, we recommend using the PS/2 port. To determine the model number of your device, turn it upside down and look at the label. Model numbers are indicated by "M/N:". This will help you determine what system ports your Labtec mouse can be connected to.
Thank you
Mar 14, 2010 | Labtec Wireless Desktop Keyboard/Mouse...
It will not connect and I can not find the product number anywhere it is a 98812 ge mouse
if you press connect on the bottom of the mouse and then press connect on the USB thats plugged into the computer it should work.
Aug 16, 2009 | GE Wireless Optical Mouse
Microsoft Wireless Notebook Optical Mouse Not Connecting
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the mouse. This should be done whenever you change batteries or glitch.
Jan 30, 2009 | Microsoft Wireless Optical Notebook Mouse...
Wireless mouse and keyboard not working
If you have got a USB receiver for the wireless keyboard and mouse, then the solution might be with the receiver. Normally we know that to play a USB thumb drive, we simply plug in and play. But some model of Acer computer require us to press the button on the thumb drive to activate it. The model I had (an Aspire model) set the press button same as the blicking light bulb. So (a) turn on computer, (b) plug in thumb drive receiver (c) press button on the drive, (d) press "contact" button on the mouse and keyboard. That works for me.
Mar 08, 2008 | Acer Wireless WIL-152 91.84R07.152...
Logitech Cordless Mouse Logo
324 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
